b4ip
September 16, 2015, 2:12pm
#1
I’m using the Adafruit Chronodot with RTClib.h (RTC_DS1307)
My code connects to a time server which gives me the current UNIX time (number of seconds since 1/1/1970 UTC) as an unsigned long.
How do I convert this value into human readable date and time values so I can set the date/time?
My function to set the date time:
void RTCSetDateTime(char *theDate, char *theTime)
RTC.adjust(DateTime(theDate, theTime));
Example:
char myDate = “Sep 05 2015”;
char myTime = “14:37:30”;
RTCSetDateTime(my_date, my_time);
Also, if I include <Time.h> then I get a stack of compile errors that seem to conflict with RTCLib.
Have you looked at the now() function in DateTime?
http://playground.arduino.cc/Code/DateTime
Hi, Also, perhaps Adafruit can assist since I assume the library has been provided by them ?
b4ip
September 16, 2015, 3:24pm
#4
SOLVED:
Thanks for the responses but it was simple once I worked out how the "adjust" method and the DateTime object works. It seems DateTime has at least one override.
I just had to create the DateTime object by passing in the epoch rather than passing in 2 variables as char arrays that represent the date/time in human readable format.
rtc.adjust(DateTime(theDate, theTime));
unsigned long offset = 36000;
void RTCSetDateTimeFromEpoch(unsigned long t)
t += offset;
rtc.adjust(DateTime(t));
b4ip
September 16, 2015, 4:23pm
#6
That was quick. Yes, Sydney time. Up late hacking Arduino.
