i have connected a microphone with arduino uno and i am using uspeech library, As i speak in the mic the data appears in the form of alphabets and when i am quite there will be no data. I want to take the data in the array as soon as i start speaking and when i speak again the array should contain the new series of data.The data on the serial monitor is in the form of:
o
o
o
a
e
e
o
o
e
e
e
e
e
e
Please tell me how to do that thank you in advance
Thank you for your reply.Yes the microphone is connected with the microphone and a bluetooth device(hc-05).As i speak in the microphone the data describe above appears on the serial monitor then i send this data from one arduino to other using hc05 but on the other monitor instead of the same data i want to see the count of alphabets that appear everytime i speak in the microphone like 6 6 2 fro above example.
Actually my main task is to count how many o's (alphabet) occurs whenever i speak for example when i say one in the mic i got
o
o
e
e
so it means 2 o's
then again i said two in the microphone i got
e
e
e
it means 0 o's
but this work have to be done continuously on the sender side the serial monitor will continuously show the alphabets and on the receiver side number of o's for that word will be shown
If this was my project I would be very tempted to do the counting on the sending Arduino and then when the character changes just send the character and the count.
Thank you for your time.May be i am not clear in defining my object. I have to count the no of o's in between the white spaces ( blank lines). Will it do that ? i man as soon as i start speaking it will count o's and when there is silence it won't count and then again if i speak it will count and so on?
so the output on sender/receiver should be
SENDER ////// receiver
o
o
e
e
2
Aiman-Farid:
I was certainly unclear. I thought you wanted to count the number of times each character appeared.
I still think you should do the counting on the sending Arduino. But you will need code to identify when a "white space" occurs. You can use millis() to measure the interval between characters. If the interval exceeds a preset value you have "white space".
I don't know exactly how your phoneme library works so I can't make specific suggestions. The general idea is to save the value of millis() every time a character is received and use something like this to test for an interval
if (millis() - lastSavedMillis >= intervalMillis) {
// we have white space
Now, as @Delta_G has said, it's time for you to do some work.
...R
PS, if you need to measure time between characters I reckon it is essential to do that on the Arduino that is calling the phoneme library to ensure you eliminate the risk of other timing glitches causing confusion.
