One more question when I try to upload this, I get error 'Error compiling.' =( :~
This example shows the various abilities of the TouchScreenMenu library.
See the readme.txt file for information on find the libraries this library uses.
TouchScreenMenu Library.
2012 Copyright (c) Scott Shaver
Authors: Scott Shaver
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 3 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include <TouchScreenMenu.h>
#include <TouchScreen.h>
#include <TFT.h>
#include <cstddef.h>
// create the array of items for the first sub menu
TouchScreenMenuItem subMenuItems[] = {
TouchScreenMenuItem("<- Main Menu"),
TouchScreenMenuItem("Left Justify"),
TouchScreenMenuItem("Right Justify"),
TouchScreenMenuItem("Small Font"),
TouchScreenMenuItem("Spacing"),
TouchScreenMenuItem("Padding"),
TouchScreenMenuItem("ENDOFMENU")
// create the array of items for the left justify sub menu
TouchScreenMenuItem leftSubMenuItems[] = {
TouchScreenMenuItem("<- Back"),
TouchScreenMenuItem("Item 1"),
TouchScreenMenuItem("Item 2"),
TouchScreenMenuItem("Item 3"),
TouchScreenMenuItem("Item 4"),
TouchScreenMenuItem("Item 5"),
// create the array of items for the right justify sub menu
TouchScreenMenuItem rightSubMenuItems[] = {
// create the array of items for the wide spacing sub menu
TouchScreenMenuItem spacingSubMenuItems[] = {
// create the array of items for the wide padding sub menu
TouchScreenMenuItem paddingSubMenuItems[] = {
// create the array of items for the small font sub menu
TouchScreenMenuItem smallSubMenuItems[] = {
TouchScreenMenuItem("Item 6"),
TouchScreenMenuItem("Item 7"),
TouchScreenMenuItem("Item 8"),
TouchScreenMenuItem("Item 9"),
// create the array of items for the main menu
TouchScreenMenuItem mainMenuItems[] = {
TouchScreenMenuItem("-> Sub Menus"),
TouchScreenMenuItem("Gfx Functions"),
TouchScreenMenuItem("Buttons"),
TouchScreenMenuItem("Labels"),
// create the various menus setting the items, font size, spacing, padding, justification and titles
TouchScreenMenu paddingSubMenu = TouchScreenMenu(paddingSubMenuItems, 2, 5, 20, CENTERJ, "Padding");
TouchScreenMenu spacingSubMenu = TouchScreenMenu(spacingSubMenuItems, 2, 40, 5, CENTERJ, "Spacing");
TouchScreenMenu smallSubMenu = TouchScreenMenu(smallSubMenuItems, 1, 10, 5, CENTERJ, "Small Font");
TouchScreenMenu rightSubMenu = TouchScreenMenu(rightSubMenuItems, 2, 10, 5, RIGHTJ, "Right Justify");
TouchScreenMenu leftSubMenu = TouchScreenMenu(leftSubMenuItems, 2, 10, 5, LEFTJ, "Left Justify");
TouchScreenMenu subMenu = TouchScreenMenu(subMenuItems, 2, 10, 5, CENTERJ, "Sub Menu");
TouchScreenMenu mainMenu = TouchScreenMenu(mainMenuItems, 2, 10, 10, CENTERJ, "Main Menu");
// keep track of which menu is the currently active one
TouchScreenMenu *curMenu = &mainMenu;
TouchScreenArea backFromGfx = TouchScreenButton("<- Back", TSC.createColor(255, 255, 255), TSC.createColor(0, 0, 0), 50, TSC.getScreenHeight() - 50, 2, 10);
TouchScreenArea backFromBtns = TouchScreenButton("<- Back", TSC.createColor(255, 255, 255), TSC.createColor(0, 0, 0), 50, TSC.getScreenHeight() - 50, 2, 10);
TouchScreenArea backFromLbls = TouchScreenButton("<- Back", TSC.createColor(255, 255, 255), TSC.createColor(0, 0, 0), 50, TSC.getScreenHeight() - 50, 2, 10);
TouchScreenArrowButton btn1 = TouchScreenArrowButton("btn1",TSC.createColor(0, 0, 0), TSC.createColor(255, 200, 0), 10, TSC.getScreenHeight() - 220, 30, 30, UP);
TouchScreenArrowButton btn2 = TouchScreenArrowButton("btn2",TSC.createColor(0, 0, 0), TSC.createColor(255, 0, 255), 50, TSC.getScreenHeight() - 220, 30, 50, DOWN);
TouchScreenArrowButton btn3 = TouchScreenArrowButton("btn3",TSC.createColor(0, 0, 0), TSC.createColor(0, 255, 255), 90, TSC.getScreenHeight() - 220, 30, 70, LEFT);
TouchScreenArrowButton btn4 = TouchScreenArrowButton("btn4",TSC.createColor(0, 0, 0), TSC.createColor(255, 255, 255), 130, TSC.getScreenHeight() - 220, 30, 90, RIGHT);
TouchScreenCircleButton btn5 = TouchScreenCircleButton("btn5",TSC.createColor(0, 0, 0), TSC.createColor(255, 255, 255), 10, 10, 70, 70);
TouchScreenCircleButton btn6 = TouchScreenCircleButton("btn6",TSC.createColor(0, 0, 0), TSC.createColor(0, 0, 255), 80, 10, 40, 40);
TouchScreenSlider btn7 = TouchScreenSlider("btn7",TSC.createColor(200, 200, 200), TSC.createColor(50, 50, 255), 5, TSC.getScreenHeight() - 110, 150, 40, HORIZONTAL);
TouchScreenSlider btn8 = TouchScreenSlider("btn8",TSC.createColor(255, 0, 0), TSC.createColor(200, 255, 0), TSC.getScreenWidth()-55, TSC.getScreenHeight() - 200, 40, 150, VERTICAL);
TouchScreenArea lbl1 = TouchScreenLabel("This is a label with bg.", TSC.createColor(0, 0, 0), TSC.createColor(255, 255, 255), 45, 10, 1, 2, true);
TouchScreenArea lbl2 = TouchScreenLabel("This is a label, no bg.", TSC.createColor(0, 0, 0), TSC.createColor(255, 255, 255), 45, 30, 1, 2, false);
TouchScreenArea lbl3 = TouchScreenLabel("Big label.", TSC.createColor(255, 255, 255), TSC.createColor(0, 0, 0), 0, 60, 2, 2, true);
TouchScreenArea lbl4 = TouchScreenLabel("Big label.", TSC.createColor(255, 0, 0), TSC.createColor(255, 255, 0), 0, 90, 2, 2, false);
TouchScreenArea lbl5 = TouchScreenLabel("Big label.", TSC.createColor(0, 200, 0), TSC.createColor(255, 0, 255), 0, 120, 3, 2, true);
TouchScreenArea lbl6 = TouchScreenLabel("Big label.", TSC.createColor(0, 200, 0), TSC.createColor(255, 0, 255), 0, 160, 3, 2, false);
void setup(void) {
TSC.setBackColor(TSC.createColor(255, 255, 0)); // change the default background color
TSC.init(); // make sure everything get initialized
btn7.setValue(.5); // change the value on one of the sliders
btn7.setPadding(5); // change the padding on one of the sliders
btn8.setValue(.75); // change the value on one of the sliders
btn8.setPadding(5); // change the padding on one of the sliders
curMenu->draw(); // put up the main menu
void loop(void) {
// handle the current menu
if(curMenu!=NULL){
// process the current menu
TouchScreenMenuItem *item = curMenu->process(false);
// check to see which, if any, menu item was pressed
checkMenuSelection(item);
}else{
// if there isn't a current menu being displayed check all of the buttons
// to see if any of them was pressed
checkButtons();
// check various buttons and perform actions if any was pressed
void checkButtons(){
if(backFromGfx.process()){ // return from the graphics function screen
TSC.clearScreen();
curMenu->draw();
else if(backFromBtns.process()){ // return from the buttons screen
TSC.clearScreen();
curMenu->draw();
