Take out a potentiometer
hi guys
I got this code from internet and it works well for my puppet ; anyway i'd like to take out the potentiometer "eyelid contro" which i don't need.
could you help me on the code pls ?
 Controlling a servo position using a potentiometer (variable resistor)
 by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
 modified on 8 Nov 2013
 by Scott Fitzgerald
 http://www.arduino.cc/en/Tutorial/Knob
#include <Servo.h>
Servo x;  // create servo object to control a servo
Servo y;
Servo b;
Servo t;
int xpotpin = 1;  // analog pin used to connect the potentiometer
int ypotpin = 0;
int opin = 2;
int bpin = 10;
int xval;    // variable to read the value from the analog pin
int yval;
int bval;
int tval;
int xxval;
int yyval;
int oval;
int blinkval;
  pinMode(bpin, INPUT);
  x.attach(8);  // attaches the servo on pin 9 to the servo object
  y.attach(9);
  b.attach(6);
  t.attach(7);
  blinkval = digitalRead(bpin);
  oval = analogRead(opin);
  xval = analogRead(xpotpin);            // reads the value of the potentiometer (value between 0 and 1023)
  yval = analogRead(ypotpin);
  oval = map(oval, 0, 1023, -10, 10);
  xxval = map(xval, 0, 1023, 0, 80);     // scale it to use it with the servo (value between 0 and 180)
  yyval = map(yval, 0, 1023, 0, 80);
  if (blinkval == 0){
    bval = 50;
    tval = 50;
    b.write(bval);
    t.write(tval);
  bval =  map(yval, 0, 1023, 110, 150);
  tval =  map(yval, 0, 1023, 120, 90 );
  b.write(bval + oval);
  t.write(tval + oval);
  x.write(xxval);                  // sets the servo position according to the scaled value
  y.write(yyval);
  delay(5);                           // waits for the servo to get there
There are at least 3 pots and 4 servos in that code. None of them have any comments saying what they control so it's anyone's guess what "eyelid contro" is associated with.
Steve
Looks like the eyelid control pot (called opin) is connected to A2.
