Thermal printer not printer Bitmap
Hi ! I am having trouble printing bitmap on my thermal printer bought on Aliexpress ::
https://fr.aliexpress.com/i/4000782512644.html
The Adafruit library tet sketch works well for text and barcode but the Bitmap returns chinese characters. I did some digging online and found a tutorial that helps print bitmap without the adafruit library.
I need some help working out the tech documentation - as I am able to reproduce a bitmap and have the same resutl as the tutorial posted above but I cannot manage to understand
  1. how to change the width :
  2. Why the width is equivalent to the height on the print (The logo is printed horizontaly instead of verticaly)
    https://dfimg.dfrobot.com/nobody/wiki/0c0a789684349c93a55e754f49bdea18.pdf
Thanks for your help
Code
  Example sketch for Adafruit Thermal Printer library for Arduino.
  Demonstrates a few text styles & layouts, bitmap printing, etc.
  IMPORTANT: DECLARATIONS DIFFER FROM PRIOR VERSIONS OF THIS LIBRARY.
  This is to support newer & more board types, especially ones that don't
  support SoftwareSerial (e.g. Arduino Due).  You can pass any Stream
  (e.g. Serial1) to the printer constructor.  See notes below.
  You may need to edit the PRINTER_FIRMWARE value in Adafruit_Thermal.h
  to match your printer (hold feed button on powerup for test page).
#include "Adafruit_Thermal.h"
#include "adalogo.h"
#include "adaqrcode.h"
// Here's the new syntax when using SoftwareSerial (e.g. Arduino Uno) ----
// If using hardware serial instead, comment out or remove these lines:
#include "SoftwareSerial.h"
#define TX_PIN 11 // Arduino transmit  YELLOW WIRE  labeled RX on printer
#define RX_PIN 10 // Arduino receive   GREEN WIRE   labeled TX on printer
SoftwareSerial mySerial(RX_PIN, TX_PIN); // Declare SoftwareSerial obj first
Adafruit_Thermal printer(&mySerial);     // Pass addr to printer constructor
// Then see setup() function regarding serial & printer begin() calls.
// Here's the syntax for hardware serial (e.g. Arduino Due) --------------
// Un-comment the following line if using hardware serial:
//Adafruit_Thermal printer(&Serial1);      // Or Serial2, Serial3, etc.
  // This line is for compatibility with the Adafruit IotP project pack,
  // which uses pin 7 as a spare grounding point.  You only need this if
  // wired up the same way (w/3-pin header into pins 5/6/7):
  pinMode(7, OUTPUT); digitalWrite(7, LOW);
  // NOTE: SOME PRINTERS NEED 9600 BAUD instead of 19200, check test page.
  mySerial.begin(9600);  // Initialize SoftwareSerial
  //Serial1.begin(19200); // Use this instead if using hardware serial
  printer.begin();        // Init printer (same regardless of serial type)
  // The following calls are in setup(), but don't *need* to be.  Use them
  // anywhere!  They're just here so they run one time and are not printed
  // over and over (which would happen if they were in loop() instead).
  // Some functions will feed a line when called, this is normal.
  // Barcode examples:
  // CODE39 is the most common alphanumeric barcode:
  printer.printBarcode("ADAFRUT", CODE39);
  printer.setBarcodeHeight(100);
  // Print UPC line on product barcodes:
  printer.printBarcode("123456789123", UPC_A);
  mySerial.write(show,823);     //Send “print bitmap instruction” to printer
  printer.sleep();      // Tell printer to sleep
  delay(3000L);         // Sleep for 3 seconds
  printer.wake();       // MUST wake() before printing again, even if reset
  printer.setDefault(); // Restore printer to defaults
The bitmap
unsigned char  show[] = {
0x1B,0x2A,0x20,0xFA,0x00,   //Bitmap size: 24*250, revise parameter with the reference of general instruction set 34 and 35 < 24 is actualy the height & 250 the widht when printed ???
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,0x00,0xFE,0x00,0x00,0xFE,0x00,0x01,0xFF,
0x00,0x01,0xFF,0x80,0x03,0xFF,0x80,0x03,0xEF,0x80,0x07,0xEF,0xC0,0x07,0xC7,0xC0,0x07,0xC7,0xC0,0x07,0xC7,0xC0,0x07,0xC7,0xE0,0x0F,0x83,0xE0,
0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x81,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,
0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,
0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x1F,0x01,0xF0,0x0F,0x81,0xF0,0x0F,0x83,0xE0,
0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0xC7,0xE0,0x07,0xC7,0xC0,0x07,0xC7,0xC0,0x07,0xC7,0xC0,0x07,
0xEF,0xC0,0x03,0xEF,0x80,0x03,0xFF,0x80,0x01,0xFF,0x80,0x01,0xFF,0x00,0x00,0xFE,0x00,0x00,0xFE,0x00,0x00,0x38,0x00,0x00,0x00,0x00,0x00,0x00,
0x01,0xFF,0x80,0x03,0xFF,0xC0,0x03,0xFF,0xC0,0x03,0xFF,0xC0,0x03,0xFF,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,
0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,
0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x0F,0xE7,0xF0,
0x1F,0xE7,0xF8,0x1F,0xE7,0xF8,0x1F,0xE7,0xF8,0x1F,0xC3,0xF8,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0xC1,0xF0,0x07,0xC3,0xE0,0x07,
0xC3,0xE0,0x07,0xC3,0xE0,0x07,0xC3,0xE0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x03,0xE7,0xC0,0x01,0xFF,0x80,0x01,0xFF,0x80,0x01,0xFF,
0x80,0x01,0xFF,0x80,0x00,0xFF,0x80,0x00,0xFF,0x00,0x00,0xFF,0x00,0x00,0xFF,0x00,0x00,0x7F,0x00,0x00,0x7E,0x00,0x00,0x7E,0x00,0x00,0x7E,0x00,
0x00,0x7E,0x00,0x00,0x3C,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0x80,0x03,0xFF,0xC0,0x07,0xFF,0xC0,0x07,0xFF,0xE0,0x07,0xFF,0xE0,
0x07,0xC3,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,
0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF8,0x0F,0x80,0xF8,0x0F,0x80,0xF8,0x0F,0x80,0xF8,0x0F,0x80,0xF8,0x0F,0x81,0xF8,0x0F,0x81,0xF0,0x0F,0x81,
0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,
0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,
0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,
0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xF0,0x0F,0x81,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x0F,0x83,0xE0,0x07,0xC3,0xE0,0x07,0xFF,0xE0,0x07,0xFF,0xE0,
0x07,0xFF,0xC0,0x03,0xFF,0xC0,0x01,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0d,0x0a,
0x1B,0x40,
0x1b,0x2a,0x00,0x0C,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,                                                       //Print a division line
0x1B,0x33,0x00,
0x0A,
0x1D,0x2F,0x30        //Print bitmap instruction
Your printer was reviewed by upir, and he shows how to print graphics.
If you look that up in the manual, that is
ESC * m Hl Hh (cmd #34 in the manual)
in you case m = 0x20 or 32 so you are in 24-point Single density mode with 1x vertial and 2x horizontal density
Hl = 0xFA (250) and Hh = 0x00 (0) so your width is 250 + 0 * 256 = 250
The rest is data
Your show array is 770 bytes, not 823.
Also be careful with whether the library expects the bitmap to be in PROGMEM or ram.
Thanks, I have done some test an can print logo from 24 x 250 or lower than 250 as I can change the width. I canot get my head arround the height.
how do I print pictures that are like 250 x 250 ?
THanks
send more data....
The example code is 24 lines long by 250 bits wide. If you doubled it, you'd have 48 lines, etc.
Did you watch the video from #2? There is a link to a site for converting images to the hex array and back.
Yes I followed the tutorial and use all the online tool. The bitmap logo is displayed as Vertical. But it prints horizontaly on the printer. Same behaviour as the video tutorial : Printing with Arduino - YouTube (6'27)
I don't get how to really print in vertical
I followed the exact same tutorial and can go as far as he does before using Adafruit library. With Adafruit library the bitmap is giberish.
Okay. Would you post a picture of the output?
It will probably be how the image was encoded (read vertical, read horizontal, output as (arduino, adafruit)...)
You could also try your image with this page...
https://javl.github.io/image2cpp/
Thanks for looking into this, really. I am actualy already using : image2cpp
The BMP is 24x250 as in the array below - Read as Horizontal on javl Github
Output : Somewhat sending weird characters & the logo is printed horizontaly
// Print some special characters
  printer.boldOn();
  printer.println("Bold Text");
  printer.boldOff();
  printer.println("Normal Text");
  printer.feed(3);  // Feed 3 lines
  mySerial.write(show,sizeof(show));     //Send “print bitmap instruction” to printer
24x250 BPM
0x1B, 0x2A, 0x20, 0xFA, 0x00,   //Bitmap size: 24*250, revise parameter with the reference of general instruction set 34 and 35.
//0x1b,0x2a,0x00,0x0C,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,                                                       //Print a division line
//0x1B,0x33,0x00,
//0x0A,
//0x1D,0x2F,0x30        //Print bitmap instruction
Another test with a 100x100 BMP
0x1B, 0x2A, 0x20, 0x64, 0x00,   //Bitmap size: 100*100, revise parameter with the reference of general instruction set 34 and 35.
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xff,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x3f, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f,
  0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xc0, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0xff, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0xff, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x1f, 0xf0,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x0f, 0xf0, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x0f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x03, 0xfe, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x03, 0xfc, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xfc, 0x0f,
  0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x03, 0xfc, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x03, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x0f, 0xf8, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xf8, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0,
  0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x01, 0xff, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0xff, 0x80, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x3f, 0xe0, 0x00, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f,
  0xc0, 0x00, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xc0, 0x00, 0x7f,
  0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xc0, 0x00, 0x7f, 0xc0, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xc0, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0xff, 0xc0, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
  0xff, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0x00, 0x00,
  0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x1f, 0xf0, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x0f, 0xf8, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x03, 0xfe, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00,
  0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x0f, 0xfc,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x03, 0xfe, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xf8, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf8,
  0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x03,
  0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf8, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f,
  0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff,
  0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00,
  0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x3f,
  0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xf8, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xfe, 0x00,
  0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00,
  0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x07, 0xfc, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf8,
  0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf8, 0x00, 0x00, 0x00,
  0x00, 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff,
  0x80, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0x80, 0x00, 0x00,
  0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x3f,
  0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00,
  0x00, 0x00, 0x00, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
//0x1B,0x33,0x00,
//0x0A,
Spec of the printer
For the random characters... verify the printer and the arduino are grounded together.
I am not certain what you want the graphic to look like, but try these check-boxes...
Maybe hand-draw (MS Paint, or on the printout) how you want the graphic to look.
I tried a square with a big letter in.. The output is a mess. All grounds connected
But the "circle arrow square" looks good... are you using the "Arduino" format?
Does the image2cpp page have "code type, char type and language" as the self-test.
(the self test prints well, so it's a code, data or connection issue)
