Switching between Wifi and BLE
So very happy with my 2 Nano 33 IoT boards.
I have got both BLE working to control a peripheral LED using the other board as Central, and Wifi working to make a web page showing the Analog pins. Very impressed with this as the web pages auto update the analog readings. Easily got 5 web pages all working at the same time. (Just the basic examples with perhaps a few changes)
Has anyone merged the two ideas. Have one Nano 33 IoT as a web page generator that shows and controls the other Nano 33 IoT LED using BLE?
I know BLE and Wifi can't work in parallel on this board but can you easily and quickly switch between the two.
jerteach:
One of the Arduino developers has done some work towards allowing this. It requires changes to the NINA module's firmware:
https://github.com/agdl/nina-fw/tree/coexistance
the Arduino SAMD Boards package:
and the ArduinoBLE library:
pert:
That looks really interesting Pert for a more advanced Arduino user, I think I will just stick to the default Nano 33 IoT install.
I think that's probably a good decision. My intent was more to make you aware that we are likely to see this functionality officially supported by Arduino at some point.
I have created a project where I can switch between WiFi and BLE. I had some issues on the way and have not cleaned the code yet. Currently I need to reset the Nina and restart the WiFi driver.
The switch takes significant amount of time and therefore is only useful for use cases where you want to configure your device via Bluetooth and then switch to WiFi. You can also restart the Bluetooth mode from a webpage.
Klaus_K:
Interesting Klaus_K I would like to have a look at your code. Curious about the time delay. I just want to read 3 BLE LED's on or off state from 3 different devices, then update the Nano 33 IoT generated webpage. So a 10 second time delay might not be a big deal.
Presently I am having some strange issues just getting my BLE LED Central control program working. Seemed to work fine 3 days ago but now does not connect to the peripheral LED. The peripheral works fine since I can change the LED using nrf-connect for mobile, and my web page javascript BLE program.
My program on github is here
The program scans for devices that contain the local name "LED" then when you send a "1" it connects to the last device found. Then when you send a "2" it goes back to scanning. When it is connected you can connect 3V3 to pin 2 to turn on the LED on both devices (The central and the peripheral).
It was just a test program. It does seem to work, but my serial output is not getting me much useful information.
Update to the above. All three BLE programs work fine just getting strange data from these calls.
// Note the 2 GATT's are slightly different: service=19b10010,  LED=19b10011
    BLECharacteristic ledCharacteristic =   peripheral.service("19b10010-e8f2-537e-4f6c-d104768a1214").characteristic("19b10011-e8f2-537e-4f6c-d104768a1214");  //worked
    Serial.print("ledCharacteristic: ");
    Serial.println(ledCharacteristic);
    Serial.print("ledCharacteristic.descriptor(0): ");
    Serial.println(ledCharacteristic.descriptor(0));
    Serial.print("ledCharacteristic.descriptor(0).value(): ");
    Serial.println((int)ledCharacteristic.descriptor(0).value());
    Serial.print("ledCharacteristic.descriptor(1): ");
    Serial.println(ledCharacteristic.descriptor(1));
    Serial.print("ledCharacteristic.descriptor(1).value(): ");
    Serial.println((int)ledCharacteristic.descriptor(1).value());
What I want to see is proof about if the LED is on or off, but what I am getting is zero when the LED is on or when it is off.
ledCharacteristic: 1
ledCharacteristic.descriptor(0): 0
ledCharacteristic.descriptor(0).value(): 0
ledCharacteristic.descriptor(1): 0
ledCharacteristic.descriptor(1).value(): 0
... Sorry editing while working on things.
I think I understand what the problem is. Got it working now with some changes, but I do not like this function.
void printData(const unsigned char data[], int length) {
  for (int i = 0; i < length; i++) {
    unsigned char b = data[i];
    if (b < 16) {
      Serial.print("0");
    Serial.print(b, HEX);
Can someone explain it, or better yet show me a simpler way to tell if the LED is on or off.
The code I needed to get things working is
  if (ledCharacteristic.canRead()) {
    ledCharacteristic.read();
    if (ledCharacteristic.valueLength() > 0) {
      Serial.print(", value 0x");
     printData(ledCharacteristic.value(), ledCharacteristic.valueLength());
I have cleaned up my code and did some more experimenting. I do not need to reset the Nina module but reinitialize the WiFi driver when switching to WiFi. Here is my example. You will need to add a "arduino_secrets.h" file like other WiFi example for your Wifi network credentials.
  BLE2WiFi
  This example creates a BLE peripheral with a service that contains a
  characteristic to switch to WiFi.
  The circuit:
  - Arduino Nano 33 IoT,
  You can use a generic BLE central app, like LightBlue (iOS and Android) or
  nRF Connect (Android), to interact with the services and characteristics
  created in this sketch.
  This example code is in the public domain.
#include <ArduinoBLE.h>
#include <SPI.h>
#include <WiFiNINA.h>
#include "utility/wifi_drv.h"
#include "arduino_secrets.h"
#define BLE_UUID_NETWORK_CONFIG_SERVICE              "343D2964-5ECF-2297-4463-609011571F24"
#define BLE_UUID_NETWORK_ENABLE_CHARACTERISTIC       "767B22E7-EA6C-B017-286A-55B68310FD9D"
BLEService networkConfigService( BLE_UUID_NETWORK_CONFIG_SERVICE );
BLEBoolCharacteristic networkEnableCharacteristic( BLE_UUID_NETWORK_ENABLE_CHARACTERISTIC , BLERead | BLEWrite );
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssidName[] = SECRET_SSID;
char ssidPass[] = SECRET_PASS;
WiFiServer server( 80 );
int status = WL_IDLE_STATUS;
bool networkInitialized = false;
bool wifiModeFlag = false;
const int LED_PIN = LED_BUILTIN;
  Serial.begin( 9600 );
  while ( !Serial );
  pinMode( LED_PIN, OUTPUT );
  if( !networkInitialized )
    if( !wifiModeFlag )
      Serial.print( "Switch to BLE: " );
      if( !switch2BleMode() )
        Serial.println( "failed" );
        networkInitialized = true;
        Serial.println( "success" );
      Serial.print( "Switch to WiFi: " );
      if( !switch2WiFiMode() )
    if( !wifiModeFlag )
      bleMode();
      wifiMode();
void bleMode()
  BLEDevice central = BLE.central();
  if ( central )
    Serial.print( "Connected to central: " );
    Serial.println( central.address() );
    while ( central.connected() )
      if( networkEnableCharacteristic.written() )
        wifiModeFlag = true;
        return;
void wifiMode()
  int connectCount = 0;
  if ( status != WL_CONNECTED )
    while ( status != WL_CONNECTED )
      connectCount++;
      Serial.print( "WiFi attempt: " );
      Serial.println( connectCount );
      if( connectCount > 10 )
        Serial.println( "WiFi connection failed" );
        return;
      Serial.print( "Attempting to connect to SSID: " );
      Serial.println( ssidName );
      status = WiFi.begin( ssidName, ssidPass );
      if( status != WL_CONNECTED )
        // wait 10 seconds for connection:
        delay( 10000 );
    printWiFiStatus();
    server.begin();
    WiFiClient client = server.available();
    if ( client )
      String currentLine = "";
      while ( client.connected() )
        if ( client.available() )
          char c = client.read();
          if ( c == '\n' )
            // if the current line is blank, you got two newline characters in a row.
            // that's the end of the client HTTP request, so send a response:
            if ( currentLine.length() == 0 )
              // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
              // and a content-type so the client knows what's coming, then a blank line:
              client.println( "HTTP/1.1 200 OK" );
              client.println( "Content-type:text/html" );
              client.println();
              // the content of the HTTP response follows the header:
              client.print( "Click <a href=\"/H\">here</a> turn the LED on
              client.print( "Click <a href=\"/L\">here</a> turn the LED off
              client.print( "Click <a href=\"/B\">here</a> disconnect WiFi and start Bluetooth
              // The HTTP response ends with another blank line:
              client.println();
            else        // if you got a newline, then clear currentLine:
              if ( currentLine.startsWith( "GET /H" ) )
                digitalWrite( LED_PIN, HIGH );
              if ( currentLine.startsWith( "GET /L" ) )
                digitalWrite( LED_PIN, LOW );
              if ( currentLine.startsWith( "GET /B" ) )
                // GET /B switch to Bluetooth
              currentLine = "";
          else if ( c != '\r' )
            currentLine += c;
      client.stop();
bool switch2BleMode()
  if ( !BLE.begin() )
    return false;
  // set advertised local name and service UUID:
  BLE.setDeviceName( "Arduino Nano 33 IoT" );
  BLE.setLocalName( "Arduino Nano 33 IoT" );
  BLE.setAdvertisedService( networkConfigService );
  // add the characteristic to the service
  networkConfigService.addCharacteristic( networkEnableCharacteristic );
  // add service
  BLE.addService( networkConfigService );
  // set the initial value for the characeristic:
  networkEnableCharacteristic.writeValue( false );
  BLE.advertise();
  return true;
bool switch2WiFiMode()
  BLE.stopAdvertise();
  BLE.end();
  // Re-initialize the WiFi driver
  // This is currently necessary to switch from BLE to WiFi
  wiFiDrv.wifiDriverDeinit();
  wiFiDrv.wifiDriverInit();
  return true;
void printWiFiStatus()
  Serial.print( "SSID: " );
  Serial.println( WiFi.SSID() );
  IPAddress ip = WiFi.localIP();
  Serial.print( "IP address: " );
  Serial.println( ip );
  long rssi = WiFi.RSSI();
  Serial.print( "Signal strength (RSSI):" );
  Serial.print( rssi );
  Serial.println( " dBm" );
Klaus_K:
Wow. That is really sweet. Very fancy and easy how you communicate from the web page to the Arduino. Everything worked for me immediately. Thank you for sharing. That should be a great base for my project.
Klaus_K:
I am still working on code to generate a webpage, then read a few BLE devices then update the webpage. All my test code is on my github at everything-nrf52840-usb-dongles/code/simple-ble-led at master · hpssjellis/everything-nrf52840-usb-dongles · GitHub
Quick question for Klaus_K or anyone else, when you restart WiFi you use the below code (Thank you very much, no idea how I would have figured that out myself):
Curious what, in your opinion, is needed to shutdown WiFi and shutdown BLE. Also is there code to start BLE?
I will test things in the next few days, but I am guessing after basic setup is done the pseudo code for starts and stops is:
After some testing these commands seem to work individually. Next step is to put them together.
//Start Wifi
  status = WiFi.begin(ssid, pass);
  server.begin();
// End Wifi
  WiFi.end()
//Start BLE
    BLE.begin();
    BLE.scan();
// End BLE
   BLE.stopAdvertise();   //don't think this is needed as I am reading other BLE devices
   BLE.stopScan();
   BLE.end();
If you want to stop WiFi you can use the WiFi.end() function.
To enable BLE you only need the code from my functions. BLE.begin(), setup a GATT and start advertising.
There is also a pin to reset the Nina module. I thought I needed that to switch from BLE to WiFi but it turned out it was not necessary.
So I basically have what I want working and will show the code once it is tidied up. Just stuck on something that I will use trial and error to probably solve today. Wondering if anyone has a solution.
I barely understand the following code but I need to rewrite it to return a boolean result, not to do a serial print. Any suggestions?
It is given the hex numbers 0x00 or 0x01 from a BLE device and returns a serial print of "00" if the LED is off and "01" if the LED is on. I need it to return true or false. Here is the working code and my latest attempt below it:
// helper function to print HEX variables, takes from device 0x00 or 0x01 Hex numbers
    if (b < 16) {
      Serial.print("0");
// And here is my attempt to return a boolean.
//Ignored the length as it is fixed at 1
//Probably could make this much shorter.
bool ledIsOn(const unsigned char data[]) {
  for (int i = 0; i < 1; i++) {
    if (b <= 0) {
      return false;
      return true;
// Any suggestions from someone who actually understands the code snipets.
You do not need the for loop. One of the two returns will be executed in any case in the first loop.
unsigned char b = data[0];
if (b <= 0)
  return false;
  return true;
Klaus_K:
Thanks Klaus_K, that was a lot easier than it originally looked. I guess the first method was for any size HEX value.
I am finding an interesting little BLE LED bug.
When you use nrf-connect to change the value of the LED, say turn it on, then reset the device, the LED stays on, but my program does not know that the device LED is turned on, it assumes the BLE device LED on startup is off. Not sure if this is a bug or something I have programmed.
I would not call it a bug. Call it a feature. :slight_smile:
You usually do not care about memory locations that are no longer used. There are plenty of bytes in your microcontroller that are in a random state from the last operations when they were used. In case of an I/O you are just in the position to notice this fact and sometimes its a bad situation.
I can imagine different scenarios. In some you need to make sure the I/O is reset in others you will be happy to have the I/O stay in the state it was last.
Klaus_K:
Actually it is a bit strange and probably a bug in my Simple-LED-Peripheral program, but the Nano 33 IoT and the Nano 33 BLE seem to compile differently. The Nano 33 IoT seems to work fine. I can set the LED off at startup and as a characteristic it is off, but the Nano 33 BLE seems to always set the LED on, but as a characteristic it thinks it is off.
Also I think the button only works on the second attempt, which sounds like something is not being setup properly.
Here is a link to my Simple-LED-peripheral or see the code below
  simple-led-peripheral.ino
  This example creates a BLE peripheral with service that contains a
  characteristic to control an LED and another characteristic that
  represents the state of the button.
  The circuit:
  - Arduino MKR WiFi 1010, Arduino Uno WiFi Rev2 board, Arduino Nano 33 IoT,
    Arduino Nano 33 BLE, or Arduino Nano 33 BLE Sense board.
  - Button connected to pin 4
  Edited By Jeremy Ellis
  Jan 2020
Can use Simple-LED-Central To communicated with this.
// Global constants and variables
const int ledPin = LED_BUILTIN; // set ledPin to on-board LED
const int buttonPin = 4;        // set buttonPin to digital pin 4
int myOldButtonValue;
BLEService ledService("19B10010-E8F2-537E-4F6C-D104768A1214"); // create service
// allow remote device to read and write
BLEByteCharacteristic ledCharacteristic("19B10011-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);
// create button characteristics
BLEByteCharacteristic buttonCharacteristic("19B10012-E8F2-537E-4F6C-D104768A1214", BLERead | BLENotify);
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT_PULLDOWN); // use button pin as an input
  // Note: No serial needing a line feed so this works with battery power.
  // just to prove it is running, flash LED twice, since no serial.
  digitalWrite(ledPin, HIGH);
  delay(400);
  digitalWrite(ledPin, LOW);
  delay(400);
  delay(400);
  delay(400);
  // begin initialization
  if (!BLE.begin()) {
    while (1);  // kills it here
  // set the local name peripheral advertises
  BLE.setLocalName("SimpleLED");
  // set the service
  BLE.setAdvertisedService(ledService);
  // add both characteristics to the service
  ledService.addCharacteristic(ledCharacteristic);
  ledService.addCharacteristic(buttonCharacteristic);
  // add the service
  BLE.addService(ledService);
  // set default values
  ledCharacteristic.writeValue(0);
  buttonCharacteristic.writeValue(0);
  // start advertising
  BLE.advertise();
  BLE.poll();  // poll for BLE events
  // Read button, compare and set button
  int myButtonValue = digitalRead(buttonPin);
  if (myOldButtonValue != myButtonValue){
    myOldButtonValue = myButtonValue;
    digitalWrite(ledPin, myOldButtonValue);
  // Check if external program controlling button
  else if (ledCharacteristic.written()){
    digitalWrite(ledPin, ledCharacteristic.value());
  delay(10);
Some really good news, is that my Wifi-BLE-generic program is working here I could not get @KLAUS_K buttons working but what I set out to do works fine. Thanks to both @Klaus_K and @pert. It generates a webpage showing the analog pins but also searches for any BLE device with "LED" in it's name and shows if the LED is on or off.
As with the above issue it works fine on the Nano 33 IoT but has some minor issue on the Nano 33 BLE.
Fairly happy though.
I posted in the Nano 33 BLE forum here wondering if anyone knows an easy way to force the Peripheral BLE to unpair. I can do it manully with a button push reset, and could probably force a reset through software but that seems a bit extreme. Does anyone know of a way to get my Simple-LED-Peripheral device to unpair every say 20 seconds just to clear it for a different device to pair with it (I can do the timer stuff just not sure how to unpair)?
The ArduinoBLE API is here
Hello jerteach.
I am trying out a lot of the BLE stuff myself so don't my word as gospel.
However, I just ran a simple test using this code to check:
  // listen for BLE peripherals to connect:
  // if a central is connected to peripheral:
  if (central) {
    Serial.print("Connected to central: ");
    // print the central's MAC address:
    Serial.println(central.address());
    long currentMillis = millis();
    long timeoutMillis = currentMillis + 20000; //20 second timeout
    // while the central is still connected to peripheral:
    while (central.connected()) {
      // Do stuff
      if (timeoutMillis - currentMillis <= 0) {
        Serial.println("Timeout");
        central.disconnect();
    // when the central disconnects, print it out:
    Serial.print(F("Disconnected from central: "));
This worked fine, as did BLE.disconnect(), the central device, in this case, a phone, could connect, was disconnected and could connect again. You could maybe also try getting the central to disconnect itself and stop it scanning/connecting for a while.
The relevant pages of the library are here and here
Hope that helps,
Matt
matt_lee_smith:
Hello jerteach.
Hope that helps,
Matt
Thanks @Matt all my attempts are at this Github
I am very close to getting my web page that shows many nearby BLE connections working. This might be the last step.
Been thinking about this quote by Pert about the Nano 33 IoT running Wifi and BLE at the same time:
pert:
GitHub - agdl/ArduinoCore-samd at coexistance
GitHub - agdl/ArduinoBLE at coexistance
I am almost finished my Wifi webpage BLE data collection project, needs a few minor changes to better collect BLE, but I was thinking about Pert's post.
Any word on how long it might take until this branch (labelled coexistance) gets merged with the main branch? Anyone been working on it and any feedback about it? Anyone tried to install it on the Nano33 IoT. The last 2 links look easy just installing a new board and the new ArduinoBLE package. I am a bit concerned about the steps to install the new firmware, not sure how difficult that is to do.
My project would be much better if the Wifi could stay running while every 5 minutes checking all the nearby BLE devices.
I've been trying to do something very similar by using WiFi and BLE on the IoT. I've been poking at it for a while. I think I finally have a simple PoC that switches back and forth reliably between WiFi and BLE.
What I found is that you must call BLE.disconnect() and BLE.end() before switching to WiFi. Without the call to .disconnect() it sort of works but the various characteristics were double and tripling in length. It would appear that the call to .disconnect() is necessary to fully clean things up before starting the Wifi. Reviewing the source, there are calls in .disconnect() that are made that are not made in .end().
Sharing in case others find this useful: GitHub - tjpetz/SetWifiPoC: Simple Arduino program for the Nano 33 IoT board to set the WiFi configuration using BLE. Also demonstrates an approach to switch between BLE and WiFi.
