TFT Graphics - Scrolling ruler scale tied to Enc position
No. It was not.
@DucatiboyStu the Adafruit_GFX library gives you access to a framebuffer called GFXcanvas that will give your animations a smooth and virtually flicker free scroll.
Your code can be adapted to the GFXcanvas quite easily, the example I posted uses a canvas framebuffer. Google Adafruit GFXcanvas and check it out, if you have future projects that use displays you wont regret it.
The rest of the code is irrelevant. I am sure you could make it work if you really wanted to :grinning_face:
Its going to run in 2 modes, 1 for position, and the other for feed ratebut I get what you mean
I will prob re-do it using TFT-eSpi lib
Not if it is written poorly.
Well, you can always re-write it :smiling_face_with_sunglasses:
Which rotary encoder library are you using? I can't seem to find the correct one to compile the code.
What type of Arduino?
Not sure how I found it, but works very well with the ky-040
So I am onto v2 now. I have added a second mode to show feed rate. This uses a simple button to change modes.
I also decided to have ruler go the full width of the screen. I looks better and is more funcional
Also changed the way the ticks are drawn. Instead overwriting the old tick, I redraw the background then the new ticks as required in the “if” loop
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ST7796S.h>
#include <RotaryEncoder.h>
#include <Fonts/FreeSansBoldOblique9pt7b.h>
#include <Fonts/FreeSansBoldOblique12pt7b.h>
#define display_CS 10
#define display_RST 8
#define display_DC 9
#define display_MOSI 11
#define display_CLK 13
#define feedzLed 1
#define BLACK 0x0000
#define GRAY 0x8410  //lGRAY = light gray, GREY = dark grey  16bit colour
#define GREY 0x632C
#define WHITE 0xFFFF
#define RED 0xF800
#define ORANGE 0xFCA0
#define YELLOW 0xFFE0
#define DENIM 0x4CBA
#define GREEN 0x07E0
#define DARKGREEN 0x2BE3
#define LIGHTGREEN 0x97F0
#define CYAN 0x07FF
#define AQUA 0x04FF
#define BLUE 0x001F
#define MAGENTA 0xF81F
#define PINK 0xF69A
#define GREYGREEN 0x2984
Adafruit_ST7796S display(display_CS, display_DC, display_MOSI, display_CLK, display_RST);
RotaryEncoder Rotary(&RotaryChanged, 2, 3, 28);  // Pins 2 (DT), 3 (CLK), 28 (SW) - 28 is just a null number as the (SW) is not used
int mode = 0;
int feedzButt = 0;
int encCounter = 0;
long posn = -999;
long newposn;
int buttonState;
int lastButtonState = HIGH;
long lastDebounceTime = 0;
long debounceDelay = 10;
char buffermeas[10];
char bufferimp[10];
char bufferMMS[10];
char bufferRPM[10];
void RotaryChanged() {
  const unsigned int state = Rotary.GetState();
  if (state & DIR_CW)
    encCounter++;
  if (state & DIR_CCW)
    encCounter--;
  Serial.print(("Oih !"));
  display.init(74, 284, 0, 0, ST7796S_BGR);  //screen size 74 x 284
  display.invertDisplay(1);
  display.fillScreen(BLACK);
  display.setRotation(1);
  display.setTextColor(WHITE);
  display.setCursor(80, 100);
  display.setTextSize(1);
  display.println("T.I.S.M");  // mum, we are serious.   google it
  pinMode(feedzButt, INPUT_PULLUP);
  display.fillScreen(GRAY);
void position() {
  display.fillTriangle(140, 15, 150, 5, 130, 5, RED);
  display.fillTriangle(140, 30, 150, 40, 130, 40, RED);
  display.drawRoundRect(0, 1, 284, 44, 10, RED);
  display.drawRoundRect(2, 2, 282, 42, 10, RED);
  display.drawRoundRect(3, 4, 279, 38, 10, RED);
  float measurment = (encCounter / 200.000);
  float imperial = (measurment / 2.5400);
  dtostrf(measurment, 6, 3, buffermeas);
  dtostrf(imperial, 6, 4, bufferimp);
  newposn = encCounter;  // derived from  rotary encoder
  if (newposn != posn) {
    posn = newposn;
    int16_t startX = (encCounter - 660);  // zero maj posn to triangles
    int16_t startY = 8;
    int16_t numTicks = 200;
    int16_t minTickHeight = 10;
    int16_t medTickHeight = 20;
    int16_t majTickHeight = 30;
    int16_t minTickspacing = 20;
    int16_t medTickspacing = 100;
    int16_t majTickspacing = 200;
    display.fillRoundRect(4, 5, 278, 35, 10, WHITE);
    for (int i = 0; i < numTicks; i++) {
      display.drawFastVLine(startX + (i * minTickspacing), startY + 10, minTickHeight, BLACK);
      display.drawFastVLine(startX + (i * medTickspacing), startY, medTickHeight, BLACK);
      display.drawFastVLine(startX + (i * majTickspacing), startY, majTickHeight, BLACK);
    display.fillRect(0, 45, 280, 40, GRAY);
    display.setTextColor(BLACK);
    display.setFont(&FreeSansBoldOblique12pt7b);
    display.setCursor(70, 65);
    display.print(buffermeas);
    display.setCursor(140, 65);
    display.print("mm");
    display.setCursor(195, 65);
    display.setFont(&FreeSansBoldOblique9pt7b);
    display.print(bufferimp);
    display.setCursor(260, 65);
    display.print("in");
void feedrate() {
  float rpm = (encCounter / 10.00);
  float feed = (rpm / 60.0);
  dtostrf(rpm, 6, 1, bufferRPM);
  dtostrf(feed, 6, 2, bufferMMS);
    posn = newposn;
    display.drawRoundRect(1, 1, 204, 44, 11, RED);
    display.drawRoundRect(3, 2, 201, 42, 10, RED);
    display.drawRoundRect(5, 4, 198, 38, 9, RED);
    display.fillRoundRect(6, 5, 196, 36, 9, BLUE);
    display.setTextColor(RED);
    display.setCursor(210, 30);
    display.print("FEED");
    display.setCursor(30, 30);
    display.print(bufferMMS);
    display.setCursor(100, 30);
    display.print("mm/s");
    display.setCursor(30, 68);
    display.print(bufferRPM);
    display.setCursor(100, 68);
    display.print("RPM");
  int reading = digitalRead(feedzButt);
  if (reading != lastButtonState) {
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    if (reading != buttonState) {
      buttonState = reading;
      if (buttonState == LOW) {
        mode++;
        if (mode > 1) {  // Change to the last mode number you want
          mode = 0;
        Serial.print("Mode changed to: ");
        Serial.println(mode);
  lastButtonState = reading;
  switch (mode) {
    case 0:
      position();
    case 1:
      feedrate();
I may have missed where you mentioned it, what type arduino are you using?
Is there a reason you are using software SPI for the display? This runs much slower than hardware SPI?
You might want to set the Arduino IDE preferences to show all warning, both versions of your code have a similar problem:
/home/user/Arduino/scrollingRulerScaleV2/scrollingRulerScaleV2.ino:108:41: warning: iteration 164 invokes undefined behavior [-Waggressive-loop-optimizations]
/home/user/Arduino/scrollingRulerScaleV2/scrollingRulerScaleV2.ino:105:23: note: within this loop
Uno/Pro mini/nano/Tennsy 4
I probably could use hardware SPI, but it was already there from recycled code
