Hi guys ! Anyone of you know why there are two kinds of timer interrupt, a CTC mode and a normal mode? What is the different between both of them? Is there any advantages or disadvantages when you use either one of them?
CTC mode:
void setup(){
cli();//stop interrupts
//set timer0 interrupt at 2kHz
TCCR0A = 0;// set entire TCCR0A register to 0
TCCR0B = 0;// same for TCCR0B
TCNT0 = 0;//initialize counter value to 0
// set compare match register for 2khz increments
OCR0A = 124;// = (1610^6) / (200064) - 1 (must be <256)
// turn on CTC mode
TCCR0A |= (1 << WGM01);
// Set CS01 and CS00 bits for 64 prescaler
TCCR0B |= (1 << CS01) | (1 << CS00);
// enable timer compare interrupt
TIMSK0 |= (1 << OCIE0A);
//set timer1 interrupt at 1Hz
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;//initialize counter value to 0
// set compare match register for 1hz increments
OCR1A = 15624;// = (1610^6) / (11024) - 1 (must be <65536)
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS10 and CS12 bits for 1024 prescaler
TCCR1B |= (1 << CS12) | (1 << CS10);
TIMSK1 |= (1 << OCIE1A);
//set timer2 interrupt at 8kHz
TCCR2A = 0;// set entire TCCR2A register to 0
TCCR2B = 0;// same for TCCR2B
TCNT2 = 0;//initialize counter value to 0
// set compare match register for 8khz increments
OCR2A = 249;// = (1610^6) / (80008) - 1 (must be <256)
// turn on CTC mode
TCCR2A |= (1 << WGM21);
// Set CS21 bit for 8 prescaler
TCCR2B |= (1 << CS21);
TIMSK2 |= (1 << OCIE2A);
sei();//allow interrupts
}//end setup
normal mode:
#include <TimerThree.h>
// This example uses the timer interrupt to blink an LED
// and also demonstrates how to share a variable between
// the interrupt and the main program.
const int led = LED_BUILTIN; // the pin with a LED
void setup(void)
pinMode(led, OUTPUT);
Timer3.initialize(150000);
Timer3.attachInterrupt(blinkLED); // blinkLED to run every 0.15 seconds
// The interrupt will blink the LED, and keep
// track of how many times it has blinked.
int ledState = LOW;
volatile unsigned long blinkCount = 0; // use volatile for shared variables
void blinkLED(void)
if (ledState == LOW) {
ledState = HIGH;
blinkCount = blinkCount + 1; // increase when LED turns on
ledState = LOW;
digitalWrite(led, ledState);
// The main program will print the blink count
// to the Arduino Serial Monitor
void loop(void)
unsigned long blinkCopy; // holds a copy of the blinkCount
// to read a variable which the interrupt code writes, we
// must temporarily disable interrupts, to be sure it will
// not change while we are reading. To minimize the time
// with interrupts off, just quickly make a copy, and then
// use the copy while allowing the interrupt to keep working.
noInterrupts();
blinkCopy = blinkCount;
interrupts();
Serial.print("blinkCount = ");
Serial.println(blinkCopy);
delay(100);
