Temp, Humidity CO2 COZIR sensor.
Does anyone have any experience in using the COZIR range of sensors with any arduino / .net based platform?.
http://www.cozir.com/
Regards
Hi!
I dont...
I use 2 "traditional" CO2 sensors...
they use 500mA and 700mA peak...
Where can i get those low power thingies?
Thx.
Bye
You need to get in touch with cozir directly i think, I have the data sheet. The CO2 values are via serial so I know you'd need to use softserial. The optional temp/rh values are digital output, ill be ordering soon, i just wanted to know if anyone had used these before.
Hello it wanted to know since I can do in order that arduino was detecting conductivity by means of: two separated cables that when it rains the rain transmits the current to another point. But first not which pines connects neither both cables nor that software to write in order that if it detects conductivity for example it ignites a led during 20 seconds and if it does not detect that alone my project is ignited during 40 seconds actually rightly it treats as this example
