Hello.
My test system is a ttgo AX7670 board with a A7670E SIMCOM modem. This is my test code:
// #define TINY_GSM_MODEM_SIM7000
#define TINY_GSM_MODEM_SIM7600
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
// Use Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// See all AT commands, if wanted
// #define DUMP_AT_COMMANDS
// Define the serial console for debug prints, if needed
#define TINY_GSM_DEBUG SerialMon
* Tests enabled
#define TINY_GSM_TEST_GPRS false
#define TINY_GSM_TEST_WIFI false
#define TINY_GSM_TEST_CALL false
#define TINY_GSM_TEST_SMS true
#define TINY_GSM_TEST_USSD false
#define TINY_GSM_TEST_BATTERY false
#define TINY_GSM_TEST_GPS false
#define TINY_GSM_POWERDOWN true // powerdown modem after tests
#define TINY_GSM_TEST_WEB_SERVER true
// set GSM PIN, if any
#define GSM_PIN ""
//SMS target number
#define SMS_TARGET "87101766" //Poner aquà el número de teléfono para SMS
// Your GPRS credentials, if any
const char apn[] = "kolbi3g";
const char gprsUser[] = "";
const char gprsPass[] = "";
// Web Server details
const char server[] = "vsh.pp.ua";
const char resource[] = "/TinyGSM/logo.txt";
#include <TinyGsmClient.h>
#include <Ticker.h>
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
TinyGsm modem(SerialAT);
#endif
Ticker tick;
#ifdef USE_SSL
TinyGsmClientSecure client(modem);
const int port = 443;
#else
TinyGsmClient client(modem);
const int port = 80;
#endif
#define uS_TO_S_FACTOR 1000000ULL /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP 60 /* Time ESP32 will go to sleep (in seconds) */
#define PIN_TX 27
#define PIN_RX 26
#define UART_BAUD 115200
#define PWR_PIN 4
#define LED_PIN 12
#define POWER_PIN 25
#define IND_PIN 36
#define PMU_IRQ 35
#define I2C_SDA 21
#define I2C_SCL 22
// Set console baud rate
SerialMon.begin(115200);
delay(10);
// Onboard LED light, it can be used freely
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, LOW);
// POWER_PIN : This pin controls the power supply of the SIM7600
pinMode(POWER_PIN, OUTPUT);
digitalWrite(POWER_PIN, HIGH);
// PWR_PIN : This Pin is the PWR-KEY of the SIM7600
// The time of active low level impulse of PWRKEY pin to power on module , type 500 ms
pinMode(PWR_PIN, OUTPUT);
digitalWrite(PWR_PIN, HIGH);
digitalWrite(PWR_PIN, LOW);
// IND_PIN: It is connected to the SIM7600 status Pin,
// through which you can know whether the module starts normally.
pinMode(IND_PIN, INPUT);
attachInterrupt(IND_PIN, []() {
detachInterrupt(IND_PIN);
// If SIM7600 starts normally, then set the onboard LED to flash once every 1 second
tick.attach_ms(1000, []() {
digitalWrite(LED_PIN, !digitalRead(LED_PIN));
}, CHANGE);
DBG("Wait...");
delay(3000);
SerialAT.begin(UART_BAUD, SERIAL_8N1, PIN_RX, PIN_TX);
// Restart takes quite some time
// To skip it, call init() instead of restart()
DBG("Initializing modem...");
if (!modem.init()) {
DBG("Failed to restart modem, delaying 10s and retrying");
return;
//Set to GSM mode, please refer to manual 5.11 AT+CNMP Preferred mode selection for more parameters
2 Automatic
13 GSM Only
14 WCMDA Only
38 LTE Only
bool result;
result = modem.setNetworkMode(38);
Serial.println("SetNetworkMode result: "+String(result));
if (modem.waitResponse(10000L) != 1) {
DBG(" setNetworkMode faill");
//return ;
int netWorkMode = modem.getNetworkMode();
Serial.printf("Current network mode set to: %d (2 Auto, 13 GSM, 14 WCMDA, 38 LTE): \n",netWorkMode);
#if TINY_GSM_TEST_GPS
//https://github.com/vshymanskyy/TinyGSM/pull/405
uint8_t mode = modem.getGNSSMode();
Serial.print("Current GNSS Mode (1=GPS 2 BDS 3=GPS + BDS 4=GLONASS 5=GPS + GLONASS 6=BDS + GLONASS 7=GPS + BDS + GLONASS): ");
Serial.println(mode);
* CGNSSMODE: <gnss_mode>,<dpo_mode>
* This command is used to configure GPS, GLONASS, BEIDOU and QZSS support mode.
* gnss_mode:
* 0 : GLONASS --ruso
* 1 : BEIDOU --chino
* 2 : GALILEO --europa
* 3 : QZSS --japĂłn
* dpo_mode :
* 0 disable
* 1 enable
According to A7670 doc
1 GPS
2 BDS
3 GPS + BDS
4 GLONASS
5 GPS + GLONASS
6 BDS + GLONASS
7 GPS + BDS + GLONASS
uint16_t gnssMode = 7;
Serial.print("Set GNSS Mode to :"+String(gnssMode));
String res = modem.setGNSSMode(gnssMode, 1);
Serial.println(res);
#endif
// DBG("Initializing modem...");
// if (!modem.restart()) {
// DBG("Failed to restart modem, delaying 10s and retrying");
// return;
String name = modem.getModemName();
DBG("Modem Name:", name);
String modemInfo = modem.getModemInfo();
DBG("Modem Info:", modemInfo);
#if TINY_GSM_TEST_GPRS
// Unlock your SIM card with a PIN if needed
if ( GSM_PIN && modem.getSimStatus() != 3 ) {
modem.simUnlock(GSM_PIN);
#endif
#if TINY_GSM_TEST_GPRS && defined TINY_GSM_MODEM_XBEE
// The XBee must run the gprsConnect function BEFORE waiting for network!
modem.gprsConnect(apn, gprsUser, gprsPass);
#endif
DBG("Waiting for network...");
if (!modem.waitForNetwork()) {
delay(10000);
return;
if (modem.isNetworkConnected()) {
DBG("Network connected");
SerialAT.println("AT+CEREG?");
if (SerialAT.available()){
String input = SerialAT.readString();
Serial.printf("CEREG?: %s \n",input.c_str());
DBG("Connecting to", apn);
if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
delay(10000);
return;
bool res = modem.isGprsConnected();
DBG("GPRS status:", res ? "connected" : "not connected");
//#endif
String ccid = modem.getSimCCID();
DBG("CCID:", ccid);
String imei = modem.getIMEI();
DBG("IMEI:", imei);
String cop = modem.getOperator();
DBG("Operator:", cop);
IPAddress local = modem.localIP();
DBG("Local IP:", local);
int csq = modem.getSignalQuality();
DBG("Signal quality:", csq);
#endif
//Disable gnss
modem.sendAT("+CGNSSPWR=0");
modem.waitResponse(10000L);
//Enable gnss
modem.sendAT("+CGNSSPWR=1");
//Wait gnss start.
SerialMon.print("\tWait GPS ready.");
while (modem.waitResponse(1000UL, "+CGNSSPWR: READY!") != 1) {
SerialMon.print(".");
SerialMon.println();
//Set gnss mode use GPS.
modem.sendAT("+CGNSSMODE=7"); //1 = GPS 7 = GPS, GLONAS, BEIDOU
modem.enableGPS();
float lat, lon, speed, alt;
int vsat, usat;
float accuracy;
int year,month,day,hour,minute,second;
while (1) {
if (modem.getGPS(&lat, &lon, &speed, &alt, &vsat, &usat, &accuracy, &year, &month, &day, &hour, &minute, &second)) {
Serial.printf("lat:%f lon:%f, speed:%f, alt:%f, vsat:%d, usat:%d, accu:%f, year:%d, month:%d, day:%d, hour:%d, minute:%d, second:%d\n",
lat, lon, speed, alt, vsat, usat, accuracy, year, month, day, hour, minute, second);
/** THIS IS ORIGINAL CODE THAT HAS ISSUES WITH INDEXES USED TO EXTRACT VALUES. THIS EXAMPLE NEEDS THE TinyGsMcLIENTsim7600.h fix made by jbejarano to work **/
/*modem.sendAT(GF("+CGNSSINFO"));
Format for CGNSSINFO at https://www.manualslib.com/manual/1889278/Simcom-Sim7500-Series.html?page=391
format: [<mode>],[<GPS-SVs>],[<GLONASS-SVs>],[<BEIDOU-SVs>],[<unknown],[<lat>] ,[<N/S>],[<log>] ,[<E/W>],[<date>],[<UTC-time>],[<alt>], [<speed>],[<course>],[<PDOP>],[HDOP],[VDOP]
example: 3 , 14 , , , ,9.8503294, N ,83.9305038, W ,110723 , 202457.00 ,1446.6 , 0.201 , , 3.90 , 2.96 ,2.54,05
if (modem.waitResponse(GF(GSM_NL "+CGNSSINFO:")) == 1) {
String res = modem.stream.readStringUntil('\n');
String lat = "";
String n_s = "";
String lon = "";
String e_w = "";
res.trim();
lat = res.substring(8, res.indexOf(',', 8));
n_s = res.substring(19, res.indexOf(',', res.indexOf(',', 19)));
lon = res.substring(21, res.indexOf(',', res.indexOf(',', 21)));
e_w = res.substring(33, res.indexOf(',', res.indexOf(',', 33)));
delay(100);
Serial.println("****************GNSS********************");
Serial.printf("lat:%s %s\n", lat.c_str() , n_s.c_str());
Serial.printf("lon:%s %s\n", lon.c_str(), e_w.c_str());
float flat = atof(lat.c_str());
float flon = atof(lon.c_str());
Serial.printf("flat: %f",flat);
Serial.printf("flon: %f",flon);
flat = (floor(flat / 100) + fmod(flat, 100.) / 60) *
(n_s == "N" ? 1 : -1);
flon = (floor(flon / 100) + fmod(flon, 100.) / 60) *
(e_w == "E" ? 1 : -1);
Serial.print("Latitude:"); Serial.println(flat);
Serial.print("Longitude:"); Serial.println(flon);
Serial.print("Searching GPS satellites...");
Serial.println(millis());
delay(2000);
modem.disableGPS();
//Disable gnss
#endif
#if TINY_GSM_TEST_SMS
bool smsres = modem.sendSMS(SMS_TARGET, String( " imei: " + imei +
" Signal: " + String(csq)));
DBG("SMS:", smsres ? "OK" : "fail");
#else
bool smsres = modem.sendSMS(SMS_TARGET, String("No GPRS mode active"));
#endif
#endif
#if TINY_GSM_TEST_WEB_SERVER
SerialMon.print("Connecting to ");
SerialMon.println(server);
if (!client.connect(server, port)) {
SerialMon.println(" fail");
delay(10000);
return;
SerialMon.println("Connection to endpoint successful");
// Make a HTTP GET request:
SerialMon.println("Performing HTTP GET request...");
client.print(String("GET ") + resource + " HTTP/1.1\r\n");
client.print(String("Host: ") + server + "\r\n");
client.print("Connection: close\r\n\r\n");
client.println();
uint32_t timeout = millis();
while (client.connected() && millis() - timeout < 10000L) {
// Print available data
while (client.available()) {
char c = client.read();
SerialMon.print(c);
timeout = millis();
// Shutdown
client.stop();
SerialMon.println(F("Server disconnected"));
#endif
modem.gprsDisconnect();
if (!modem.isGprsConnected()) {
DBG("GPRS disconnected");
DBG("GPRS disconnect: Failed.");
#endif
#if TINY_GSM_POWERDOWN
// Try to power-off (modem may decide to restart automatically)
// To turn off modem completely, please use Reset/Enable pins
modem.poweroff();
DBG("Poweroff.");
#endif
// Test is complete Set it to sleep mode
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
delay(200);
esp_deep_sleep_start();
20:46:26.183 -> [525] Wait...
20:46:29.159 -> [3525] Initializing modem...
20:46:29.159 -> [3526] ### TinyGSM Version: 0.11.5
20:46:29.206 -> [3526] ### TinyGSM Compiled Module: TinyGsmClientSIM7600
20:46:36.599 -> [10926] ### Unhandled: *ISIMAID: "A0000000871004FFFFF00189000001FF"
20:46:36.958 -> [11331] ### Modem: AT
20:46:37.003 -> SetNetworkMode result: 1
20:46:37.127 -> Current network mode set to: 38 (2 Auto, 13 GSM, 14 WCMDA, 38 LTE):
20:46:37.215 -> [11558] ### Modem: A7670E-FASE
20:46:37.215 -> [11558] Modem Name: A7670E-FASE
20:46:37.251 -> [11587] Modem Info: Manufacturer: INCORPORATED Model: A7670E-FASE Revision: A7670M7_V1.11.1 IMEI: 862205052863802 +GCAP: +CGSM,+FCLASS,+DS
20:46:37.251 -> [11598] Waiting for network...
20:46:41.890 -> [16222] Network connected
20:46:43.370 -> CEREG?:
20:46:43.370 -> +CEREG: 0,1
20:46:43.370 ->
20:46:43.370 -> OK
20:46:43.370 ->
20:46:46.454 -> [20792] SMS: OK
20:46:46.454 -> Connecting to vsh.pp.ua
20:46:46.454 -> fail
20:46:56.451 -> [30812] Modem Name: SIMCom SIM7600
20:46:56.491 -> [30824] Modem Info: PB DONE A7670E-FASE
20:46:56.491 -> [30824] Waiting for network...
20:46:56.491 -> [30839] Network connected
20:46:57.996 -> CEREG?:
20:46:57.996 -> +CEREG: 0,1
20:46:57.996 ->
20:46:57.996 -> OK
20:46:57.996 ->
20:46:58.891 -> [33250] SMS: OK
As shown the modem supports LTE connection so I set modem.setNetworkMode(38) so I can use LTE. The gprs code is disabled #define TINY_GSM_TEST_GPRS false. The connection by TCP to the endopint vsh.pp.ua FAILS. Why if there is LTE connection? The Network is connected as shown in the output. Now, if I enable the gprs connection it works. Why if the connection mode is LTE the web server connection works with GPRS enabled. My target is to connect throug EPS connection and no any GSM (gprs connection). Probabily I am missunderstanding concepts. Any clarification from the team is appreciated.
