Time question "Simple right"
I'm not posting my code as I'm a newb and it's really ugly. Just want your best guess
time.h library
Why do I get 12 hour time format from this.
Serial.println(timeinfo.tm_hour);
Everything I read says it should be 24 hour
ESP32-2432S028R
Edit %I and %h return 12 hour also I need 24 hour format
I just ran the simpletime example in the Arduino IDE, and here is the output:
Got time adjustment from NTP!
Monday, December 23 2024 22:34:05
Without seeing your code, it is impossible to really pinpoint your error.
I run that sketch and I do return 24 hour time, Hmmmm. Is there and command or structure that would change it to 12 hour for the whole sketch
Yes, the output is formatted
Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
Way too much text, posting is refufused.
This is strange, this part of my code is working????
if (timeinfo.tm_hour < 12) {
tft.setTextDatum(MC_DATUM);
tft.drawString("Good Afternoon Bob", tft.width() / 2, 20);
Look at this code from this article:
Serial.print("Day of week: ");
Serial.println(&timeinfo, "%A");
Serial.print("Month: ");
Serial.println(&timeinfo, "%B");
Serial.print("Day of Month: ");
Serial.println(&timeinfo, "%d");
Serial.print("Year: ");
Serial.println(&timeinfo, "%Y");
Serial.print("Hour: ");
Serial.println(&timeinfo, "%H");
Serial.print("Hour (12 hour format): ");
Serial.println(&timeinfo, "%I");
Serial.print("Minute: ");
Serial.println(&timeinfo, "%M");
Serial.print("Second: ");
Serial.println(&timeinfo, "%S");
Again, without seeing what you are doing, I am guessing this may help, but I have no way of knowing.
What is the project. Your last year's hollow clock?
You shouldn't use the time.h library or any other time library with an ESP32 any more, assuming you don't use a RTC (not needed). It's now all built into the current ESP core.
This basic example is the easy way. It gives you the local time, including daylight savings, and all the time elements. Just enter your WiFi credentials, enter your location (link is in the code), and choose your local NTP pool (or use "pool.ntp.org"). By default it will sync every 3 hours, and keeps time within one second.
Leo..
#include <WiFi.h> // ESP32
unsigned long prevTime;
time_t now; // holds epoch
tm tm; // create time struct
  WiFi.begin("SSID", "PW");
  configTzTime("NZST-12NZDT,M9.5.0,M4.1.0/3", "nz.pool.ntp.org"); // https://github.com/nayarsystems/posix_tz_db/blob/master/zones.csv
  time(&now);
  if (now != prevTime) { // time has changed?
    prevTime = now; // remember
    localtime_r(&now, &tm); // compute local time
    printf("\n%02u:%02u:%02u", tm.tm_hour, tm.tm_min, tm.tm_sec); // print
I'm going to try and modify my code to what Wawa posted, if I get no where I'll post my ugly mess of a code. Thanks for the input so far.
There is also an easy way to wait for the correct internet time, before displaying it.
I can post additional code for that if needed.
You can find a list of the time elements here (click).
The below addition should print in 12-hour format (untested).
Leo..
      if(tm.tm.hour > 12) tm.tm.hour -= 12; // 12-hour format
#include "SPI.h"
#include "TFT_eSPI.h"
#include <WiFi.h>
#include "time.h"
#include <HTTPClient.h>
#include <Arduino_JSON.h>
#include <XPT2046_Touchscreen.h>
int a = 0;
// Use hardware SPI
TFT_eSPI tft = TFT_eSPI();
// Touchscreen pins
#define XPT2046_IRQ 36   // T_IRQ
#define XPT2046_MOSI 32  // T_DIN
#define XPT2046_MISO 39  // T_OUT
#define XPT2046_CLK 25   // T_CLK
#define XPT2046_CS 33    // T_CS
int tch;
int bg;
int x, y, z;
SPIClass touchscreenSPI = SPIClass(VSPI);
XPT2046_Touchscreen touchscreen(XPT2046_CS, XPT2046_IRQ);
unsigned long drawTime = 0;
const char* ssid = "MBR";
const char* password = "cradlepoint";
const char* ntpServer = "pool.ntp.org";
const long gmtOffset_sec = 21600;
const int daylightOffset_sec = 3600;
unsigned long lastTime = 0;
unsigned long lastTime2 = 0;
unsigned long timerDelay = 20000;
unsigned long timerDelay2 = 2000;
String jsonBuffer;
struct tm timeinfo;
  touchscreenSPI.begin(XPT2046_CLK, XPT2046_MISO, XPT2046_MOSI, XPT2046_CS);
  touchscreen.begin(touchscreenSPI);
  tft.invertDisplay( true );
  // Set the Touchscreen rotation in landscape mode
  // Note: in some displays, the touchscreen might be upside down, so you might need to set the rotation to 3: touchscreen.setRotation(3);
  touchscreen.setRotation(1);
  int touchZ;
  tft.begin();
  tft.setRotation(3.5);
  tft.fillScreen(TFT_BLACK);
  tft.setTextSize(2);
  WiFi.begin(ssid, password);
  tft.println("Connecting");
    tft.print(".");
  tft.println("");
  tft.print("Connected to  ");
  tft.println(ssid);
  tft.println(WiFi.localIP());
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  printLocalTime();
  //Serial.println("Timer set to 10 seconds (timerDelay variable), it will take 10 seconds before publishing the first reading.");
  //int touchZ;
  TS_Point p = touchscreen.getPoint();
  tch = p.z;
  getLocalTime(&timeinfo);
  printLocalTime();
   tft.invertDisplay( false );
 if ((millis() - lastTime2) > timerDelay2) {
  if (tch > 200) bg=bg+1;
  if (bg>4) bg=0;
    //Serial.println(&timeinfo, "%H");
if (bg==0)  tft.fillScreen(TFT_YELLOW);
if (bg==1)  tft.fillScreen(TFT_WHITE);
if (bg==2)  tft.fillScreen(TFT_NAVY);
if (bg==3)  tft.fillScreen(TFT_VIOLET);
if (bg==4)  tft.fillScreen(TFT_RED);
   tft.setTextColor(TFT_WHITE);
  tft.setTextSize(2);
  tft.setCursor(10, 10);
  if (timeinfo.tm_hour > 12) {
    tft.drawString("Good Morning Bob", tft.width() / 2, 20);
    //tft.print("Good afternoon Bob");
  //Serial.println(timeinfo.tm_hour);
  tft.setCursor(90, 40);
  tft.setTextSize(2);
  tft.print("The time is");
  tft.setTextColor(TFT_GREEN);
  tft.setCursor(70, 70);
  tft.setTextSize(6);
  tft.println(&timeinfo, "%I:%M");
  tft.setTextSize(2);
  tft.drawString("The Date is", tft.width() / 2, 130);
  tft.setCursor(30, 140);
  tft.print(&timeinfo, " %A,%B,%d");
  //Serial.println(&timeinfo, "%A, %B %d %Y %h:%M:%S");
  JSONVar myObject = JSON.parse(jsonBuffer);
  tft.setCursor(15, 170);
  a = (myObject["main"]["temp"]);
  tft.print("Temp is: ");
  tft.setTextSize(6);
  tft.print(a, 0);
  tft.setTextSize(3);
  tft.print("o ");
  tft.setTextSize(6);
  tft.print("F");
  tft.setTextSize(2);
  tft.setCursor(15, 220);
  tft.print("Miller Time in");
  //Serial.println(timeinfo.tm_min);
  Serial.println(bg);
  Serial.println(tch);
lastTime2 = millis();
  //delay(5000);
  if ((millis() - lastTime) > timerDelay) {
    // Check WiFi connection status
    if (WiFi.status() == WL_CONNECTED) {
      String serverPath = "http://api.openweathermap.org/data/2.5/weather?q=rochester,mn,us&&units=imperial&appid=643b2895bb04f51dbdd5687d86203e28";
      jsonBuffer = httpGETRequest(serverPath.c_str());
      // JSON.typeof(jsonVar) can be used to get the type of the var
      if (JSON.typeof(myObject) == "undefined") {
        Serial.println("Parsing input failed!");
        return;
      //Serial.print("Temperature: ");
      Serial.println(myObject["main"]["temp"]);
      Serial.println("WiFi Disconnected");
    lastTime = millis();
String httpGETRequest(const char* serverName) {
  WiFiClient client;
  HTTPClient http;
  // Your Domain name with URL path or IP address with path
  http.begin(client, serverName);
  // Send HTTP POST request
  int httpResponseCode = http.GET();
  String payload = "{}";
  if (httpResponseCode > 0) {
    payload = http.getString();
    Serial.print("Error code: ");
    Serial.println(httpResponseCode);
  // Free resources
  //http.end();
  printLocalTime();
  return payload;}
void printLocalTime() {
  struct tm timeinfo;
  if (!getLocalTime(&timeinfo)) {
    tft.println("Failed to obtain time");
    return;
Here is my UGLY code, I know there are a million ways to make this better, but I'm damn proud of myself for getting this far. The last language I knew was Apple basic on a IIe.
Doesn't "afternoon" come after 12 o'clock? Why do you write about it BEFORE 12?
The same about morning
That explains why it works then, it overwrites the good morning after 12.
