Timer Interrupts on Due
I've been searching through the library code as well as thoroughly searched Google and haven't come across any working timer interrupt code for the Due. I could do this on the Uno in my sleep, but have yet to figure it out on the Due. Any pointers (xkcd: Pointers) or example code would be greatly appreciated. Basically I want to get a function to run once every X microseconds. Thanks.
Yeah, I was hoping to get timer interrupt hints on my thread for Tone.cpp code. I've done timers on Uno and Maple, but Maple IO architecture is quite different from DUE. There is PWM timer code in
hardware/arduino/sam/cores/arduino/wiring_analog.c
but no interrupt code. The Timer/Counter support routines (no interrupt routines) are in
hardware/arduino/sam/system/libsam/source/tc.c
with the #define's in
hardware/arduino/sam/system/CMSIS/Device/ATMEL/sam3sd8/include/component/component_tc.h
The ISR handler's are named TCx_Handler(), e.g. TC0_Handler()
I'm guessing (don't have a DUE yet) that interrupt enable would be something like
tc->TC_CHANNEL[chan].TC_IER = TC_IER_CPCS;
but there is also an interrupt mask register TC_IMR?
not much help, but hopeful ...
I think I'm getting somewhere with this... try this:
volatile boolean l;
void TC0_Handler()
    long dummy=REG_TC0_SR0; // vital - reading this clears some flag
                            // otherwise you get infinite interrupts
    l= !l;
void setup(){
  pinMode(13,OUTPUT);
  pinMode(2,OUTPUT);    // port B pin 25
  analogWrite(2,255);   // sets up some other registers I haven't worked out yet
  REG_PIOB_PDR = 1<<25; // disable PIO, enable peripheral
  REG_PIOB_ABSR= 1<<25; // select peripheral B
  REG_TC0_WPMR=0x54494D00; // enable write to registers
  REG_TC0_CMR0=0b00000000000010011100010000000000; // set channel mode register (see datasheet)
  REG_TC0_RC0=100000000; // counter period
  REG_TC0_RA0=30000000;  // PWM value
  REG_TC0_CCR0=0b101;    // start counter
  REG_TC0_IER0=0b00010000; // enable interrupt on counter=rc
  REG_TC0_IDR0=0b11101111; // disable other interrupts
  NVIC_EnableIRQ(TC0_IRQn); // enable TC0 interrupts
void loop(){
      digitalWrite(13,l);
The timer controls the output of pin 2 and the interrupt toggles a flag which is output on pin 13.
Whats the best resource you have found for describing the timer registers ?
Thanks
Duane B
rcarduino.blogspot.com
Not what you're looking for, but on a similar topic:
I wanted to use the TC* timers to create a software servo library but I couldn't find out how to use the timers so I ended up using the PWM clock to generate the output.
While testing the PWM pulse I used attachInterrupt on the same pin to measure the pulse timing, effectively creating software interrupts. It's a hack, but if you're interested the code is here: http://arduino.cc/forum/index.php/topic,130631.0.html
It doesn't use any registers, so I can't tell you about those - just add attachInterrupt()
timer/counter registers are detailed in chapter 37 of datasheet
stimmer:
volatile boolean l;
void TC0_Handler()
    l= !l;
void setup(){
  pinMode(13,OUTPUT);
void loop(){
      digitalWrite(13,l);
I'll give this a shot thanks. I am curious though why you didn't do a digitalWrite() inside the handler? Arduino's digitalWrite() function is pretty clock-cycle heavy, but the following code works just fine for writing a digital output and only takes a couple of clock cycles if that was the primary concern.
static inline void pinOutput(int pin, int val)
	if (val)
		g_APinDescription[pin].pPort->PIO_SODR = g_APinDescription[pin].ulPin;
		g_APinDescription[pin].pPort->PIO_CODR = g_APinDescription[pin].ulPin;
On another note, Maple uses a different processor, but gives as good of an explanation / example of how timers work as I've found so far:
I haven't tried to implement any of their code yet, but thought I'd share the links.
I recognize that code fragment 8)
As for digitalWrite not being in the handler, actually it was there originally, but you have to understand that I'd been struggling for hours with interrupt code that wouldn't fire, then it only fired once, then it got hammered with constant interrupts, and I didn't know what was going on. So I did what is pretty much standard debugging practice and changed the interrupt handler to do the absolute bare minimum just to be sure that digitalWrite wasn't causing a side effect (there's some architectures where you can't write certain registers in an interrupt). But the important thing turned out to be the dummy read of TC_SR0. By then it was late so I just posted what I'd done.
Since then I have tried putting digitalWrite and direct port writes back in and they don't seem to cause any odd side effects.
The Maple hardware is completely different unfortunately and the registers are incompatible.
I understand. Thanks :slight_smile:
Using this code, you can set a timer for any of the ISRs TC0_Handler through TC8_Handler, see table of parameters below. It is possible to use the timers without a physically mapped pin, such as TC1 channel 0 (TC3_Handler) shown here:
volatile boolean l;
//TC1 ch 0
void TC3_Handler()
        TC_GetStatus(TC1, 0);
        digitalWrite(13, l = !l);
void startTimer(Tc *tc, uint32_t channel, IRQn_Type irq, uint32_t frequency) {
        pmc_set_writeprotect(false);
        pmc_enable_periph_clk((uint32_t)irq);
        TC_Configure(tc, channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK4);
        uint32_t rc = VARIANT_MCK/128/frequency; //128 because we selected TIMER_CLOCK4 above
        TC_SetRA(tc, channel, rc/2); //50% high, 50% low
        TC_SetRC(tc, channel, rc);
        TC_Start(tc, channel);
        tc->TC_CHANNEL[channel].TC_IER=TC_IER_CPCS;
        tc->TC_CHANNEL[channel].TC_IDR=~TC_IER_CPCS;
        NVIC_EnableIRQ(irq);
void setup(){
        pinMode(13,OUTPUT);
        startTimer(TC1, 0, TC3_IRQn, 4); //TC1 channel 0, the IRQ for that channel and the desired frequency
void loop(){
Here is the table of parameters:
ISR/IRQ TC Channel Due pins
TC0 TC0 0 2, 13
TC1 TC0 1 60, 61
TC2 TC0 2 58
TC3 TC1 0 none <- this line in the example above
TC4 TC1 1 none
TC5 TC1 2 none
TC6 TC2 0 4, 5
TC7 TC2 1 3, 10
TC8 TC2 2 11, 12
Sebastian:
Well done! thanks
Noob question here, could someone please explain the inputs to the startTimer function? What is channel, and how do we use the frequency input? Also, what are the pins in the table for?
Same question; please explain the inputs to the startTimer function.
Are there any ready-to-use-libs (like Arduino Playground - Timer1) for using Hardware Timer on Due?
Or is there a beginner-friendly How-To (like http://www.engblaze.com/microcontroller-tutorial-avr-and-arduino-timer-interrupts/) for the Due?
A brief explanation:
The SAM3X8E CPU has 3 Timer Counters (TC) they are called TC0, TC1, TC2.
Every Timer Counter contains 3 Channels numbered 0, 1 and 2 (this give us a total of 9 Channels).
Every Channel has its own counters and interrupt handler that are independent from other Channels.
In other words each Channel can be considered as a separate "Timer", and is like having 9 separate timers.
To initialize a Channel you need the following parameters:
TC0/TC1/TC2 - The Timer Counter instance
0 / 1 / 2 - The Channel number inside Timer Counter
If you want to use interrupts you must enable the NVIC (Nested Vector Interrupt Controller) for that channel with:
NVIC_EnableIRQ(TCx_IRQn);
where TCx_IRQn is the ID of the interrupt to enable. These id are listed in the following table together with the ISR handler function name:
TC Chan NVIC "irq" IRQ handler function PMC id
TC0 0 TC0_IRQn TC0_Handler ID_TC0
TC0 1 TC1_IRQn TC1_Handler ID_TC1
TC0 2 TC2_IRQn TC2_Handler ID_TC2
TC1 0 TC3_IRQn TC3_Handler ID_TC3
TC1 1 TC4_IRQn TC4_Handler ID_TC4
TC1 2 TC5_IRQn TC5_Handler ID_TC5
TC2 0 TC6_IRQn TC6_Handler ID_TC6
TC2 1 TC7_IRQn TC7_Handler ID_TC7
TC2 2 TC8_IRQn TC8_Handler ID_TC8
(note that TC2_IRQn is the irq id for TC0-channel-2 not for TC2...)
but this is still not enough! Every peripheral in the SAM3X is off by default (to save power) and should be turned on. To turn on you need to run the following command:
pmc_enable_periph_clk(id);
where id is found on the last column of the above table (ID_TCx). It happened that ID_TCx constant equals TCx_IRQn, so Sebastian Vik has simplified a bit the function using TCx_IRQn as input for pmc_enable_periph_clk:
Hope this helps to decode whats happening with timers inside SAM3X.
Selachii:
Are there any ready-to-use-libs (like http://www.arduino.cc/playground/Code/Timer1) for using Hardware Timer on Due?
Nope, there are no libs neither tutorials.
I've planned a SAM3Timer library (to simplify implementation of Arduino Core and some libraries) but I didn't started it yet.
Volunteers? :slight_smile:
Send me a Due and I will write some libraries for it.
Duane B
Quote from: Sebastian Vik on November 05, 2012, 08:48:40 PM
TC0 TC0 0 2, 13
TC1 TC0 1 60, 61
TC2 TC0 2 58
TC4 TC1 1 none
TC5 TC1 2 none
TC6 TC2 0 4, 5
TC7 TC2 1 3, 10
TC8 TC2 2 11, 12
Code:
Code:
Code:
Thank you for your detailed answer.
Can somebody explain the following code?
I want to use it to execute a function after every XY CPU counts:
mnpumar:
Good question! If I understood everything correctly, the pins in the table are where you could output the clock of that timer/counter if you wanted to use it for something else than internal software interrupts.
Basically you can set up the hardware counter to output a clock signal. For example, TC0 channel 0 could be used to output a clock on the Arduino pin 2 or 13. So if you use TC0 channel 0 for your timer, you would not be able to output a clock on those pins (except using the frequency you set up the channel for).
That is why it would be better to use TC1 channels 0, 1 or 2 primarily for this kind of interrupt, as their output is not mapped to any of the Arduino pins and therefore does not limit any of your physically mapped outputs.
I have the same question. I'm trying to create an Interrupt every 62.5 microseconds but I'm incapable! Do you know if it is possible and if it is how should I proceed? As I have understand I should modify the variable RC and reading through the net I came with a possible answer being (VARIAN_MCK/8)/SPEED of transmission (I need the interruption to modify the VirtualWire library for the DUE, which I have almost done ;)) but it doesn't work!
You should use the code Sebastian Vik already posted, I've slightly rewrite it with some comments
// Black magic
void setup(){
  pinMode(13,OUTPUT);
  // Start timer. Parameters are:
  // TC1 : timer counter. Can be TC0, TC1 or TC2
  // 0   : channel. Can be 0, 1 or 2
  // TC3_IRQn: irq number. See table.
  // 40  : frequency (in Hz)
  // The interrupt service routine is TC3_Handler. See table.
  startTimer(TC1, 0, TC3_IRQn, 40);
  // Paramters table:
  // TC0, 0, TC0_IRQn  =>  TC0_Handler()
  // TC0, 1, TC1_IRQn  =>  TC1_Handler()
  // TC0, 2, TC2_IRQn  =>  TC2_Handler()
  // TC1, 0, TC3_IRQn  =>  TC3_Handler()
  // TC1, 1, TC4_IRQn  =>  TC4_Handler()
  // TC1, 2, TC5_IRQn  =>  TC5_Handler()
  // TC2, 0, TC6_IRQn  =>  TC6_Handler()
  // TC2, 1, TC7_IRQn  =>  TC7_Handler()
  // TC2, 2, TC8_IRQn  =>  TC8_Handler()
void loop(){
volatile boolean l;
// This function is called every 1/40 sec.
void TC3_Handler()
  // You must do TC_GetStatus to "accept" interrupt
  // As parameters use the first two parameters used in startTimer (TC1, 0 in this case)
ForcisConnect:
62.5 uS is 1000000/62.5 = 16000 Hz, use that value as last parameter of startTimer.
