Teensy 4.0 + Audioboard + neotrellis
Hallo, ich bastel gerade an einem Sample-Player mit einem Teensy 4.0 mit Audioboard und einem Adafruit Neotrellis.
Das läuchten der Tasten funktioniert super.
Ich bekomme es aber nicht hin mir den gedrückten button ausgeben zu lassen um damit einen Suond zu triggern.
#include <Audio.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <SerialFlash.h>
#include "Adafruit_NeoTrellis.h"
// WAV files converted to code by wav2sketch
#include "AudioSampleSnare.h"        // http://www.freesound.org/people/KEVOY/sounds/82583/
#include "AudioSampleTomtom.h"       // http://www.freesound.org/people/zgump/sounds/86334/
#include "AudioSampleHihat.h"        // http://www.freesound.org/people/mhc/sounds/102790/
#include "AudioSampleKick.h"         // http://www.freesound.org/people/DWSD/sounds/171104/
#include "AudioSampleGong.h"         // http://www.freesound.org/people/juskiddink/sounds/86773/
#include "AudioSampleCashregister.h" // http://www.freesound.org/people/kiddpark/sounds/201159/
// Create the Audio components.  These should be created in the
// order data flows, inputs/sources -> processing -> outputs
AudioPlayMemory    sound0;
AudioPlayMemory    sound1;  // six memory players, so we can play
AudioPlayMemory    sound2;  // all six sounds simultaneously
AudioPlayMemory    sound3;
AudioPlayMemory    sound4;
AudioPlayMemory    sound5;
AudioMixer4        mix1;    // two 4-channel mixers are needed in
AudioMixer4        mix2;    // tandem to combine 6 audio sources
AudioOutputI2S     headphones;
AudioOutputAnalog  dac;     // play to both I2S audio board and on-chip DAC
// Create Audio connections between the components
AudioConnection c1(sound0, 0, mix1, 0);
AudioConnection c2(sound1, 0, mix1, 1);
AudioConnection c3(sound2, 0, mix1, 2);
AudioConnection c4(sound3, 0, mix1, 3);
AudioConnection c5(mix1, 0, mix2, 0);   // output of mix1 into 1st input on mix2
AudioConnection c6(sound4, 0, mix2, 1);
AudioConnection c7(sound5, 0, mix2, 2);
AudioConnection c8(mix2, 0, headphones, 0);
AudioConnection c9(mix2, 0, headphones, 1);
AudioConnection c10(mix2, 0, dac, 0);
// Create an object to control the audio shield.
AudioControlSGTL5000 audioShield;
// NeoTrellis
Adafruit_NeoTrellis trellis;
//define a callback for key presses
TrellisCallback blink(keyEvent evt){
  // Check is the pad pressed?
  if (evt.bit.EDGE == SEESAW_KEYPAD_EDGE_RISING) {
    //Serial.println(evt.bit.NUM);
    trellis.pixels.setPixelColor(evt.bit.NUM, Wheel(map(evt.bit.NUM, 0, trellis.pixels.numPixels(), 0, 255))); //on rising
  } else if (evt.bit.EDGE == SEESAW_KEYPAD_EDGE_FALLING) {
  // or is the pad released?
    trellis.pixels.setPixelColor(evt.bit.NUM, 0); //off falling
  // Turn on/off the neopixels!
  trellis.pixels.show();
  return 0;
  //NeouTrellis setup
  //while(!Serial);
  if (!trellis.begin()) {
    Serial.println("Could not start trellis, check wiring?");
    while(1);
    Serial.println("NeoPixel Trellis started");
  //activate all keys and set callbacks
  for(int i=0; i<NEO_TRELLIS_NUM_KEYS; i++){
    trellis.activateKey(i, SEESAW_KEYPAD_EDGE_RISING);
    trellis.activateKey(i, SEESAW_KEYPAD_EDGE_FALLING);
    trellis.registerCallback(i, blink);
  //do a little animation to show we're on
  for (uint16_t i=0; i<trellis.pixels.numPixels(); i++) {
    trellis.pixels.setPixelColor(i, Wheel(map(i, 0, trellis.pixels.numPixels(), 0, 255)));
    delay(50);
    trellis.pixels.setPixelColor(i, 0x000000);
    delay(50);
  // Audio connections require memory to work.  For more
  // detailed information, see the MemoryAndCpuUsage example
  AudioMemory(10);
  // turn on the output
  audioShield.enable();
  audioShield.volume(0.5);
  // by default the Teensy 3.1 DAC uses 3.3Vp-p output
  // if your 3.3V power has noise, switching to the
  // internal 1.2V reference can give you a clean signal
  //dac.analogReference(INTERNAL);
  // reduce the gain on mixer channels, so more than 1
  // sound can play simultaneously without clipping
  mix1.gain(0, 0.4);
  mix1.gain(1, 0.4);
  mix1.gain(2, 0.4);
  mix1.gain(3, 0.4);
  mix2.gain(1, 0.4);
  mix2.gain(2, 0.4);
  trellis.read();  // interrupt management does all the work! :)
  delay(20); //the trellis has a resolution of around 60hz
  // When the buttons are pressed, just start a sound playing.
  // The audio library will play each sound through the mixers
  // so any combination can play simultaneously.
//  if (button0.fallingEdge()) {
//    sound0.play(AudioSampleSnare);
//  if (button1.fallingEdge()) {
//    sound1.play(AudioSampleTomtom);
//  if (button2.fallingEdge()) {
//    sound2.play(AudioSampleHihat);
//  if (button3.fallingEdge()) {
//    sound3.play(AudioSampleKick);
//  if (button4.fallingEdge()) {
//    // comment this line to work with Teensy 3.0.
//    // the Gong sound is very long, too much for 3.0's memory
//    sound4.play(AudioSampleGong);
//  if (button5.fallingEdge()) {
//    sound5.play(AudioSampleCashregister);
// Input a value 0 to 255 to get a color value.
// The colors are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return trellis.pixels.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return trellis.pixels.Color(255 - WheelPos * 3, 0, WheelPos * 3);
   WheelPos -= 170;
   return trellis.pixels.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  return 0;
unkommentiere mal die Zeile mit dem Serial.print in der der Callback-Funktion.. dort wird evt.bit.NUM ausgegeben. Damit kann man wunderbar weiterarbeiten :wink:
Danke für den Tip!
Hab jetzt ne Variable dafür angelegt und jetzt funktionierts.
// NeoTrellis
    bang = evt.bit.NUM;
  return 0;
  //NeouTrellis setup
  //while(!Serial);
    while(1);
    delay(50);
    delay(50);
  AudioMemory(10);
  mix1.gain(0, 0.4);
  mix1.gain(1, 0.4);
  mix1.gain(2, 0.4);
  mix1.gain(3, 0.4);
  mix2.gain(1, 0.4);
  mix2.gain(2, 0.4);
  if (bang == 0) {
  if (bang == 1) {
  if (bang == 2) {
  if (bang == 4) {
  if (bang == 5) {
  if (bang == 6) {
Bloß jetzt wird der Sound so lange getriggert bis ich einen anderen button betätige.
in der gleichen Callback-Funktion wird auch erfasst, welche Taste losgelassen wurde:
Dein "bang" sollte dort auf einen Wert gesetzt werden, der in deinem Loop keinen Sound abspielt.
