TM1637 colon lighting up
Hello! I want to make a clock. It works but i dont know how to make the colon light up.. And yes, they work. This is where i bought the display Modul LED Display Ceas | Cleste.ro ( You might not undertand what written there bcz is in romanian)
I can give you my code too...
#include <TM1637Display.h>
#define CLK_PIN 8   // Pinul conectat la pinul CLK al afișajului
#define DIO_PIN 9   // Pinul conectat la pinul DIO al afișajului
const int DIN_PIN = 2;
const int DIN2_PIN = 3;
unsigned long previousTime = 0;
const unsigned long interval = 60000; // Intervalul de timp în milisecunde (60 de secunde)
int i = 0;
TM1637Display display(CLK_PIN, DIO_PIN);
void setup(){
  display.setBrightness(7);  // Setarea luminozității afișajului (0-7)
  pinMode(DIN_PIN, INPUT_PULLUP);
  pinMode(DIN2_PIN, INPUT_PULLUP);
    Serial.begin( 9600 );
     previousTime = millis(); // Salvează timpul de pornire
void loop(){
 unsigned long currentTime = millis(); // Obține timpul curent
  display.showNumberDec(i, true);
  int value = digitalRead(DIN_PIN);
  int value2 = digitalRead(DIN2_PIN);
  if (value == 0) {
    i++;
    delay(200);
  if (value2 == 0) {
    i += 100;
    delay(200);
      if (i % 100 / 10 == 6) {
        i = (i - i % 100) + 100;
if (currentTime - previousTime >= interval) {
  i++;
    previousTime = currentTime;
   if (i>=2359) i=0;
use that information
  //! Display arbitrary data on the module
  //! This function receives raw segment values as input and displays them. The segment data
  //! is given as a byte array, each byte corresponding to a single digit. Within each byte,
  //! bit 0 is segment A, bit 1 is segment B etc.
  //! The function may either set the entire display or any desirable part on its own. The first
  //! digit is given by the @ref pos argument with 0 being the leftmost digit. The @ref length
  //! argument is the number of digits to be set. Other digits are not affected.
  //! @param segments An array of size @ref length containing the raw segment values
  //! @param length The number of digits to be modified
  //! @param pos The position from which to start the modification (0 - leftmost, 3 - rightmost)
  void setSegments(const uint8_t segments[], uint8_t length = 4, uint8_t pos = 0);
so I assume
uint8_t data[] = { 0b11111111 };
display.setSegments(data, 1, 1);
should switch on all segments of the "second" digit (showing "8") including the colon.
if yes, try 0b10000000 (or 0b00000001) for the colon only.
i would use this function instead
  //! Display a decimal number, with dot control
  //! Display the given argument as a decimal number. The dots between the digits (or colon)
  //! can be individually controlled.
  //! @param num The number to be shown
  //! @param dots Dot/Colon enable. The argument is a bitmask, with each bit corresponding to a dot
  //!        between the digits (or colon mark, as implemented by each module). i.e.
  //!        For displays with dots between each digit:
  //!        * 0.000 (0b10000000)
  //!        * 00.00 (0b01000000)
  //!        * 000.0 (0b00100000)
  //!        * 0.0.0.0 (0b11100000)
  //!        For displays with just a colon:
  //!        * 00:00 (0b01000000)
  //!        For displays with dots and colons colon:
  //!        * 0.0:0.0 (0b11100000)
  //! @param leading_zero When true, leading zeros are displayed. Otherwise unnecessary digits are
  //!        blank. NOTE: leading zero is not supported with negative numbers.
  //! @param length The number of digits to set. The user must ensure that the number to be shown
  //!        fits to the number of digits requested (for example, if two digits are to be displayed,
  //!        the number must be between 0 to 99)
  //! @param pos The position of the most significant digit (0 - leftmost, 3 - rightmost)
  void showNumberDecEx(int num, uint8_t dots = 0, bool leading_zero = false, uint8_t length = 4, uint8_t pos = 0);
of
so that would be
display.showNumberDecEx(i, 0b01000000, true); // 0b01000000 = 64 or 0x40, you can use either of those as well.
Thank you so much!!! Now how can i make it blink?
at a seconds interval i presume...
simplest solution is to take the elapsed time, take the modulo 1000 of that ( % 1000) resulting in a value that has just the milliseconds, and divide that by 500, so it will be either 0 or 1, and then execute conditionally the colon showing.
if ( ( (currentTime - previousTime) % 1000) / 500 == 1) display.showNumberDecEx(i, 0b01000000, true);
else display.showNumberDecEx(i, 0, true);
just a note about your code.
  i++;
isn't very accurate, instead use
  i++;
    previousTime = previousTime + interval;  // oops edit '+' instead of '-'
It is easier when using the "TM1637_RT" library.
See this example in Wokwi simulation:
In Wokwi, click the start button in the upper-middle of the screen. The loop() has three sections for the three displays.
To show the minutes and seconds and a optional colon, this single line will do that:
TM1.displayTime(clockMinutes,clockSeconds, colon);
