I'm following this example to have my Arduino Mega vary the voltage to my dragon ears. Each ear has a 12V strand of red LEDs. At full intensity, the total wattage for both ears will be (12V x 3A) X 2 ears = 72 Watts.
My concern is that the jumper wires I have for connecting breadboard/TIP120 to negative on ARD seem very thin. Can they handle 72 watts and, if not, what do you recommend?
Larry_Tremaine:
It's not the power (W), it's the current.
Describe the "strand" - What's the "3A" based upon?
I wouldn't use thin jumper wires for that, nor would I trust a breadboard to handle 6A.
I suspect if you run it like that, you'll find that the lights just aren't as bright as you'd like them to be, and the jumpers and/or breadboard around the transistor will get warm (or hot).
Use thicker wire, and solder the high current connections.
