Hello everybody, today are arrived 2 TMP36 that I had ordered.
After setting up and copy paste the code from internet I get this valus:
0.22 volts
-28.03 degrees C
-18.45 degrees F
0.24 volts
-25.59 degrees C
-14.05 degrees F
0.05 volts
-44.63 degrees C
-48.33 degrees F
0.11 volts
-39.26 degrees C
-38.66 degrees F
0.07 volts
-42.68 degrees C
-44.82 degrees F
0.06 volts
-43.65 degrees C
-46.57 degrees F
0.10 volts
-39.75 degrees C
-39.54 degrees F
0.10 volts
-39.75 degrees C
-39.54 degrees F
0.08 volts
-42.19 degrees C
-43.94 degrees F
0.17 volts
-32.91 degrees C
-27.24 degrees F
0.21 volts
-29.49 degrees C
-21.09 degrees F
0.10 volts
-40.23 degrees C
-40.42 degrees F
0.18 volts
-31.93 degrees C
-25.48 degrees F
0.20 volts
-29.98 degrees C
-21.96 degrees F
0.16 volts
-34.38 degrees C
-29.87 degrees F
The code that I'm using is this:
//TMP36 Pin Variables
int sensorPin = 0; //the analog pin the TMP36's Vout (sense) pin is connected to
//the resolution is 10 mV / degree centigrade with a
//500 mV offset to allow for negative temperatures
* setup() - this function runs once when you turn your Arduino on
* We initialize the serial connection with the computer
Serial.begin(9600); //Start the serial connection with the computer
//to view the result open the serial monitor
void loop() // run over and over again
//getting the voltage reading from the temperature sensor
int reading = analogRead(sensorPin);
// converting that reading to voltage, for 3.3v arduino use 3.3
float voltage = reading * 5.0;
voltage /= 1024.0;
// print out the voltage
Serial.print(voltage); Serial.println(" volts");
// now print out the temperature
float temperatureC = (voltage - 0.5) * 100 ; //converting from 10 mv per degree wit 500 mV offset
//to degrees ((voltage - 500mV) times 100)
Serial.print(temperatureC); Serial.println(" degrees C");
// now convert to Fahrenheit
float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
Serial.print(temperatureF); Serial.println(" degrees F");
delay(1000); //waiting a second
Took from adafruit site at this link: Overview | TMP36 Temperature Sensor | Adafruit Learning System
Anyone can help me?
Im very angry because this cheap sensor is real creap nonetheless more people said thatt they are precise and suggested!
Thank you all
(PS all wired is connected in the right way)
