The number on the display does not change
hi, i need help, i don't know why my code doesn't work, i would like when i click a button so the number on the display changes to TM1637 but it doesn't work? (Sorry for my English, I don't speak English well) :frowning:
#include <TM1637.h>
int button = 4;
int buttonstate = 0;
int CLK = 2;
int DIO = 3;
TM1637 tm(CLK, DIO);
  tm.init();
  pinMode(button, INPUT);
  //set brightness; 0-7
  tm.set(2);
  buttonstate = digitalRead(button);
  if (button == HIGH)
    displayNumber(10.00);
  else if (button == HIGH);
  displayNumber(11.25);
  if (button == HIGH)
    displayNumber(12.50);
  displayNumber(13.75);
void displayNumber(int num) {
  tm.display(3, num % 10);
  tm.display(2, num / 10 % 10);
  tm.display(1, num / 100 % 10);
  tm.display(0, num / 1000 % 10);
That is an odd use of an if / then / else if / else statement where each condition is exactly the same.
I assume that you want, on each subsequent button press, that the next number in the series is displayed.
Yes, I want this to change the number every time I click :slight_smile:
else if (button == HIGH);That semicolon doesn't belong there
You need to detect when a button becomes pressed rather than when it is pressed. See the StateChangeDetection example in the IDE
When such a change is detected you can increment a variable and decide what to print based on the value of the number
Also, know that the pin number is not the same as the state on that pin.
thanks everyone for the help :slight_smile: but i still don't know how to create this code
Did you look at the example I directed you to ?
It shows how to detect a button press and increment a number
What have you tried since looking at the example ?
Where are you stuck ?
I looked at StateChangeDetection I tried to convert it for my code but it doesn't work or I don't know how I can set it to change the number from 10.00 = 11.25 = 12.50 = 13.75 with each click
#include <TM1637.h>
int button = 4;
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
int CLK = 2;
int DIO = 3;
  tm.init();
  tm.set(2);
  buttonState = digitalRead(button);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      Serial.println("on");
      Serial.print("number of button pushes: ");
      Serial.println(buttonPushCounter);
      // if the current state is LOW then the button went from on to off:
      Serial.println("off");
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
if (buttonPushCounter % 9 == 0)
You have a comment saying "increment the counter" but I can't see any code that is doing any incrementing.
Steve
Divide large problems in two (or more) parts.
In this case, part 1 is to increment a counter each time a button is pressed:
0, 1, 2, 3, 0, 1, 2 ......
Modify the first part of your code to do this and, for testing, write the value of the counter to the serial monitor.
Part 2 is to display a number on the display depending on the value of the counter. That is simply a big if / then / else if / else (or switch) statement.
There may be other, equally valid, ways of solving this.
Come back when you have tried this and whether it works or not post your code. Then you can move on to translating the count to another number of your choice
Thanks, I'll take a look at it :slight_smile:
I tried the test, nothing works, at least my code doesn't work and I don't know why
int button = 2;
int led = 13;
  pinMode(led, OUTPUT);
  buttonstate == digitalRead(button);
  switch (buttonstate) {
    case 1:
        digitalWrite(led, HIGH);
        // statements
    case 2:
        digitalWrite(led, LOW);
        // statements
      { case 3:
      // statements
      default:
Did you remember to rewire, to move the switch to the different pin?
case 2:digitalRead returns HIGH or LOW, neither of which will ever equal 2.
You have no code in that sketch to sense that the button has become pressed and nothing to increment a variable
Go back to the StateChangeDetection example. Modify it to print buttonPushCounter each time it changes and take out the code that controls the LED then come back and post your code and describe what it does
buttonstate == digitalRead(button); Too much '='
I don't know, I just don't know how to make such code work, I tried it for half a day and nothing
See reply #15
I didn't give up and it works finally :slight_smile:
#include <TM1637.h>
int button = 4;
int counter = 0;   // counter for the number of button presses
int buttonstate = 0;         // current state of the button
int CLK = 2;
int DIO = 3;
  tm.init();
  tm.set(5);
  if (buttonstate == HIGH) {
    counter++;
    delay(100);
    Serial.print(counter);
    if (counter == 1)
      displayNumber(1000);
    else if (counter == 2)
      displayNumber(1125);
    else if (counter == 3)
      displayNumber(1250);
    else if (counter == 4)
      displayNumber(1375);
    else if (counter == 5)
      displayNumber(1500);
    else if (counter == 6)
      displayNumber(1625);
    else if (counter == 7)
      displayNumber(1750);
    else if (counter == 8)
      displayNumber(1850);
    else if (counter == 9)
      displayNumber(2000);
    else if (counter == 10)
      displayNumber(2125);
    else if (counter == 11)
      displayNumber(2250);
   if (counter == 11) counter = 0;
  tm.point(1);
