Hi guys,
this is my first post. I'll make sure to do it right.
I am using an EM406A GPS module, a Sparkfun GPS shield and an Arduino UNO setup. And just to see if it can run the simplest example, I ran the code:
 Serial.begin(4800);
 byte a;
 if ( Serial.available() > 0 )
  a = Serial.read();
  Serial.write(a);
And the output was as follows:
$GPGGA,115228.000,3543.9110,N,14005.2443,E,1,08,1.3,133.2,M,39.3,M,,000058
$GPGSA,A,3,07,08,01,32,19,20,09,03,,,,,2.5,1.3,2.238
$GPRMC,115228.000,A,3543.9110,N,14005.2443,E,0.43,235.05,140514,,,A69
$GPGGA,115229.000,3543.9104,N,14005.2441,E,1,08,1.3,135.7,M,39.3,M,,00005D
$GPGSV,3,1,12,01,78,295,27,11,68,025,,32,45,115,20,28,41,314,177C
$GPGSV,3,2,12,19,38,074,17,20,35,170,32,08,30,251,31,03,29,095,1571
$GPGSV,3,3,12,09,24,262,31,07,19,223,32,27,11,093,,17,08,288,7F
$GPRMC,115229.000,A,3543.9104,N,14005.2441,E,0.35,220.25,140514,,,A68
$GPGGA,115230.000,3543.9098,N,14005.2439,E,1,08,1.3,138.4,M,39.3,M,,000050
$GPRMC,115230.000,A,3543.9098,N,14005.2439,E,0.22,206.71,140514,,,A68
$GPGGA,115231.000,3543.9092,N,14005.2436,E,1,08,1.3,140.8,M,39.3,M,,000057
$GPRMC,115231.000,A,3543.9092,N,14005.2436,E,0.29,1.67,140514,,,A65
$GPGGA,115232.000,3543.9086,N,14005.2431,E,1,08,1.3,143.3,M,39.3,M,,00005E
$GPRMC,115232.000,A,3543.9086,N,14005.2431,E,0.98,240.42,140514,,,A6E
$GPGGA,115233.000,3543.9079,N,14005.2425,E,1,08,1.3,146.0,M,39.3,M,,00005C
$GPRMC,115233.000,A,3543.9079,N,14005.2425,E,1.39,235.73,140514,,,A60
$GPGGA,115234.000,3543.9073,N,14005.2421,E,1,08,1.3,148.3,M,39.3,M,,000058
$GPGSV,3,1,12,01,78,295,27,11,68,025,,32,45,115,19,28,41,314,1978
$GPGSV,3,2,12,19,38,074,16,20,35,170,32,08,30,251,26,03,29,095,15*76
$GPGSV,3,3,12,09,24,262,31,07,19,223,26,27,11,093,,17,08,288,7A
$GPRMC,115234.000,A,3543.9073,N,14005.2421,E,0.78,226.72,140514,,,A6E
And if you look at the $GPRMC lines, you will see the letter A, indicating that A is for active and data is valid, V for void and data is not valid. So the data is valid and ready for processing.
I used the following code in order to print the Latitudes and Longitudes on the Serial Monitor:
#include <TinyGPS.h>
TinyGPS gps;
void getgps(TinyGPS &gps);
 Serial.begin(4800);
 // Define the variables that will be used
 float latitude, longitude;
 // Then call this function
 gps.f_get_position(&latitude, &longitude);
 Serial.print("Lat: ");
 Serial.println(latitude, 5);
 Serial.print("Long: ");
 Serial.println(longitude, 5);
 byte a;
 if ( Serial.available() > 0 ) // if there is data coming into the serial line
  a = Serial.read(); // get the byte of data
  if(gps.encode(a)) // if there is valid GPS data...
   getgps(gps); // then grab the data and display it
   Serial.println("encode(a) doesn't return true");
Once I ran the code above, due to the encode function not returning true at all, the getgps() function can never be called. I took the hardware outside with a laptop to an area where there was a clear view of the sky and still it just doesn't work.
Any ideas as to why the encode function won't return true?
Thanks.
