TM1637 and semicolon problem
in this part of my program, in on_button_short_click(), the testseconds are displayed without the semcolon, like 07 by the next short click, the testminutes displays the semicolon like 05:
How do I also get the simicolon with the testseconds...?
#include <Arduino.h>
#include <Wire.h>
#include "AiEsp32RotaryEncoder.h"
#include <TM1637Display.h>
#define CLK 21  // TM1637 CLK
#define DIO 22  // TM1637 DIO
// Create a TM1637 display object
TM1637Display display(CLK, DIO);
int testminutes = 5;
int testseconds = 7;
int MS = 2
  display.clear();
  display.setBrightness(3);
  display.showNumberDecEx(0, 0b01000000, true);  // 00:00
void on_button_short_click() {
    switch (MS) {
    case 1:
      display.clear();
      display.showNumberDecEx(testminutes, 0b01000000, true, 2, 4);  // 05:__
      MS=2;
    case 2:
      display.clear();
      display.showNumberDecEx(testseconds, 0b01000000, true, 2, 2);  // __:07
      MS=1;
Can you explain this part better:
Post your entire code.
Ok here its, its a simple countdown timer...
#include <Wire.h>
#define output 16        // output for lights can by realy module or BJT,Mosfet
#define buzzer 25
#define runningLED 23   //Red, timer is running
#define readyLED 26     //Green, timer is ready
// Timer settings
int minutes = 0;
int seconds = 0;
int setminutes = 0;
int setseconds = 0;
boolean timeState = false;
int HMS = 2;              // 1 for Minnutes, 2 for seconds, boot with seconds selected
// I reversed the pin conections A and B, for rotating clockwise!!
#define ROTARY_ENCODER_A_PIN 18         //CLK right ------->>>>> Real connection is pin 27 <<<----- !!!!!!!!!!
#define ROTARY_ENCODER_B_PIN 27         //DT  left  ------->>>>> Real connection is pin 18 <<<----- !!!!!!!!!!
#define ROTARY_ENCODER_BUTTON_PIN 19    //SW  switch
//depending on your encoder - try 1,2 or 4 to get expected behaviour
#define ROTARY_ENCODER_STEPS 4
//#define ROTARY_ENCODER_STEPS 4 = default
AiEsp32RotaryEncoder rotaryEncoder = AiEsp32RotaryEncoder(ROTARY_ENCODER_A_PIN, ROTARY_ENCODER_B_PIN, ROTARY_ENCODER_BUTTON_PIN, -1, ROTARY_ENCODER_STEPS);
#define ROTARY_ENCODER_VCC_PIN -1 // put -1 if Rotary encoder Vcc is connected directly to 3,3V; else you can use declared output pin for powering rotary encoder */
unsigned long shortPressAfterMiliseconds = 50;   //how long short press shoud be. Do not set too low to avoid bouncing (false press events).
unsigned long longPressAfterMiliseconds = 500;  //how long long press shoud be.
void buzz() {
  digitalWrite(buzzer, HIGH);
  delay(100);
  digitalWrite(buzzer, LOW);
  if (!timeState) { //  if false (running)
    switch (HMS) {
    case 1:
      display.clear();
      HMS=2;
    case 2:
      display.clear();
      HMS=1;
void on_button_long_click() {
//   if ( minutes >0 or seconds >0) {
//     if (minutes == 1 and seconds ==0) {
//       minutes = 0;
//       seconds = 60;
//     lcd.clear();
//     lcd.setCursor(2, 0); lcd.print("Creating....");
//     timeState = true;
//     digitalWrite(output, HIGH);
//     digitalWrite(runningLED, HIGH);
//     digitalWrite(readyLED, LOW);
//     delay(50);
//     while (timeState == true) {
//       int period = 1000;
//       unsigned long time_now = 0;
//       time_now = millis();
//       while(millis() < time_now + period) { //wait approx. [period] ms}
//       seconds = seconds - 1;
//       if (seconds == 0 and minutes >= 1) {
//         seconds = 60;
//         minutes = minutes - 1;
//       else if (minutes == 0 and seconds == 0) { //count down alarm
//           digitalWrite(output, LOW);
//           digitalWrite(runningLED, LOW);
//           digitalWrite(readyLED, HIGH);
//           lcd.clear();
//           lcd.setCursor(4, 0);
//           lcd.print("Creation");
//           lcd.setCursor(6, 1);
//           lcd.print("Ready");
//           HMS = 2;
//           minutes = 0;
//           seconds = 0;
//           int x = 1;
//           while (x < 11) { // 10x beeps if ready
//             lcd.clear();
//             buzz();
//             delay(500);
//             lcd.clear();
//             x = x + 1;
//           minutes = setminutes;
//           seconds = setseconds;
//           timeState = false;
//           lcd.clear();
//           lcd.print("Set Seconds");
//           lcd.setCursor(5, 1);
//           lcd.print("00:00");
//       if (minutes <= 9) {
//         lcd.print("0");
//       lcd.print(minutes);
//       lcd.print(":");
//       lcd.setCursor(8, 1);
//       if (seconds <= 9) {
//         lcd.print("0");
//       lcd.print(seconds);
void handle_rotary_button() {
  static unsigned long lastTimeButtonDown = 0;
  static bool wasButtonDown = false;
  bool isEncoderButtonDown = rotaryEncoder.isEncoderButtonDown();
  //isEncoderButtonDown = !isEncoderButtonDown; //uncomment this line if your button is reversed
  if (isEncoderButtonDown) {
  //   //Serial.print("+");  //REMOVE THIS LINE IF YOU DONT WANT TO SEE
  //   lcd.clear();
  //   lcd.setCursor(0, 0);
  //   lcd.print("+");
    if (!wasButtonDown) {
  //     //start measuring
     lastTimeButtonDown = millis();
    //else we wait since button is still down
    wasButtonDown = true;
    return;
//   button is up
  if (wasButtonDown) {
//     // Serial.println("");  //REMOVE THIS LINE IF YOU DONT WANT TO SEE
//     // //click happened, lets see if it was short click, long click or just too short
//     lcd.clear();
//     lcd.print("Short click");
     if (millis() - lastTimeButtonDown >= longPressAfterMiliseconds) {
       on_button_long_click();
     } else if (millis() - lastTimeButtonDown >= shortPressAfterMiliseconds) {
       on_button_short_click();
// ********** button handling ----
void rotary_loop() {
  if (rotaryEncoder.encoderChanged()) {
    if (HMS == 1) {
      minutes = rotaryEncoder.readEncoder();
      if( minutes <1 ) {
        minutes = 0;
    else if (HMS == 2) {
      seconds = rotaryEncoder.readEncoder();
  handle_rotary_button();
void IRAM_ATTR readEncoderISR() {
  rotaryEncoder.readEncoder_ISR();
  rotaryEncoder.begin();
  rotaryEncoder.setup(readEncoderISR);
  pinMode(output, OUTPUT);
  pinMode(buzzer, OUTPUT);
  pinMode(runningLED, OUTPUT);
  pinMode(readyLED, OUTPUT);
  display.clear();
  delay(100);
  delay(150);
  delay(100);
// Rotary acceleration introduced 25.2.2021.
//    * in case range to select is huge, for example - select a value between 0 and 1000 and we want 785
//    * without accelerateion you need long time to get to that number
//    * Using acceleration, faster you turn, faster will the value raise.
//    * For fine tuning slow down.
   rotaryEncoder.disableAcceleration(); //acceleration is now enabled by default - disable if you dont need it
  //rotaryEncoder.setAcceleration(250);  //or set the value - larger number = more accelearation; 0 or 1 means disabled acceleration
//set boundaries and if values should cycle or not
  //in this example we will set possible values between 1 and 60;
  bool circleValues = true;
  rotaryEncoder.setBoundaries(0, 60, circleValues);  //minValue, maxValue, circleValues true|false (when max go to min and vice versa)
  //in loop call your custom function which will process rotary encoder values
  rotary_loop();
  delay(50);
I didn't understand this explanation.
Can you elaborate more?
And,
In the display, do you want to display a semicolon ( ; ) or a colon ( : )?
The colon is only written when digit 1 is written. There doesn't seem to be a way to write blank to a digit with showNumberDecEx, but you can call setSegments directly e.g.
const byte segmentData[1] = {SEG_DP};
    switch (HMS) {
    case 1:
      display.clear();
      HMS=2;
    case 2:
      display.clear();
      display.setSegments(segmentData, 1, 1);
      HMS=1;
sorry my fault, it has to be a colon (:slight_smile:
step 1 when the timer is booted, it displays 00:00
step 2 push short to switch between seconds or minutes
step 3 rotary left/right for increase or decrease the selected minutes or seconds
step 4 long press start timer
You're my hero, works like a charm.
Thank you so much.
@ceesii
I'm glad it worked, but I still don't understand your previous difficulty.
See the simulator using your first posted code.
Shows the colon after the minutes and before the seconds.
Ruilviana, also many thanks for helping, I tried with Wokwi but with the KY-040 it gave a lot of lag..
P.s. Im using an ESP32, And I have the complete code working with an CrystalDisplay.
But I wanna use a cheaper tm1637 , and save the lcd for other projects.
So I have to rewrite for simple display tm1637.... almost there
