Actually I presumed OP would use the same LED/resistor of the original circuit. But also didn´t know pin 13 had a resistor in the past. So, thanks!
But yes sorry, all upload code were failed, I also try with something with Serial.printI() and it fails.
Turn on verbose output for compiling and upload in your preferences then try the Blink sketch again.
After uploading it copy the full message from the bottom of the screen and post it here again in
< CODE/ > tags
Using board 'uno' from platform in folder: /Users/chloe/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Using core 'arduino' from platform in folder: /Users/chloe/Library/Arduino15/packages/arduino/hardware/avr/1.8.6
Detecting libraries used...
/Users/chloe/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/chloe/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/chloe/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/Users/chloe/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/chloe/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/chloe/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/sketch/Blink.ino.cpp -o /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/preproc/ctags_target_for_gcc_minus_e.cpp
/Users/chloe/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/preproc/ctags_target_for_gcc_minus_e.cpp
Compilation du croquis...
/Users/chloe/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Users/chloe/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/Users/chloe/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/sketch/Blink.ino.cpp -o /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/cores/arduino_avr_uno_d3704327e7059f7a188ba0f60ae9cb17/core.a
Linking everything together...
/Users/chloe/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/Blink.ino.elf /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/sketch/Blink.ino.cpp.o /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/../../cores/arduino_avr_uno_d3704327e7059f7a188ba0f60ae9cb17/core.a -L/private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A -lm
/Users/chloe/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/Blink.ino.elf /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/Blink.ino.eep
/Users/chloe/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/Blink.ino.elf /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/Blink.ino.hex
/Users/chloe/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/Blink.ino.elf
Le croquis utilise 924 octets (2%) de l'espace de stockage de programmes. Le maximum est de 32256 octets.
Les variables globales utilisent 9 octets (0%) de mémoire dynamique, ce qui laisse 2039 octets pour les variables locales. Le maximum est de 2048 octets.
"/Users/chloe/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/chloe/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-P/dev/cu.usbmodem21301" -b115200 -D "-Uflash:w:/private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/Blink.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/chloe/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/chloe/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem21301
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/private/var/folders/nn/3glhgr3j7hq9dt7rpd6sks840000gn/T/arduino/sketches/9F7D32F12B8E32531B4055CD3194B11A/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 0.13s
avrdude: 924 bytes of flash written
avrdude done. Thank you.
This indicates that the code is compiling and loading successfully.
It looks like you used Blink.ino when you generated this.
Is the on board led blinking?
Yes, but the led blink 3 times very fast, infinitely, like before uploading the code. It does not blink as requested in the code.
In Preferences, please check the box which says "Verify Code after Upload" and see what the verbose output indicates when that is checked.
There is indeed a error here:
avrdude: verification error, first mismatch at byte 0x0000
0x62 != 0x0c
avrdude: verification error; content mismatch
Failed uploading: uploading error: exit status 1
Hi @ada
It looks like you are using the 2.0.xxx IDE.
Load the 1.8.19 IDE and see if it works.
What OS are you using?
Tom..
I will check in a few hours, my mac Os is Monterey version 12.0.1
This is an indication of a problem with the bootloader code on the AT328.
https://forum.arduino.cc/t/solved-verification-error-content-mismatch/436352
You can either try to burn a new bootloader using another Arduino or a USBASP programmer. There are plenty of guides to be found online.
Alternatively, since you have a socketed AT328 on your board, you can purchase a new chip which is programmed with the bootloader. Not all AT328 chips are sold this way, so make certain of what you are buying.
I changed the AT328 and It actually works now. Thanks you all !
