Hey all,
Hopefully I have setup this question correctly. I have been trying to implement the Arduino FreeRTOS into my robotics project but have run into some issues. The purpose of my code is to read the distance from 4 time of flight sensors on a robot and output them onto the serial monitor (see working code). I tried to implement the FreeRTOS into my code but now I dont get any serial outputs, i.e my serial monitor is blank.
So far I've tried working up from scratch with the code (starting from a blank working FreeRTOS project and slowly adding my code bit by bit) to see what breaks it, however what occurs is at a certain point of adding code my serial monitor displays the first string I print cut of and repeating (i.e Serial.println("Serial Started") is my first serial print and my monitor outputs Serial StSerialStSerialSt etc)
Any assistance is greatly appreciated, I am rather new to Arduino and the forums so any help on formatting my posts better is also welcome.
WORKING CODE WITHOUT RTOS:
SHT = Shutdown Pin
#include "Adafruit_VL53L0X.h"
#define FL_TOF_ADRESS 0x2A
#define FR_TOF_ADRESS 0x2D
#define BL_TOF_ADRESS 0x2C
#define BR_TOF_ADRESS 0x19
#define SHT_FL_TOF 10
#define SHT_FR_TOF 9
#define SHT_BL_TOF 5
#define SHT_BR_TOF 7
Adafruit_VL53L0X frontLeftTOF = Adafruit_VL53L0X();
Adafruit_VL53L0X frontRightTOF = Adafruit_VL53L0X();
Adafruit_VL53L0X backLeftTOF = Adafruit_VL53L0X();
Adafruit_VL53L0X backRightTOF = Adafruit_VL53L0X();
VL53L0X_RangingMeasurementData_t distFL;
VL53L0X_RangingMeasurementData_t distFR;
VL53L0X_RangingMeasurementData_t distBL;
VL53L0X_RangingMeasurementData_t distBR;
void setRangingSensorAdresses() {
// all reset
digitalWrite(SHT_FL_TOF, LOW);
digitalWrite(SHT_FR_TOF, LOW);
digitalWrite(SHT_BL_TOF, LOW);
digitalWrite(SHT_BR_TOF, LOW);
delay(10);
// all unreset
digitalWrite(SHT_FL_TOF, HIGH);
digitalWrite(SHT_FR_TOF, HIGH);
digitalWrite(SHT_BL_TOF, HIGH);
digitalWrite(SHT_BR_TOF, HIGH);
delay(10);
//Front Left TOF sensor intitialisation
if(!frontLeftTOF.begin(FL_TOF_ADRESS)) {
Serial.println(F("Failed to boot first VL53L0X"));
while(1);
delay(10);
//Front Right TOF sensor intitialisation
delay(10);
if(!frontRightTOF.begin(FR_TOF_ADRESS)) {
Serial.println(F("Failed to boot second VL53L0X"));
while(1);
//Back Left TOF sensor intitialisation
delay(10);
if(!backLeftTOF.begin(BL_TOF_ADRESS)) {
Serial.println(F("Failed to boot third VL53L0X"));
while(1);
//Back Right TOF sensor intitialisation
delay(10);
if(!backRightTOF.begin(BR_TOF_ADRESS)) {
Serial.println(F("Failed to boot fourth VL53L0X"));
while(1);
void readSensors() {
frontLeftTOF.rangingTest(&distFL, false); // pass in 'true' to get debug data printout!
frontRightTOF.rangingTest(&distFR, false);
backLeftTOF.rangingTest(&distBL, false);
backRightTOF.rangingTest(&distBR, false);
// print sensor one reading
Serial.print(F("FL: "));
if(distFL.RangeStatus != 4) { // if not out of range
Serial.print(distFL.RangeMilliMeter);
Serial.print(F("Out of range"));
Serial.print(F(" "));
// print sensor two reading
Serial.print(F("FR: "));
if(distFR.RangeStatus != 4) {
Serial.print(distFR.RangeMilliMeter);
Serial.print(F("BL: "));
if(distBL.RangeStatus != 4) {
Serial.print(distBL.RangeMilliMeter);
Serial.print(F("BR: "));
if(distBR.RangeStatus != 4) {
Serial.print(distBR.RangeMilliMeter);
//Serial
while (! Serial) { delay(1); }
delay(100);
Serial.println(F("Serial initialised"));
//TOF Sensor intitialisation
pinMode(SHT_FL_TOF, OUTPUT);
pinMode(SHT_FR_TOF, OUTPUT);
pinMode(SHT_BL_TOF, OUTPUT);
pinMode(SHT_BR_TOF, OUTPUT);
Serial.println(F("Shutdown pins initialised"));
Serial.println(F("Shutdown pins Activated"));
setRangingSensorAdresses();
readSensors();
delay(10);
NOT WORKING CODE WITH RTOS:
SHT = Shutdown Pin
#include <Arduino_FreeRTOS.h>
delay(100);
Serial.println("Serial initialised");
xTaskCreate(sensing, "Sensing", 256, NULL, 1, NULL);
xTaskCreate(myLoop, "Loop", 256, NULL, 2, NULL);
delay(200);
vTaskStartScheduler();
// all reset
delay(10);
// all unreset
delay(10);
while(1);
delay(10);
delay(10);
while(1);
delay(10);
while(1);
delay(10);
while(1);
void sensing(void *pvParameters) {
for(;;) {
readSensors();
delay(150);
void myLoop(void *pvParameters) {
for(;;){
delay(10);
Serial.println(F("Test"));
void loop(){
for(;;){
