TFT Screen 3.5 mcufriend GUI Design For Menu or Back button along with 3-Pages Synch-up each other
Please find given Code as well as my GUI design pic -
  1. If I press Menu button then it will comes to Menu1 Gui and if I press Menu1 Gui button then it will comes to Menu2 Gui button , How can I make Gui for my slide?
  2. How to synch-up my pages to each other using Back Gui button? Like if I press Page2 Back button then it will comes to Page1 and if I press Page1 back button then it will comes to Home screen? How can I do this ?
I am using Arduino Uno board, TFT Gui screen ILI9486 Mcufriend.
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_TFTLCD.h>
#include <TouchScreen.h>
#include<Fonts/FreeSansBold12pt7b.h>
#define LCD_CS A3     // Chip Select goes to Analog 3
#define LCD_CD A2     // Command/Data goes to Analog 2
#define LCD_WR A1     // LCD Write goes to Analog 1
#define LCD_RD A0     // LCD Read goes to Analog 0
#define LCD_RESET A4  // Can alternately just connect to Arduino's reset pin
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
// Define some TFT readable colour codes to human readable names
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define REDBAR_MINX 80
#define GREENBAR_MINX 130
#define BLUEBAR_MINX 180
#define BAR_MINY 30
#define BAR_HEIGHT 250
#define BAR_WIDTH 30
#define YP A2  // must be an analog pin, use "An" notation!
#define XM A3  // must be an analog pin, use "An" notation!
#define YM 8   // can be a digital pin
#define XP 9   // can be a digital pin
// from Kuman_SC3A
#define TS_MINX 85
#define TS_MAXX 925
#define TS_MINY 135
#define TS_MAXY 910
#define MINPRESSURE 10
#define MAXPRESSURE 1000
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
boolean buttonEnabled = true;
int currentPage = 0;
#define PALETTEDEPTH   0     // do not support Palette modes
void setup(void) {
  Serial.print(F("Finding out the type of TFT LCD... ID is : "));
  tft.reset();
  uint16_t identifier = tft.readID();
  Serial.print(identifier, HEX);
  tft.begin(identifier);
  Serial.print(". TFT size is : "); Serial.print(tft.width()); Serial.print(" x "); Serial.println(tft.height());
  tft.setRotation(1);
  tft.invertDisplay(1);                           // UNCOMMENT THIS IF COLORS get inverted
  tft.fillScreen(BLACK);
  Serial.println("Drawing Init Screen...");
  drawInitScreen();
  delay(100);
  Serial.println("Drawing Home or Menu Screen...");
  //drawHomeScreen1();
  drawHomeScreen();
  delay(100);
void drawInitScreen()
  tft.setTextSize(4);
  tft.setTextColor(BLUE);
  tft.setCursor(20, 30);
  tft.print("Welcome ");
  tft.setTextSize(2);
  tft.setTextColor(WHITE);
  tft.setCursor(100, 170);
  tft.print("Smart Lighting System");
  for ( int i = 1; i < 400; i++)
      tft.fillRect(30, 200, i, 15, MAGENTA);
      delay(5);
void drawHomeScreen()
  tft.drawRoundRect(0, 0, 479, 319, 8, BLUE);     //Page border
  tft.setTextSize(2);
  tft.setCursor(120, 30);
  tft.drawLine(100,50,390,50,WHITE);
  tft.print("SMART LIGHTING SYSTEM");
  tft.fillRoundRect(60, 100, 360, 40, 8, RED);
  tft.drawRoundRect(60, 100, 360, 40, 8, WHITE);
  tft.fillRoundRect(60, 180, 360, 40, 8, RED);
  tft.drawRoundRect(60, 180, 360, 40, 8, WHITE);
  tft.setCursor(165, 115);
  tft.print("Menu ");
  tft.setCursor(175, 195);
  tft.print("Home");
  tft.fillRoundRect(60, 250, 360, 40, 8, RED);
  tft.drawRoundRect(60, 250, 360, 40, 8, WHITE);
  tft.setCursor(160, 260);
  tft.print("GROUP-DETAILS");
void loop(void) {
  digitalWrite(13, HIGH);
  TSPoint p = ts.getPoint();
  digitalWrite(13, LOW);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
   if (currentPage == 0){
      if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
          //map(value, fromLow, fromHigh, toLow, toHigh)
          p.x = map( p.x, TS_MINX, TS_MAXX,0,  480 );
          p.y = map( p.y, TS_MINY, TS_MAXY, 0, 320 );
          if(p.x>60 && p.x<400 && p.y>100 && p.y<120 )// The user has pressed inside the red rectangle        // 1 slide
              currentPage = 1;
              // top row buttons
              tft.fillRoundRect(40, 80, 80, 40, 8, RED);
              tft.drawRoundRect(40, 80, 80 , 40, 8, WHITE);
              tft.setTextSize(2);
              tft.setCursor(74, 93);
              tft.print("1");
              tft.fillRoundRect(380, 260, 60, 30, 8, RED);
              tft.drawRoundRect(380, 260, 60 , 30, 8, WHITE);
              tft.setTextSize(2);
              tft.setCursor(395, 268);
              tft.print("<<");
              tft.setTextSize(2);
              tft.setCursor(170, 30);
              tft.print(" ON");
              if(p.x>380 && p.x<435 && p.y>260 && p.y<285 ){
                  currentPage = 0;
                  drawHomeScreen();
      if (currentPage == 2){
          if(p.x>40 && p.x<400 && p.y>80 && p.y<120 )// The user has pressed inside the red rectangle        // 1 slide
              currentPage = 3;
              tft.setTextSize(2);
              tft.print("Timer");
              tft.setTextSize(2);
              tft.print("<<");
              tft.setTextSize(2);
              tft.print(" ON-OFF");
                  currentPage = 1;
                  drawHomeScreen();
  if (currentPage == 1){
          if(p.x>380 && p.x<470 && p.y>260 && p.y<300 ){
              tft.fillRoundRect(380, 260, 60, 30, 8, BLACK);
              tft.setTextSize(2);
              tft.print("<<");
                      currentPage = 0;
                      drawHomeScreen();
  } // end of page 1
What is the problem? What happens and what doesn't?
Okey, lots of anonymous numbers in the code but currentPage is used in a possible way.
i want to design GUI for my TFT Touch screen display. How can i design? please check given image.
Please answer #2. Repeating the initial question tells nothing.
pls read carefully what i written in above quires. i want to design GUI like above img.
One important idea with this forum is of cource to assist members but also that other members can share the advice. Therefore I don't use privat Email communication.
Anyway, I don't understand Your problem.
Are you willing to PAY for such help ?
If the answer is YES you can have the topic transferred to the pay section.
