TOF sensors using Adafruit_VL53L0X - sensor no longer work
I March 2025 I last time worked on a little project that operated 5 TOF-sensors. Today I dealt again with it after updating the IDE and libraries. And after recompiling the project doesn’t provide the expected results. I suspect the Adafruit_VL53L0X library.
What has changed mainly is the Adafruit_VL53L0X library. I just updated the library not testing the program before and freezing the state of libraries used for the project last time it worked.
I first tried the latest Adafruit_VL53L0X (1.2.4) and after that was failing, I installed 1.2.2, the previous version, not being sure that this is the one the app was compiled with when it was last time working. I could well be, that it contains a programming bug that just reveils now. I’m posting the code FWIW below.
#include "Adafruit_VL53L0X.h"
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
#define XSHUT_5 19
#define XSHUT_4 18
#define XSHUT_3 17
#define XSHUT_2 16
#define XSHUT_1 15
#define LX_ADDR_1 0x30
#define LX_ADDR_2 0x31
#define LX_ADDR_3 0x32
#define LX_ADDR_4 0x33
#define LX_ADDR_5 0x34
#define N_SENSORS 5
/* meine 5 Sensoren */
Adafruit_VL53L0X lox1 ;
Adafruit_VL53L0X lox2 ;
Adafruit_VL53L0X lox3 ;
Adafruit_VL53L0X lox4 ;
Adafruit_VL53L0X lox5 ;
struct {
Adafruit_VL53L0X *lox; // Sensor handle
uint8_t address;  // gewünschte Sensoradresse
uint8_t xshut_pin;// pin am ESP32 zum XSHUT
} lox[N_SENSORS]= {
{&lox1,LX_ADDR_1,XSHUT_1},
{&lox2,LX_ADDR_2,XSHUT_2},
{&lox3,LX_ADDR_3,XSHUT_3},
{&lox4,LX_ADDR_4,XSHUT_4},
{&lox5,LX_ADDR_5,XSHUT_5}
#define i2c_Address 0x3c //initialize with the I2C addr 0x3C Typically eBay OLED's
//#define i2c_Address 0x3d //initialize with the I2C addr 0x3D Typically Adafruit OLED's
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1   //   QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
char str[128];
int i,j;
// wait until serial port opens for native USB devices
while (! Serial) {
delay(1);
/* shut them all down */
Serial.println("Adafruit VL53L0X test - shutting down sensors");
for(i=0 ; i< N_SENSORS ;  i++) {
digitalWrite(lox[i].xshut_pin,0);
delay(10);
Serial.println(F("VL53L0X schalte Sensoren ein und setze Adresse\n\n"));
digitalWrite(XSHUT_1,1); // schalte Sensor ein
delay(10);
if (!lox1.begin(LX_ADDR_1)) { // setze Adresse und starte Sensor
Serial.println(F("Failed to boot VL53L0X 1"));
//while(1); /* hang here forever /
digitalWrite(XSHUT_2,1); // schalte Sensor ein
if (!lox2.begin(LX_ADDR_2)) { // setze Adresse und starte Sensor
Serial.println(F("Failed to boot VL53L0X 2"));
//while(1); / hang here forever /
digitalWrite(XSHUT_3,1); // schalte Sensor ein
if(!lox3.begin(LX_ADDR_3)) { // setze Adresse und starte Sensor
Serial.println(F("Failed to boot VL53L0X 3"));
digitalWrite(XSHUT_4,1); // schalte Sensor ein
if(!lox4.begin(LX_ADDR_4)) { // setze Adresse und starte Sensor
Serial.println(F("Failed to boot VL53L0X 4"));
digitalWrite(XSHUT_5,1); // schalte Sensor ein
if(!lox5.begin(LX_ADDR_5)) { // setze Adresse und starte Sensor
Serial.println(F("Failed to boot VL53L0X 5"));
//while(1); / hang here forever */
Serial.println("all sensors done...");
// power
Serial.println(F("VL53L0X Adressen initialisiert\n"));
delay(250); // wait for the OLED to power up
display.begin(i2c_Address, true); // Address 0x3C default
display.display();
display.clearDisplay();
display.display();
VL53L0X_RangingMeasurementData_t measure1;
VL53L0X_RangingMeasurementData_t measure2;
VL53L0X_RangingMeasurementData_t measure3;
VL53L0X_RangingMeasurementData_t measure4;
VL53L0X_RangingMeasurementData_t measure5;
int i;
Serial.print("Reading a measurement...\n");
lox1.rangingTest(&measure1, false); // pass in 'true' to get debug data printout!
lox2.rangingTest(&measure2, false); // pass in 'true' to get debug data printout!
lox3.rangingTest(&measure3, false); // pass in 'true' to get debug data printout!
lox4.rangingTest(&measure4, false); // pass in 'true' to get debug data printout!
lox5.rangingTest(&measure5, false); // pass in 'true' to get debug data printout!
if (measure1.RangeStatus != 4) {  // phase failures have incorrect data
  display.setTextSize(1);
  display.setTextColor(SH110X_WHITE);
  display.setCursor(0, 0);
  display.fillRect(0,0,120,20,SH110X_BLACK);
  sprintf(str,"Abstand:  %04d mm",measure1.RangeMilliMeter);
  display.println(str);
  display.display();
  delay(100);
  sprintf(str,"Abstand:  ---- mm",measure1.RangeMilliMeter);
  display.display();
  delay(100);
Program output:
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4980
load:0x40078000,len:16612
load:0x40080400,len:3500
entry 0x400805b4
Adafruit VL53L0X test - shut down
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x400f4eeb  PS      : 0x00060530  A0      : 0x800d48a4  A1      : 0x3ffc8310
A2      : 0x00000000  A3      : 0x0000008a  A4      : 0x3ffc833c  A5      : 0x00000001
A6      : 0x00000000  A7      : 0x00060023  A8      : 0x00060023  A9      : 0x3f40ce38
A10     : 0x3ffbe0b0  A11     : 0xffffffff  A12     : 0x80000020  A13     : 0x80000000
A14     : 0x00000001  A15     : 0x00000000  SAR     : 0x0000000f  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000  LBEG    : 0x40085255  LEND    : 0x40085265  LCOUNT  : 0xffffffff
Backtrace: 0x400f4ee8:0x3ffc8310 0x400d48a1:0x3ffc8330 0x400d49a2:0x3ffc8360 0x400d2174:0x3ffc8380 0x400d1cd4:0x3ffc83a0 0x400d1b84:0x3ffc83c0 0x400da115:0x3ffc83f0 0x40088589:0x3ffc8410
ELF file SHA256: 66f74cff0
Please post code and text here according to forum standards. Helpers avoid downloading unknown material and the result is no replies to Your post.
could be a problem with ESP32 Migration from core 2.x to 3.xESP32 Migration from core 2.x to 3.x
try resetting the ESP32 core to 2.0.17?
try testing with just one sensor?
EDIT: ran a quick test using a ESP32 using Adafruit_VL53L0X library V1.2.4 ESP32 core
3.3.5
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
  while (! Serial) {
    delay(1);
  Serial.println("Adafruit VL53L0X test.");
  if (!lox.begin()) {
    Serial.println(F("Failed to boot VL53L0X"));
    while(1);
  // power
  Serial.println(F("VL53L0X API Continuous Ranging example\n\n"));
  // start continuous ranging
  lox.startRangeContinuous();
  if (lox.isRangeComplete()) {
    Serial.print("Distance in mm: ");
    Serial.println(lox.readRange());
serial monitor output
Distance in mm: 9
Distance in mm: 10
Distance in mm: 2
Distance in mm: 189
Distance in mm: 167
Distance in mm: 187
Distance in mm: 214
Distance in mm: 236
Distance in mm: 263
Distance in mm: 287
Distance in mm: 281
Distance in mm: 231
Distance in mm: 251
Distance in mm: 317
Distance in mm: 328
Distance in mm: 322
Distance in mm: 312
Distance in mm: 292
Sorry for that. I hope, my corrections meet the posting standards now.
How does one revert to a previous core? It doesn`t seem to be in libraries, is it?
Have you tried different code examples?
I used this about 2 weeks ago with a few VL53L0X modules on the same I2C bus for a ESP32-S3 and it worked fine. Considering that version 1.2.4 came our November 2023, I likely used the same version as you.
select Tools>Board then Board Manager then enter ESP32 and you should see
what core do you have installed?
however, the program of post 3 runs OK using a ESP32 using Adafruit_VL53L0X library V1.2.4 ESP32 core
3.3.5
what has happened ? does not work at all? some sensors OK some wrong? all wrong?
@Oblivionz Thanks for the code examples but they seem to be intended for an Arduino, not ESP32, at least when I look at the first example. They are talking about Interrupt pins etc.
I reverted to Esp 2.0.17 and the picture is different but still not functioning:
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
load:0x3fff0030,len:1344
load:0x40078000,len:13964
load:0x40080400,len:3600
entry 0x400805f0
all sensors done...
I’ll give up trying with all sorts of reverting to older versions and wil start piecewise from beginning. One single module first and then get on.
good idea!
if you have 5 VL53L0X are you using the XSHUT input to disable devices while you change I2C addresses?
I never used more than two VL53L0X and used XSHUT to disable one while I changed the I2C address of the other
also tested VL6180X and VL53L1X
Yes, I’ using - as can be seen in the posted project - the XSHUT input is used to shut down the respective devices.
I narrowed down the example to one device (on the breadboard) the devices are still daisy chained.
This is what the program outputs:
entry 0x400805b4
VL53L0X Info:
Device Name: VL53L0X ES1 or later, Type: VL53L0X, ID: VL53L0CAV0DH/1$5
Rev Major: 1, Minor: 1
VL53L0X: StaticInit
VL53L0X: PerformRefSpadManagement
refSpadCount = 3, isApertureSpads = 0
VL53L0X Error: -6
And this is the program itself:
#include <SPI.h>
#include <Wire.h>
#Adafruit_VL53L0X lox = Adafruit_VL53L0X();
#define XSHUT_5 19
#define XSHUT_4 18
#define XSHUT_3 17
#define XSHUT_2 16
#define XSHUT_1 15
char str[128];
while (! Serial) {
delay(1);
digitalWrite(15,0);
delay(10);
digitalWrite(15,1);
Serial.println("Adafruit VL53L0X test");
if (!lox.begin(0x30,true)) {
while(1);
// power
Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
display.display();
sprintf(str,"VL53L0X API Simple Ranging example");
display.setCursor(0, 30);
display.display();
VL53L0X_RangingMeasurementData_t measure;
Serial.print("Reading a measurement... ");
lox.rangingTest(&measure, true); // pass in 'true' to get debug data printout!
if (measure.RangeStatus != 4) { // phase failures have incorrect data
sprintf(str,"Abstand: %04d mm",measure.RangeMilliMeter);
display.display();
delay(100);
sprintf(str,"Abstand: ---- mm",measure.RangeMilliMeter);
display.display();
delay(100);
I tried the example (2 device initialization second example) from the site you gave the link to. It gives a compiling error.
/Users/me/Library/Arduino15/packages/esp32/tools/esp-x32/2511/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld: /Users/me/Library/Caches/arduino/cores/9888ff8ce85003010d2c07dcb96d0e00/core.a(main.cpp.o):(.literal._Z8loopTaskPv+0x8): undefined reference to _Z4loopv' /Users/me/Library/Arduino15/packages/esp32/tools/esp-x32/2511/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld: /Users/me/Library/Caches/arduino/cores/9888ff8ce85003010d2c07dcb96d0e00/core.a(main.cpp.o): in function _Z8loopTaskPv':
/Users/me/Library/Arduino15/packages/esp32/hardware/esp32/3.3.6/cores/esp32/main.cpp:71:(.text._Z8loopTaskPv+0x37): undefined reference to `_Z4loopv'
collect2: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
 * Ethan Zaitchik
 * VL53L0X Distance Sensor Basic Example
 * Full guide: https://zaitronics.com.au/blogs/guides/vl53l0x-time-of-flight-distance-sensor-advanced-guide
Adafruit_VL53L0X lox1;
Adafruit_VL53L0X lox2;
// Pin definitions
const byte XSHUT_1 = 15;  // XSHUT for first sensor
const byte XSHUT_2 = 16;  // XSHUT for second sensor
  // Set both XSHUT pins as outputs and hold sensors in shutdown
pinMode(XSHUT_1, OUTPUT);
pinMode(XSHUT_2, OUTPUT);
digitalWrite(XSHUT_1, LOW);
digitalWrite(XSHUT_2, LOW);
  // Enable and configure first sensor with new address 0x30
digitalWrite(XSHUT_1, HIGH);
delay(10); // Small delay for sensor to wake up
if (!lox1.begin(0x30)) {
Serial.println("Failed to boot sensor 1");
while (1);
// Enable and configure second sensor with new address 0x31
digitalWrite(XSHUT_2, HIGH);
delay(10);
if (!lox2.begin(0x31)) {
Serial.println("Failed to boot sensor 2");
while (1);
Serial.println("Both sensors initialized with unique addresses!");
I assume you only have one VL53L0X connected to the I2C SCL and SDA GPIOs?
using IDE v2.3.4 ESP32 core 3.3.6 if I run the program of post 12 on an ESP32 with a VL53L0X I get (note I don't have a SH110X)
VL53L0X Info:
Device Name: VL53L0X ES1 or later, Type: VL53L0X, ID: VL53L0CBV0DH/1$1
VL53L0X: StaticInit
refSpadCount = 5, isApertureSpads = 1
VL53L0X: PerformRefCalibration
VL53L0X: SetDeviceMode
Reading a measurement... sVL53L0X: PerformSingleRangingMeasurement
Range Status: 0 : Range Valid
RANGE IGNORE THRESHOLD: 14.09
Measured distance: 246
RANGE IGNORE THRESHOLD: 14.02
Measured distance: 249
RANGE IGNORE THRESHOLD: 13.99
RANGE IGNORE THRESHOLD: 13.60
Measured distance: 248
RANGE IGNORE THRESHOLD: 13.38
Measured distance: 251
RANGE IGNORE THRESHOLD: 10.73
Measured distance: 275
RANGE IGNORE THRESHOLD: 10.06
Measured distance: 283
RANGE IGNORE THRESHOLD: 9.59
Measured distance: 284
checking with a ruler the Measured distance: appears to be correct
you have a lot of devices attached to the ESP32 - could you be overloading the ESP32 3.3v supply?
Can you post back your program so I can try it out? I’m getting (yes, one device connected):
entry 0x400805b4
VL53L0X Info:
VL53L0X: StaticInit
VL53L0X Error: -6
The ESP32 is powered via the USB-C cable (5V) from a USB HUB which in turn get his supply from a wall outlet supply.
EDIT: I got one of my own examples working (with a single device). The behaviour is still a bit flakey. I found an article and a YT video saying that a delay(50) in the setup() section before the device is initialized could help. It seems that it worked.
   delay(50); // to avoid Error -6 (really?)
