Syntax questions
Hi
I have variables such as
int var1;
int var2 ;
int var3;
and in the code I have a for loop which is
for(int i = 1; i <= 3; i++) {
Serial.println (var(i));
Dosen't work as it was just a guess?
So my question is how do I code it so that it will print the next variable as the counter increases.
Thanks in advance
Sounds like you need to use an array:
int a[3];
void setup ()
  a[0] = 23;
  a[1] = 45;
  a[2] = 76;
  Serial.begin (9600);
void loop ()
  int i;
  for (i = 0; i < 3; i++) {
    Serial.println (a[i]);
