The rotary encoder works well om Arduino UNO, not on esp32?
Hi all.
the code below works on UNO output as excepted; it keeps output till a large number like over 1000 without any turning. why?
Thanks.
Adam
// Rotary Encoder Inputs
#define CLK 2
#define DT 3
#define SW 4
int counter = 0;
int currentStateCLK;
int lastStateCLK;
String currentDir ="";
unsigned long lastButtonPress = 0;
	// Set encoder pins as inputs
	pinMode(CLK,INPUT);
	pinMode(DT,INPUT);
	pinMode(SW, INPUT_PULLUP);
	// Setup Serial Monitor
	// Read the initial state of CLK
	lastStateCLK = digitalRead(CLK);
	// Read the current state of CLK
	currentStateCLK = digitalRead(CLK);
	// If last and current state of CLK are different, then pulse occurred
	// React to only 1 state change to avoid double count
	if (currentStateCLK != lastStateCLK  && currentStateCLK == 1){
		// If the DT state is different than the CLK state then
		// the encoder is rotating CCW so decrement
		if (digitalRead(DT) != currentStateCLK) {
			counter --;
			currentDir ="CCW";
			// Encoder is rotating CW so increment
			counter ++;
			currentDir ="CW";
		Serial.print("Direction: ");
		Serial.print(currentDir);
		Serial.print(" | Counter: ");
		Serial.println(counter);
	// Remember last CLK state
	lastStateCLK = currentStateCLK;
	// Read the button state
	int btnState = digitalRead(SW);
	//If we detect LOW signal, button is pressed
	if (btnState == LOW) {
		//if 50ms have passed since last LOW pulse, it means that the
		//button has been pressed, released and pressed again
		if (millis() - lastButtonPress > 50) {
			Serial.println("Button pressed!");
		// Remember last button press event
		lastButtonPress = millis();
	// Put in a slight delay to help debounce the reading
	delay(1);
GPIO 3 on ESP32 is RX used by serial port.
Thanks.
Sorry I forgot to tell I changed pins as below on ESP32:
#define CLK 10
#define DT   11
#define SW  12
How about use some pin with name starting with "G"?
Thanks.
All pins used are GPIO.
