I need to switch the high side of 16 devices. I think a transistor setup is the best due to size requirements but I'm not sure...
At the moment I'm thinking a NPN transistor driving a PNP would be my best bet.
Im thinking:
NPN: MMBT5551
PNP: BDW47
In this circuit:
with:
Resistor 1: 2.2k / 0.250w
Resistor 2: 680ohm / 0.250w
Resistor 3: 6.8kOhms / 0.250w
Resistor 4: 22kOhm / 0.250w
I'm very new to the theory side of selecting components such as resistors and diodes so have no idea if these are the correct resistors to use.
I would like to make it so I could reuse it with different voltages i.e have the outputs the same as the Vin.
I have a input side of things sorted.
I think I will have a problem with changing the supply voltage because of the resistor values.
Do you think I have selected the correct transistor setup? And what problems will I encounter if I change the supply voltage and how would I over come them?
Thanks in advance!
