hi guys,
The code I have works, but I feel like there's a better way (with modulus division?) to "wrap" my list back around to itself.
I have an array with a max of 128 items. The menu displays 10 items at a time. Each time the position is higher than 10th item listed, it scrolls down. Works for Up as well.
A nice to have would be to have the list wrap around itself. so if I press up when I'm at 1, it would list 120 through 1.
I garauntee there's a better way than how I'm doing it. So, fair warning, my code is noob stuff probably.
// Static menu manager
#define MAX_SELECTIONS 5
#define MAX_PROMPT_LEN 20
char nameFiles[128][20];
char name[20];
String strname = "";
SdFile root;
int filePOS = 0;
int fileIndex = 0;
int listStart = 1;
int maxmidicount;
void clearFilelist(){
tft.drawRect(0, 60, 128, 100, BLACK);
tft.fillRect(0, 60 , 128, 100, BLACK);
int topfile(int pos, int start, int index){
int result;
pos = filePOS;
start = listStart;
index = fileIndex;
if (filePOS>120){
result = 7;
result = 10;
return result;
//int maxfile = topfile(filePOS, listStart, fileIndex);
void drawFilelist(){
clearFilelist();
char msg[64];
sprintf(msg, "listStart: %d\n filePOS: %d\n fileIndex: %d\n", listStart, filePOS, fileIndex);
Serial.print(msg);
tft.setCursor(0,60);
Serial.println(maxfile);
//for(fileIndex = listStart; fileIndex < (listStart+10); fileIndex++){
for(fileIndex = listStart; fileIndex < (listStart+maxfile); fileIndex++){
if (fileIndex == filePOS) {
tft.setTextColor(GREEN);
tft.setTextColor(WHITE);
tft.print(fileIndex);
tft.print(" ");
tft.println(nameFiles[fileIndex]) ;
void IndexFileNames(){
//char test1[20];
SD.vwd()->rewind();
while (root.openNext(SD.vwd(), O_READ)) {
root.getFilename(name);
// Serial.println(name);
root.close();
strname = name;
if (strname.endsWith(".MID") ) {
fileIndex++;
for (int i = 0; i<20; i++){
if (name[i] != 0x00){
nameFiles[fileIndex][i] = name[i];
maxmidicount = fileIndex;
void select_midi(int key){
drawFilelist();
for( uint8_t b = CheckJoystick(); b != Press; b = CheckJoystick() ) {
if (b == Down){
if (filePOS<127){
if (filePOS>=(listStart+9) ){
filePOS++;
listStart = filePOS;
drawFilelist();
Serial.println("new page");
filePOS++;
drawFilelist();
Serial.println("goin down");
else if (b==Up){
if (filePOS>1){
if (filePOS<=(listStart)){
filePOS--;
listStart = filePOS-9;
drawFilelist();
filePOS--;
drawFilelist();
cls();
draw_menu();
