Ok ive found this example sketch for a temperature gauge that uses the same sensor as the one im using but the motor and driver are different to the ones thats im going to use also this sketch uses a micro switch to set a reference position for the pointer/motor but I want to run the pointer down to a mechanical stop and make the motor skip steps on prupose by telling the motor to move more steps than possible and once its finished trying to move passed the stop (needle should be at minimum scale) then set the reference point for the motor.
any help editing this sketch?
#include "Arduino.h"
// The preferred stepper motor driver
#include <AccelStepper.h>
#include <OneWire.h>
// Easy-to-use OneWire DS18B20 temperature library
#include <DallasTemperature.h>
// We want half step (not full step) control of the stepper
#define HALFSTEP 8
// Motor pin definitions
// Blue - 28BYJ48 pin 1
// Pink - 28BYJ48 pin 2
// Yellow - 28BYJ48 pin 3
// Orange - 28BYJ48 pin 4
// Red - 28BYJ48 pin 5 (VCC)
#define motorPin1 3 // IN1 on the ULN2003 driver 1
#define motorPin2 4 // IN2 on the ULN2003 driver 1
#define motorPin3 5 // IN3 on the ULN2003 driver 1
#define motorPin4 6 // IN4 on the ULN2003 driver 1
#define sensorPin 2 // Stepper microswitch sensor
#define tempPin 12 // DS18B20 Temperature sensor
// Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
AccelStepper stepMotor(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
// Initialise OneWire comms
OneWire oneWire(tempPin);
// DallasTemp object needs that OneWire setup
DallasTemperature tempSensor(&oneWire);
// Temperature capture
int currTemp = 0;
int oldTemp = 0;
// SETUP SETUP SETUP SETUP SETUP SETUP SETUP
// Start the temperature sensor
tempSensor.begin();
// Set some constraints on the stepper motor
stepMotor.setMaxSpeed(500.0);
stepMotor.setAcceleration(100.0);
stepMotor.setSpeed(50);
// Complete anticlockwise circle until we find the reference point
stepMotor.moveTo(4096 + 100); //4096
// This is the microswitch reference point
pinMode(sensorPin, INPUT_PULLUP);
// Power to the motor is ON
stepMotor.enableOutputs();
Serial.println("Moving stepper to known reference point");
//If we are already STOPPED then move off the mark and re-reference
while (digitalRead(sensorPin) == LOW) {
stepMotor.run();
// Now continue to turn until we reach our reference point
while (!digitalRead(sensorPin) == LOW) {
stepMotor.run();
// Stop when reference point reached and set the zero position
stepMotor.stop();
stepMotor.setCurrentPosition(0);
Serial.println("Stepper motor at reference point.");
// Set the stepper motor power off
stepMotor.disableOutputs();
long mapTempToPos(long newTemp);
void doPointerMove();
// LOOP LOOP LOOP LOOP LOOP LOOP LOOP LOOP
// 1. Get the temperature and remember its value
// 2. Move pointer to temperature value via stepper
// 3. Repeat if temperature changes (whole degrees only)
// 4. Allow serial monitor input if connected to IDE
// Get temperature reading in whole degrees rounded to nearest value
tempSensor.requestTemperatures();
currTemp = (int) round(tempSensor.getTempCByIndex(0));
// Has temperature changed (significantly - i.e. whole degrees)
if (currTemp != oldTemp) {
doPointerMove();
// Allow serial monitor input (for testing!) If you put in
// non-numeric values the world as we know it will end.
char manualTemp[3];
if (Serial.available()){
// Read all NUMERIC characters until new line
Serial.println("Manual entry detected");
int charCnt = Serial.readBytesUntil('\n', manualTemp, 3);
manualTemp[charCnt] = '\0';
// Overwrite the current temperature sensor value
currTemp = atoi(manualTemp);
doPointerMove();
// Loop delay
delay(5000);
// POINTER MOVE POINTER MOVE POINTER MOVE POINTER MOVE
void doPointerMove() {
Serial.println("Temperature Change Detected");
Serial.print("Temperature: ");
Serial.print(oldTemp);
Serial.print(" vs. ");
Serial.println(currTemp);
stepMotor.moveTo(mapTempToPos(currTemp));
// turn on stepper motor
Serial.println("Stepper Motor ON");
stepMotor.run();
Serial.println("Stepper moving to new position");
while (stepMotor.isRunning()) {
stepMotor.run();
// turn off stepper motor
Serial.println("Stepper Motor OFF");
// Remember current temperature
oldTemp = currTemp;
// MAP TEMP TO SCALE MAP TEMP TO SCALE MAP TEMP TO SCALE
long mapTempToPos(long newTemp) {
// Convert the temperature to the stepper 90-degree range
// Note that if you change this the pointer will have a different range
long mappedTemp = map(newTemp - 5, -5, 30, 0, 1024);
// Debugging messages
Serial.print("Input temperature: ");
Serial.print(newTemp);
Serial.print("\tMapped to scale value: ");
Serial.println(mappedTemp);
// All done
return -mappedTemp;
