So i have gotten myself stuck. i have an LED light fixture with 6 channels that my arduino is controlling. Im using a ds3231 RTC. My set times and fading seems to be functioning fine, except one thing. i have my lights set to turn on at 2pm and off at 11pm. but when midnight rolls around it turns itself back on. im not sure what time they turn off but when i get up in the mornings about 7 they are back off again.
If someone could take the time to browse my code and see if they can spot my error, i would be much obliged. As far as i can tell, this should only be coming on between my setpoints.
#include "Adafruit_PWMServoDriver.h"
#include <TimeLib.h> // https://github.com/PaulStoffregen/Time
#include <Wire.h>
#include <DS3232RTC.h> // https://github.com/JChristensen/DS3232RTC
#include "RTClib.h"
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(); // Initialize PWM Generator object
RTC_DS3231 rtc; // initialize Real time clock object
int currentBright = 0; // Tracks current brightness
int targetBright = 0; // What is our target to fade to
int maxBright = 75; // Maximum Value of brightness - TODO: Map() fades to max brightness as 100%
// Light Variables
unsigned long currentTime; // current time in millis
unsigned long prevFadeTime = 0; // Pevious event millis
unsigned long timeBetweenFade = 250; // How long to wait between fade steps
time_t timeOn; // Time to turn light on
time_t timeOff; // Time to turn light Off
bool lightIsOn = false; // Track whether light is on or not
Serial.begin(9600); // Start serial
Wire.setClock(400000);
if (! rtc.begin()) { // try to startup RTC
Serial.println("Couldn't find RTC");
while (1); // if you cant find it, fix and wait for reset
if (rtc.lostPower()) { // check if battery died on RTC, if so lets set it to something
Serial.println("RTC lost power, lets set the time!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
//rtc.adjust(DateTime(2019, 4, 30, 23, 52, 0));
setSyncProvider(RTC.get); //Sets our time keeper as the RTC
// setTime(RTC.get); // Sets system time to RTC Time
setSyncInterval(5); // number of seconds to go before requesting re-sync
if (timeStatus() != timeSet)
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
pwm.begin();
pwm.setOutputMode(false); // Set PWM Driver to open Drain for LEDs
pwm.setPWMFreq(400); // Set PWM Hz to reduce buzzing
for (int i = 0; i < 6; i++) {
pwm.setPin(i, currentBright, 0); // turn all channels off
timeOn = 1565532000; // Time to turn this channel on
timeOff = 1565564400; // Time to turn this channel off
currentTime = millis(); // Update current time
unsigned long SSM = getSSM(now()); // Find out how many seconds since midnight it has been
Serial.print("Seconds Since Midnight");
// Serial.println(SSM);
// Serial.println(getSSM(timeOn));
// Serial.println(getSSM(timeOff));
// during light on times
if ((SSM >= getSSM(timeOn)) && (SSM < getSSM(timeOff))) {
// Serial.println(F("Turning Light On"));
targetBright = maxBright; // Set light On
// Serial.println(F("Turning Light Off"));
targetBright = 0; // Set light off
// only allow setBrightness to run occasionally to lengthen the fade
if (currentTime >= prevFadeTime + timeBetweenFade) {
//Serial.println(F("Lets go set Brightness"));
setBrightness();
// Set brightness, then auto adjust brightness.
// use current brightness and target brightness and
// increment steps one by on with a non-blocking
// delay to adjust until we are at our target level
void setBrightness () {
if (currentBright != targetBright) { // See if we need to adjust brightness
if (targetBright > currentBright) { // Are we ramping up
if (currentBright < 4096) { // Make sure we havent exceeded bounds
currentBright++; // Lets get brighter
} else if (targetBright < currentBright) { // Are we ramping down
if (currentBright > 0) { // Make sure we havent exceeded bounds
currentBright--; // Lets get dimmer
prevFadeTime = currentTime; // Reset timer to wait for next fade step
for (int i = 0; i < 6; i++) { // Lets apply the brightness to all pins
//Serial.print("Adjusting Brightness to ");
//Serial.println(currentBright);
pwm.setPin(i, (currentBright * 40), 0);
//Serial.print("On Channel ");
//Serial.println(i);
unsigned long getSSM (time_t getTime) { // Calculate seconds since midnight for timers
unsigned long timeSecs = (hour(getTime) * 60 * 60);
timeSecs += (minute(getTime) * 60);
timeSecs += second(getTime);
// static unsigned long previousTime = timeSecs;
// if (timeSecs != previousTime) {
// Serial.print("Seconds Since Midnight: ");
// Serial.println(timeSecs);
// previousTime != timeSecs;
return timeSecs;
