The word "OK" is display each time SMS is receive using GSM shield problem!!!
hi everyone,
i'm using gsm shield to receive sms which is then stored in an array but code is working but the word OK is display each time i'm receiving sms, can someone please help me how to solve this.
Please refer to the attachment for the error i'm encountering.
Thanks a lot
 SMS receiver
 This sketch, for the Arduino GSM shield, waits for a SMS message
 and displays it through the Serial port.
 Circuit:
 * GSM shield attached to and Arduino
 * SIM card that can receive SMS messages
 created 25 Feb 2012
 by Javier Zorzano / TD
 This example is in the public domain.
 http://arduino.cc/en/Tutorial/GSMExamplesReceiveSMS
// include the GSM library
#include <GSM.h>
// PIN Number for the SIM
#define PINNUMBER ""
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
// Array to hold the number a SMS is retreived from
char senderNumber[20];
char newMessage[160];
bool newMessageAvailable = false;
  pinMode(5, OUTPUT);
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("SMS Messages Receiver");
  // connection state
  boolean notConnected = true;
  // Start GSM connection
  while (notConnected)
    if (gsmAccess.begin(PINNUMBER) == GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.println("Waiting for messages");
  char c;
  byte smsIndex = 0;
  // If there are any SMSs available()
  if (sms.available())
    Serial.println("Message received from:");
    // Get remote number
    sms.remoteNumber(senderNumber, 20);
    Serial.println(senderNumber);
    // An example of message disposal
    // Any messages starting with # should be discarded
    if (sms.peek() == '#')
      Serial.println("Discarded SMS");
      sms.flush();
    // Read message bytes and print them
    while (c = sms.read())
      Serial.print(c);
      newMessage[smsIndex++] = c;
      newMessage[smsIndex] = '\0'; // Keep string NULL terminated
      newMessageAvailable = true;
       } // Always use curly braces with while statements!
      Serial.println("\nMESSAGE STORE IN ARRAY");
      Serial.print(newMessage);
      Serial.println("\nEND OF MESSAGE");
    // Delete message from modem memory
    sms.flush();
    Serial.println("MESSAGE DELETED");
Every time you send an AT command, a response if generated. Since that process is asynchronous, YOU must manage to connect the response to the command.
Typically, that is done by misusing the asynchronous nature of communications, by simply waiting for a response, doing nothing else until the complete response is received.
I don't see that getting OK as a response is a problem to be solved. Of course, if it is, simply unplug the device. No OK responses anymore.
