Hello all!
Trying to figure out why this causes my Diecimila (w/ upgraded 328 chip) to freeze.
void debugMessage(const char *format, ...) {
int stringSize = strlen(format);
char str[stringSize];
va_list args;
va_start(args, format);
vsprintf(str, format, args);
va_end(args);
Serial.println(str);
Serial.flush();
pinMode(13, OUTPUT);
pinMode(11, OUTPUT);
debugMessage("Starting Up...");
digitalWrite(13, HIGH);
debugMessage("Setting Timers...");
TCNT2 = 0;
debugMessage("TCNT2 Set to: %d", TCNT2);
debugMessage("Toggling CTC Mode...");
TCCR2A |= (1 << WGM21 );
debugMessage("\nSetting Prescaler to 128...");
TCCR2B |= (1 << CS22 );
debugMessage("\nSetting OCR2A to 10.");
OCR2A = 10;
debugMessage("OCR2A Set to: %d", OCR2A);
debugMessage("Setting TIMSK2 to enable Output Compare 2A.");
TIMSK2 |= (1 << OCIE2A);
debugMessage("\nsetup() done...");
debugMessage("Loop..."):
Serial.println("Loop...");
digitalWrite(13, LOW);
ISR(TIMER2_COMPA_vect) {
debugMessage("Interrupt/TIMER2_COMPA_vect Triggered!");
in my tests, the arduino "hangs" right after I set OCIE2A. I never see the "setup done()" message, or any of the "Loop.." messages, nor does the ISR ever get called. Anyone have any clues as to what I'm doing wrong here? I don't have any specific application in mind at the moment, just trying to learn timers..
