The countdown doesn't work on the buttons
I made an action button to make a countdown, when the button is pressed it counts down from 10 seconds, when it is pressed again it counts down from 20 seconds, the problem is when the done1 and done2 ​​buttons can be enabled, what should I change?
unsigned long prevMillis = 0;
// Counter (seconds)
int counter;
int counter2;
const int ledPin =  LED_BUILTIN;
unsigned long previousMillis = 0;
int current_Volts = 1;
int current_Volts_low;
int current_Volts_high;
bool counter1start = false;
bool counter2start = false;
 const int buttonPin = 4;
 int buttonState = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  counter = 10;
  counter2 = 20;
  prevMillis = millis();
  Serial.println("Please enter your name:");
void loop () {
  buttonState = digitalRead(buttonPin);
  if (millis() - previousMillis >= 1000) {
    previousMillis = millis();
    digitalWrite(ledPin, !digitalRead(ledPin));
    if ((buttonState == HIGH) && counter1start == false) {
      counter2 = 20;
      counter1start = true;
    if (counter1start) Serial.println(counter--);
    if (counter <= 0) {
      Serial.println("Done1");
      //current_Volts = 50;
      counter = 10;
    if ((buttonState == LOW) && counter2start == false) {
      counter = 10;
      counter2start = true;
    if (counter2start) Serial.println(counter2--);
    if (counter2 <= 0) {
      Serial.println("Done2");
      counter2 = 20;
This code structure is similar to whack a mole coding. :woozy_face:
Study how to use the State Machine coding technique in you sketches.
Edit
Thanks for using code tags.
Always show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
YMMD :+1:
Try this:
#include <Arduino.h>
#include <Bounce2.h> // https://github.com/thomasfredericks/Bounce2/archive/refs/heads/master.zip
Bounce2::Button button = Bounce2::Button();
byte step = 0;
int counter;
int counterLimit = 10;
bool start = false;
  button.attach(buttonPin, INPUT_PULLUP);
  button.interval(5); // interval im ms
  button.setPressedState(LOW);
  button.update();
  if (button.pressed())
    if(step == 1)
      counter = 0;
      step = 2;
      counterLimit = 20;
      start = true;
      Serial.println("Starting countdown 2");
      Serial.println(counterLimit - counter);
      counter = 0;
      step = 1;
      counterLimit = 10;
      start = true;
      Serial.println("Starting countdown 1");
  switch (step)
    case 0:
    case 1:
      if ((millis() - previousMillis >= 1000) && (start == true))
        counter++;
      if((counter == counterLimit) && (start == true))
        start = false;
        Serial.println("Done 1!");
    case 2:
        counter++;
        start = false;
        Serial.println("Done 2!");
    default:
Hello bimosora
Try, check and study this small C++ example for your count down task:
/* BLOCK COMMENT
  - https://forum.arduino.cc/t/the-countdown-doesnt-work-on-the-buttons/1088319
  - The countdown doesn’t work on the buttons
  - This sketch may contain traces of C++.
  - In case of indisposition:
  - https://www.learncpp.com/
  - Hardware:
  - Thanks to LarryD
  - https://europe1.discourse-cdn.com/arduino/original/4X/7/e/0/7e0ee1e51f1df32e30893550c85f0dd33244fb0e.jpeg
  - https://forum.arduino.cc/t/beginners-software-needs-hardware/1066703
  - Tested @ Arduino: Mega[X] - UNO [ ] - Nano [ ]
#define ProjectName "The countdown doesn’t work on the buttons"
// make structures
struct TIMER
  const unsigned long Interval;
  unsigned long stamp;
struct COUNTDOWN
  const int CountDowns[2];
  int countDownValue;
  const int ButtonPin;
  int stateOld;
  TIMER debounce;
  TIMER count;
} countDown {{10, 20}, 10, A0, false, 20, 0,  1000, 0};
// tools
void heartBeat(int LedPin)
  static bool setUp = false;
  if (!setUp) pinMode (LedPin, OUTPUT), setUp = !setUp;
  digitalWrite(LedPin, (millis() / 1000) % 2);
  Serial.print(ProjectName), Serial.print(" in "), Serial.println(__FILE__);
  pinMode (countDown.ButtonPin, INPUT_PULLUP);
  heartBeat(LED_BUILTIN);
  if (currentMillis - countDown.debounce.stamp >= countDown.debounce.Interval && countDown.countDownValue == 0 ? HIGH : LOW) {
    countDown.debounce.stamp = currentMillis;
    int stateNew = digitalRead(countDown.ButtonPin) ? LOW : HIGH;
    if (countDown.stateOld != stateNew)
      countDown.stateOld = stateNew;
      if (stateNew == HIGH)
        static int selector = LOW;
        countDown.countDownValue = countDown.CountDowns[selector];
        Serial.print("Starting countdown "), Serial.println(selector + 1);
        selector = selector == HIGH ? LOW : HIGH;
  if (currentMillis - countDown.count.stamp >= countDown.count.Interval && countDown.countDownValue != 0 ? HIGH : LOW)
    countDown.count.stamp = currentMillis;
    Serial.print("count down "), Serial.println(countDown.countDownValue--);
    if (countDown.countDownValue == 0) Serial.println("done");
Thanks everyone I'll try to clean it up and try what you came up with
When the initial button is HIGH will it run automatically?
Show me your circuit.
For example I have a rain sensor, when there is no rain it will automatically read the digital pin is low, what about your code will it read low the first time, I only see the code working when the button is pressed?
:point_up_2:
I tried to change the button in your code using a slide switch to experiment whether it will run automatically in LOW status or not
What about show me what you doing in reality?
Pay attention to the button here, it should when I slide it to the right HIGH the way but it only works when there is a ground cable only
Is there anything I have to change, it looks like the countdown works when the button is released not when it is pressed or released?
You can't connect in this way.
Check it:
It doesn't work for switches
Have you ever seen the light turn on when the button is pressed and the light turns off when the button is released. That's what I meant to turn on the counter
It's the same thing.
You can't short arduino pin with 5V or GND directly.
Using internal pull up the state will be always HIGH on right side and LOW in left side,
switch
Your code actually works but I want to replace it with a switch so when the switch I point to the right of the counter 2 way, then I point to the left of the counter 1 way, so the button is not released then the new run
You know this tool, when it's high, for example, the lights on the Arduino are on, then when it's low, the lights on the Arduino are off, but I want to change it to 2 counters for the lights. The counter lights on first and the counter lights off first
Arduino-IR-Collision-Detection-Module-Pin-Outs
