I'm sorry, my code is messy .... but it works, I finally found out how to make a timer per minute, for example 5 minutes on and 5 off, I hardly realized using a counter you can set the intervals, now I still have to solve the problem when we use for example 50 minutes on and 50 off, thus exceeding the limit of 60 ... I AM REFERRING TO RELAY4.
For small intervals example 1 on 1 of or 10 on 10 off, it works well ... someone more experienced than me could help me ... because I honestly got confused
#include <Wire.h>
#include <SPI.h>
#define DS3231_I2C_ADDRESS 0x68
byte DecToBcd(byte val)
return( (val/10*16) + (val%10) );
byte BcdToDec(byte val)
return( (val/16*10) + (val%16) );
int relay4 = 9;
int relay4_start = 10; // relay 4 is for the fan, it is based on minutes, how many minutes on or how many minutes off
int relay4_off = 20 ; //
Wire.begin();
pinMode(relay4,OUTPUT);
digitalWrite(relay4, HIGH);
//setDS3231time(00,10,12,5,29,1,21); //secs min hours day of week day of month month year
displayTime();
start_relay4();
void start_relay4()
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,&year);
int var=0;
int var2=0;
int i;
int dif=0;
while (var<60)
var = var+relay4_start;
var2++;
var=var+relay4_off;
Serial.println(var2);
if( minute <=relay4_start )
digitalWrite(relay4,LOW);
Serial.print("0");
Serial.print(" ON ");
Serial.println(relay4_start);
else if(minute > relay4_start && minute< relay4_start+relay4_off)
digitalWrite(relay4,HIGH);
Serial.print(relay4_start+relay4_off);
Serial.print(" OFF ");
Serial.println(2*relay4_start+relay4_off);
for(i=1;i<var2;i++)
if(minute>=i*(relay4_start+relay4_off) && minute<(i*(relay4_start+relay4_off)+relay4_start))
Serial.print(i*(relay4_start+relay4_off));
Serial.println(i*(relay4_start+relay4_off)+relay4_start);
else if(minute>=i*(relay4_start+relay4_off)+relay4_start && minute<(i+1)*(relay4_start+relay4_off))
Serial.print(i*(relay4_start+relay4_off)+relay4_start);
Serial.println((i+1)*(relay4_start+relay4_off));
void displayTime()
if (hour < 10)
Serial.print("0");
Serial.print(hour,DEC);
Serial.print(":");
if ( minute < 10 )
Serial.print("0");
Serial.print(minute,DEC);
Serial.print(":");
if( second < 10 )
Serial.print("0");
Serial.print(second,DEC);
Serial.print(" ");
switch ( dayOfWeek )
case 1:
Serial.print("Mon");
case 2:
Serial.print("Tue");
case 3:
Serial.print("Wed");
case 4:
Serial.print("Thu");
case 5:
Serial.print("Fri");
case 6:
Serial.print("Sat");
case 0:
Serial.print("Sun");
Serial.print(",");
if ( dayOfMonth < 10)
Serial.print("0");
Serial.print(dayOfMonth,DEC);
Serial.print("-");
switch ( month )
case 1:
Serial.print("Jan");
case 2:
Serial.print("Feb");
case 3:
Serial.print("Mar");
case 4:
Serial.print("Apr");
case 5:
Serial.print("May");
case 6:
Serial.print("Jun");
case 7:
Serial.print("Jul");
case 8:
Serial.print("Aug");
case 9:
Serial.print("Sep");
case 10:
Serial.print("Oct");
case 11:
Serial.print("Nov");
case 12:
Serial.print("Dec");
Serial.print("-");
Serial.println(year,DEC);
Serial.println(" ");
delay(1045);
void setDS3231time(byte second, byte minute, byte hour, byte dayOfWeek, byte
dayOfMonth, byte month, byte year)
// sets time and date data to DS3231
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0); // set next input to start at the seconds register
Wire.write(DecToBcd(second)); // set seconds
Wire.write(DecToBcd(minute)); // set minutes
Wire.write(DecToBcd(hour)); // set hours
Wire.write(DecToBcd(dayOfWeek)); // set day of week (1=Sunday, 7=Saturday)
Wire.write(DecToBcd(dayOfMonth)); // set date (1 to 31)
Wire.write(DecToBcd(month)); // set month
Wire.write(DecToBcd(year)); // set year (0 to 99)
Wire.endTransmission();
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
Wire.write(0);
Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
*second = BcdToDec(Wire.read() & 0x7f);
*minute = BcdToDec(Wire.read());
*hour = BcdToDec(Wire.read() & 0x3f);
*dayOfWeek = BcdToDec(Wire.read());
*dayOfMonth = BcdToDec(Wire.read());
*month = BcdToDec(Wire.read());
*year = BcdToDec(Wire.read());
