Toggle timed output with analogRead
Hi
I'm having some difficulty understanding the millis() when trying to create an output to go high for X time, and adding in to the complication of using a analogRead as the trigger of that event. So, simply put, what I'm trying to accomplish is if the analog value goes above a certain value (500 in my case) I am tying to have a relay, attached to digital 22 turn on for, in this case, 750ms.
The AREF is external, and the reading of the analogRead is working just fine.
oid setup() {
analogReference(EXTERNAL);
pinMode(A12, INPUT); // Mic In
pinMode(22, OUTPUT); //Trigger output
int m0 = analogRead(A15);
unsigned int Releaseperiod = 750;
unsigned long time_now = 0;
unsigned int offAt = 750;
Serial.println(m0);
delay(1);
  (analogRead(m0) >= 500);
  digitalWrite(Release, HIGH);
 //Here is where I cannot figure out how to add in the millis to keep the relay on for 750ms
  digitalWrite(Release, LOW);
loop()  }
Welcome
Here is an example I made for someone else : t940977.ino - Wokwi Arduino and ESP32 Simulator
When the slider is below a value, alarm is on for a few seconds, then stops, and the LED will turn on.
there were several changes needed just to make the code compilable though senseless
const byte anlgPin    = A0;
const byte releasePin = LED_BUILTIN;
    pinMode(anlgPin, INPUT); // Mic In
    int m0 = analogRead(anlgPin);
    Serial.println(m0);
    delay(1);
        digitalWrite(releasePin, HIGH);
        digitalWrite(releasePin, LOW);
    // loop() - why is loop() called within loop() ?
consider following which may do what you're attempting
const unsigned int ReleasePeriod = 750;
const byte anlgPin = A1;
const byte ledPin  = LED_BUILTIN;
unsigned long msecLst;
enum { Off = HIGH, On = LOW };
void setup ()
    Serial.begin (9600);
    pinMode (ledPin, OUTPUT);
    digitalWrite (ledPin, Off);
void loop ()
    unsigned long msec = millis ();
    if (On == digitalRead (ledPin) && (msec - msecLst) > ReleasePeriod)  {
    int m0 = analogRead (anlgPin);
    Serial.println (m0);
    if (500 < m0)  {
        msecLst = msec;
        digitalWrite (ledPin, On);
My take on the solution:
// if the analog value goes above a certain value (500 in my case)
// I am tying to have a relay, attached to digital 22 turn on for,
// in this case, 750ms.
const byte AnalogPin = A0;
const byte RelayPin = 22;
const unsigned long RelayOnTime = 750;
  digitalWrite(RelayPin, HIGH); // Relay off
  pinMode(RelayPin, OUTPUT);
  if (analogRead(AnalogPin) > 500)
    // have a relay, attached to digital 22 turn on
    digitalWrite(RelayPin, LOW);  // Relay on
    // for, in this case, 750ms.
    delay(RelayOnTime);
