Timer for Signal Switch on hot rod New To Audrino need help on topics to research
Here's a sketch from a thread asking about a problem that is similar if you squint at it just right. If you can figure it, you will have learned a few of the little things that you'll need to know to succeed.
Try it here:
Wokwi_badge UA Keep Alive For
This is the thread, reading it might be a jump start.
The code:
// https://forum.arduino.cc/t/how-to-delay-using-millis/1142938
// https://wokwi.com/projects/368911815269434369
// version 4. remove any debouncing
const byte buttonPin = 2;
const byte ledPin = 3;
const unsigned long actionDelay = 3500; // action 3.5 seconds for testing - life too short
  Serial.println("\nWake up!\n");
  pinMode (buttonPin, INPUT_PULLUP);
  pinMode (ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  static unsigned long startTime; // time at action
  unsigned long now = millis();   // fancier 'currentMillis' ooh!
  bool buttonState = digitalRead(buttonPin) == LOW;  // button pulled up! true is button pressed
// when the button is pressed, reset the timer, turn ON the LED
  if (buttonState) {
    startTime = now;
    digitalWrite(ledPin, HIGH);
// when (if!) the timer expires, turn OFF the LED
  if (now - startTime >= actionDelay) {
HTH
a7
