#include <ESP8266WiFi.h>
#include <espnow.h>
#include <Bounce2.h> // Bibliothèque pour le bouton avec debounce
#define BUTTON_PIN 2
// -------- LED et bâtiments --------
#define BAT_1 4
#define BAT_2 16
#define BAT_3 17
#define BAT_4 5
#define LED_PIN 15
uint8_t tab_led[5] = { BAT_1, BAT_2, BAT_3, BAT_4, LED_PIN };
// -------- Adresses des récepteurs --------
uint8_t macRecv[][6] = {
{ 0x48, 0x55, 0x19, 0x12, 0x70, 0x0F },
{ 0x3C, 0x71, 0xBF, 0x20, 0xF4, 0xDA },
{ 0xA4, 0xF0, 0x0F, 0x72, 0xBE, 0xE4 },
{ 0xA4, 0xF0, 0x0F, 0x26, 0xB7, 0xB3 },
uint8_t Stateconnect;
uint8_t numberRecv = 4;
uint8_t Adress;
unsigned long ReponseTime1 = 0;
unsigned long ReponseTime2 = 0;
unsigned long ReponseTime3 = 0;
unsigned long ReponseTime4 = 0;
unsigned long timeout = 1000;
unsigned long lastPing = 0;
// -------- Tableau bâtiments et RSSI --------
uint8_t BATIMENT[4] = { BAT_1, BAT_2, BAT_3, BAT_4 };
uint8_t TIME[4] = { 0, 0, 0, 0 };
int8_t TABRSSI[4] = {};
// -------- Structures --------
typedef struct {
uint8_t type; // 1 = PING, 2 = COMMANDE
int data;
} msg_t;
typedef struct {
signed int rssi;
} rssi_msg_t;
msg_t msg;
rssi_msg_t rssiMsg1 = { -100 };
rssi_msg_t rssiMsg2 = { -100 };
rssi_msg_t rssiMsg3 = { -100 };
rssi_msg_t rssiMsg4 = { -100 };
// -------- Bounce2 pour le bouton --------
Bounce bouton = Bounce();
// -------- Réception ESP-NOW --------
void OnDataRecv(uint8_t *mac, uint8_t *data, uint8_t len) {
if (len == sizeof(rssi_msg_t)) {
rssi_msg_t temp;
memcpy(&temp, data, sizeof(temp));
if (memcmp(mac, macRecv[0], 6) == 0) {
rssiMsg1 = temp;
ReponseTime1 = millis();
} else if (memcmp(mac, macRecv[1], 6) == 0) {
rssiMsg2 = temp;
ReponseTime2 = millis();
} else if (memcmp(mac, macRecv[2], 6) == 0) {
rssiMsg3 = temp;
ReponseTime3 = millis();
} else if (memcmp(mac, macRecv[3], 6) == 0) {
rssiMsg4 = temp;
ReponseTime4 = millis();
// -------- Setup --------
// Configuration du bouton avec debounce
bouton.attach(BUTTON_PIN, INPUT_PULLUP);
bouton.interval(50);
for (int i = 0; i < 5; i++) pinMode(tab_led[i], OUTPUT);
WiFi.mode(WIFI_STA);
WiFi.setOutputPower(19.5);
if (esp_now_init() != 0) {
Serial.println("Erreur ESP-NOW !");
return;
esp_now_register_recv_cb(OnDataRecv);
esp_now_set_self_role(ESP_NOW_ROLE_COMBO);
// Ajout des peers
esp_now_add_peer(macRecv[0], ESP_NOW_ROLE_COMBO, 1, NULL, 0);
esp_now_add_peer(macRecv[1], ESP_NOW_ROLE_COMBO, 1, NULL, 0);
esp_now_add_peer(macRecv[2], ESP_NOW_ROLE_COMBO, 1, NULL, 0);
esp_now_add_peer(macRecv[3], ESP_NOW_ROLE_COMBO, 1, NULL, 0);
Serial.println("Emetteur prêt !");
// -------- Loop --------
bouton.update();
TABRSSI[0] = rssiMsg1.rssi;
TABRSSI[1] = rssiMsg2.rssi;
TABRSSI[2] = rssiMsg3.rssi;
TABRSSI[3] = rssiMsg4.rssi;
if (millis() - lastPing > timeout) {
Serial.print("Adresse de l'emetteur: ");
Serial.println(WiFi.macAddress());
PINGSEND();
CONNECTION();
COMMANDE(Stateconnect, macRecv[Adress]);
lastPing = millis();
// -------- Envoi Ping --------
void PINGSEND() {
msg.type = 1;
msg.data = 0;
esp_now_send(macRecv[0], (uint8_t *)&msg, sizeof(msg));
esp_now_send(macRecv[1], (uint8_t *)&msg, sizeof(msg));
esp_now_send(macRecv[2], (uint8_t *)&msg, sizeof(msg));
esp_now_send(macRecv[3], (uint8_t *)&msg, sizeof(msg));
// -------- Commande --------
void COMMANDE(uint8_t Etat, uint8_t *Adresse) {
if (Etat) {
if (bouton.fell()) {
msg.type = 2;
msg.data = 1;
Serial.println("
Commande envoyée au RECEPTEUR");
esp_now_send(Adresse, (uint8_t *)&msg, sizeof(msg));
digitalWrite(BATIMENT[Etat - 1], HIGH);
if (bouton.rose()) {
digitalWrite(BATIMENT[Etat - 1], LOW);
// -------- Connexion et RSSI --------
void CONNECTION() {
TIME[0] = ReponseTime1;
TIME[1] = ReponseTime2;
TIME[2] = ReponseTime3;
TIME[3] = ReponseTime4;
if (millis() - TIME[0] > timeout) rssiMsg1.rssi = -110;
if (millis() - TIME[1] > timeout) rssiMsg2.rssi = -110;
if (millis() - TIME[2] > timeout) rssiMsg3.rssi = -110;
if (millis() - TIME[3] > timeout) rssiMsg4.rssi = -110;
Serial.println("-------------------------");
Serial.print("RSSI Recv1 : "); Serial.println(rssiMsg1.rssi);
Serial.print("RSSI Recv2 : "); Serial.println(rssiMsg2.rssi);
Serial.print("RSSI Recv3 : "); Serial.println(rssiMsg3.rssi);
Serial.print("RSSI Recv4 : "); Serial.println(rssiMsg4.rssi);
if (rssiMsg1.rssi > rssiMsg2.rssi && rssiMsg1.rssi > rssiMsg3.rssi && rssiMsg1.rssi > rssiMsg4.rssi && rssiMsg1.rssi > -90) {
digitalWrite(LED_PIN, HIGH);
Stateconnect = 1;
Adress = 0;
} else if (rssiMsg2.rssi > rssiMsg1.rssi && rssiMsg2.rssi > rssiMsg3.rssi && rssiMsg2.rssi > rssiMsg4.rssi && rssiMsg2.rssi > -90) {
Stateconnect = 2;
Adress = 1;
} else if (rssiMsg3.rssi > rssiMsg1.rssi && rssiMsg3.rssi > rssiMsg2.rssi && rssiMsg3.rssi > rssiMsg4.rssi && rssiMsg3.rssi > -90) {
Stateconnect = 3;
Adress = 2;
} else if (rssiMsg4.rssi > rssiMsg1.rssi && rssiMsg4.rssi > rssiMsg2.rssi && rssiMsg4.rssi > rssiMsg3.rssi && rssiMsg4.rssi > -90) {
Stateconnect = 4;
Adress = 3;
digitalWrite(LED_PIN, LOW);
Stateconnect = 0;
recepteur>>>
#include "user_interface.h"
#define LED_PIN 2
volatile int RSSI_entrant = -127;
// Structure du paquet promiscuous
typedef struct {
signed rssi : 8;
unsigned rate : 5;
unsigned : 3;
unsigned sig_mode : 2;
unsigned : 1;
unsigned mcs : 7;
unsigned cwb : 1;
unsigned : 8;
unsigned smoothing : 1;
unsigned not_sounding : 1;
unsigned : 1;
unsigned aggregation : 1;
unsigned stbc : 2;
unsigned fec_coding : 1;
unsigned sgi : 1;
unsigned noise_floor : 8;
unsigned ampdu_cnt : 8;
unsigned channel : 4;
unsigned : 12;
} wifi_pkt_rx_ctrl_t;
typedef struct {
wifi_pkt_rx_ctrl_t rx_ctrl;
uint8_t payload[0];
} wifi_promiscuous_pkt_t;
typedef struct {
unsigned frame_ctrl : 16;
unsigned duration_id : 16;
uint8_t addr1[6];
uint8_t addr2[6];
uint8_t addr3[6];
unsigned sequence_ctrl : 16;
unsigned category : 8;
uint8_t addr4[6];
} wifi_ieee80211_mac_hdr_t;
typedef struct {
wifi_ieee80211_mac_hdr_t hdr;
uint8_t payload[0];
} wifi_ieee80211_packet_t;
// Structure du message envoyé
typedef struct {
int data; // 0 ou 1
} msg_t;
uint8_t ESP_OUI[] = { 0x18, 0xFE, 0x34 };
uint8_t emetteur_A[] = { 0x48, 0x55, 0x19, 0x12, 0x45, 0x86 };
void promiscuous_rx_cb(uint8_t *buf, uint16_t len) {
const wifi_promiscuous_pkt_t *package = (wifi_promiscuous_pkt_t *)buf;
const wifi_ieee80211_packet_t *pk = (wifi_ieee80211_packet_t *)package->payload;
const wifi_ieee80211_mac_hdr_t *hdr = &pk->hdr;
static const uint8_t ACTION_SUBTYPE = 0xd0; // ESP-NOW
// Vérification du type de paquet et OUI
if ((ACTION_SUBTYPE == (hdr->frame_ctrl & 0xFF)) && (memcmp(hdr->addr4, ESP_OUI, 3) == 0)) {
// Chercher l'OUI dans le payload pour trouver le vrai début
int payload_offset = -1;
for (int i = 0; i < len - 3; i++) {
if (pk->payload[i] == ESP_OUI[0] && pk->payload[i + 1] == ESP_OUI[1] && pk->payload[i + 2] == ESP_OUI[2]) {
payload_offset = i + 3;
if (payload_offset > 0 && len > payload_offset + sizeof(msg_t)) {
msg_t msg;
memcpy(&msg, pk->payload + payload_offset, sizeof(msg));
RSSI_entrant = package->rx_ctrl.rssi;
// Afficher MAC émetteur
Serial.print("MAC émetteur: ");
for (int i = 0; i < 6; i++) {
if (i > 0) Serial.print(":");
Serial.print(hdr->addr2[i], HEX);
Serial.print(" | RSSI entrant : ");
Serial.print(RSSI_entrant);
Serial.print(" | Type: ");
Serial.print(msg.type);
Serial.print(" | Data: ");
Serial.println(msg.data);
Serial.println("---------------------");
// Afficher la trame complète brute
Serial.print("TRAME: ");
for (int i = 0; i < len; i++) {
if (i > 0) Serial.print(" "); // espace entre les octets
Serial.print(buf[i], HEX);
wifi_set_channel(1);
wifi_promiscuous_enable(1);
wifi_set_promiscuous_rx_cb(promiscuous_rx_cb);
// Exemple simple de calcul du RSSI moyen
static int somme = 0;
static int compt = 0;
somme += RSSI_entrant;
if (++compt >= 10) {
int RSSI_moyen = somme / compt;
Serial.print("RSSI moyen: ");
Serial.println(RSSI_moyen);
somme = 0;
compt = 0;
