The BlinkWithoutDelay Sample Which Functions Depending on a Push Button
Hello everyone, I'm trying to add a button to BlinkWithoutDelay sample. I add a button. Everything was going OK but I wanted while I'm not pressing the button, I want the led turn off. In this case if the led turns on and I take my hand the led still turn on. Then I add a little code for that but now the led always turns off.
const int ledPin =  LED_BUILTIN;
const int buttonPin = 5; // Emirhan
int ledState = LOW;
int buttonstate; // Emirhan
unsigned long previousMillis = 0;
const long interval = 1000;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT); // Emirhan
  buttonstate = digitalRead(buttonPin);  // Emirhan
    if (buttonstate==HIGH && currentMillis - previousMillis >= interval) { // Emirhan
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(ledPin, ledState);
    digitalWrite(ledPin,LOW);  // Emirhan
how did you wire your button?
look at your outer if-else
--> try to understand when you are in the "else" - what does it mean for the condition
Sorry, but I can't understand the problem. I wired simply.
The demo Several Things at a Time is an extended example of BWoD and illustrates the use of millis() to manage timing without blocking. It may help with understanding the technique.
It includes code for a button switch.
Have a look at Using millis() for timing. A beginners guide if you need more explanation.
...R
When the condition (A and B) is not true - what can you say about A or B ? What can’t you say?
I am pleased for your effort but I still don't understand. I add a one more if-else but now the led always works.
 unsigned long storageMillis;
const byte ledPin = 13;
const byte buttonPin = 5;
int buttonstate;
  if(buttonstate==HIGH)
  if(millis() - storageMillis >= 500)
    digitalWrite(ledPin, !digitalRead(ledPin));
    storageMillis = millis();
  digitalWrite(ledPin, LOW);
J-M-L:
When the conduatuob (A and B) is not true - what can you say about A or B ? What can’t you say?
It can't be there is one situation; button on or off.
Robin2:
...R
Thank you but isn't it complicated for just a switch?
if (A and B) is true, it means only one thing A is true and B is true
if (A and B) is false, it could be many things (A is false and B is true), or (A is true and B is false) or (A is false and B is false)
This is not an answer
I wired simply.
How is the button wired, really ? full description...
emirhankarahan:
Take out of the demo the parts that you need.
...R
J-M-L:
emirhankarahan:
@OP
Given below 4 possible (could have more) options for connecting a button with the UNO via DPin-5. Tell us which option (1, 2, 3, 4) you have selected.
BTW: To you, what is the meaning of -- BlinkWithoutDelay? The blink is composed of 4 events: ON-timeDelay-OFF-timeDelay. We need certain amount of timeDelay (waiting for sometimes) to see that the LED is ON (OFF). How can a LED blink without Delay?
J-M-L:
This is not an answer How is the button wired, really ? full description...
I already added a picture for connection. One terminal of the button wired Arduino 5. digital pin and the other terminal wired with Arduino 5V pin. And a pull-up resistor. I'm using simulation programs(tinkercad and proteus). I checked the wires. There isn't problem.
And I updated my code for your advice. It isn't working.
    else if(buttonstate==LOW && currentMillis - previousMillis >= interval)
    else if(buttonstate==HIGH && currentMillis - previousMillis < interval)
    else if(buttonstate==LOW && currentMillis - previousMillis < interval)
Robin2:
...R
I tried. I wish, I could. Thx.
GolamMostafa:
@OP
  1. connection and ''BlinkWithoutDelay'' is a Arduino sample. It doesn't mean without delay, It means without ''delay'' code.
but you failed at doing so.. picture not visible for the rest of us...
emirhankarahan:
emirhankarahan:
4. connection[...].
Apparently, the above two statements on connection of your button do not match.
As per top statement: one side (say, Terminal-1) of the button with DPin-5; other side (say, Terminal-2) of the button with 5V. You have a pull-up resistor - how is it connected? Is it between DPin-5/Terminal-1 and 5V or between Terminal-2 and 5V?
Option 4. of Post#8 says that Terminal-1 of the button is with DPin-5; Terminal-2 of the button is with 5V; the pull-down resistor is between Terminal-1 and GND.
Please, be sure first about the connection of your button.
emirhankarahan:
Unless you post the program showing what you tried I can't help.
...R
I've tried one more this code;
int buttonstate;
and It works as I wish. Thank you for all.
Note: I used one more if-else for that. I couldn't fix the problem but in the end, the second code is working.
