Textfinder library
I have used the example given in the textfinder library and changed it slightly but when ever I send a 1 it does not work ??
#include <TextFinder.h>
TextFinder  finder(Serial);
const int NUMBER_OF_FIELDS = 3; // how many comma seperated fields we expect
int values[NUMBER_OF_FIELDS];   // array holding values for all the fields
  Serial.begin(115200); // Initialize serial port to send and receive at 115200 baud
  // Set up pins
  pinMode(11, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(9, OUTPUT);
  if(Serial.available())
    getData();
    int lights = values[2];
    if(lights == '1')
      digitalWrite(9, HIGH);
      digitalWrite(9, LOW);
    analogWrite(11, values[0]);
    analogWrite(10, values[1]);
  void getData()
      int fieldIndex = 0; // the current field being received
      finder.find("I");
      while(fieldIndex < NUMBER_OF_FIELDS)
        values[fieldIndex++] = finder.getValue();
      //for(fieldIndex=0; fieldIndex < NUMBER_OF_FIELDS; fieldIndex++)
      //Serial.println(values[fieldIndex]);
When I send:
I 255,255,1 /n
It does not work.
Thanks for any help
So, you commented out the code that actually prints the data obtained. Why was that?
Because I don't need it to print the data. I just need to use it
Then, you don't have a problem?
Just tried sending
I 255,255,1 /n
with this code
  // Set up pins
  pinMode(9, OUTPUT);
    getData();
    Serial.print(values[2]);
    if(lights > 0)
  void getData()
      finder.find("I");
But on the serial monitor it says 5 and not 1 ?
What would these show, if they weren't commented out?
Also, try sending something like:
I 123, 456, 7
Perhaps a clue will present itself.
Thanks
I have now realised its my program I'm using to send the Arduino data that's wrong.
Thanks for the help
My program was sending a number with a decimal place and the textfinder library thought it was the end of the number.
