TGS2603 sensor unable function.
i been brought an tgs2603 sensor i following the data sheet of the sensor . i connection the AN2 to esp32 IO32 which was analog pin. 5V to the VCC and gnd to gnd of the esp32 board. During my coding
const int TELEGRAM_BUTTON_PIN =32;
int TELEGRAM_BUTTON_PINReading;
// Initlaze the buttons
pinMode(TELEGRAM_BUTTON_PIN, INPUT);
  TELEGRAM_BUTTON_PINReading = analogRead(32);    // take a reading from the optical sensor pin
  Serial.println(TELEGRAM_BUTTON_PINReading);         // the analog reading of the optical sensor
  delay(5);
the serial monitor keep printing 1623 value , by the way it should remaining 0. i have been testing this coding with other analog sensor it was working properly . Is i doing anything stupid ?
no one knows ?
Can you post a schematic? What value load resistor are you using?
BJHenry:
5 V the sensor name as 5 V so i connecting to 5 v pin of the esp 32
A link to data/specs of the sensor please?
BabyBoss101:
That doesn't really answer either of the points I asked you.
BabyBoss101:
ESP32 is 0 to 3.3V ADC.
Also look at the data sheet that shows it connections and how to get readings;
Tom... :slight_smile:
