I copied this code from a youtube video link, The code enables the sensor to turn on light when detecting anything and then you have to set a timer for the light to turn off.
HC-SR05 pin Arduino pin Relay Board
vcc 5V X
Trig pin 9 X
Echo pin 8 X
Gnd Gnd Gnd
X pin 12 signal pin
X Vin +V
int s;
int state=0;
// initialize serial communication:
pinMode(8, INPUT);
pinMode(9, OUTPUT);
pinMode(12, OUTPUT);
digitalWrite(9, LOW);
digitalWrite(8, LOW);
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
digitalWrite(9, HIGH);
delayMicroseconds(5);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
duration = pulseIn(8, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
if(inches<12){ // change number increse or decrese distanse eg 12 for 12 inches
digitalWrite(12, HIGH);
delay(2000);
}else{
digitalWrite(12, LOW);
delay(100);
long microsecondsToInches(long microseconds) {
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds) {
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
