too few arguments to function error[SOLVED]
I am having an issue with my code. The ide keeps saying: too few arguments to function 'void digitalWrite(uint8_t, uint8_t)'.
My code is:
int red = 3;
int yellow = 5;
int green = 8;
int blue = 13;
int activate = 7;
  pinMode(activate, INPUT_PULLUP);
  pinMode(red, OUTPUT);
  pinMode(yellow, OUTPUT);
  pinMode(blue, OUTPUT);
  pinMode(green, OUTPUT);
  if (digitalRead(activate) == HIGH)
    digitalWrite(green) == LOW);
    digitalWrite(yellow) == HIGH);
    delay(3000);
    digitalWrite(yellow) == LOW);
    digitalWrite(red) == HIGH);
  else if (digitalRead(activate) == LOW)
   digitalWrite(green) == HIGH);
   digitalWrite(blue) == LOW);
   digitalWrite(red) == LOW);
I am using the UNO board
I am using 5 led's(one red, one yellow, one green, two blue), five 220ohm resistors(one per LED), and one button.
Pin setup:
the two blue led's to pin 13
red led to pin 3
yellow led topin 5
green led to pin 8
button(activate in code) to pin 7
Did i code it wrong? Does anybody know the solution? I tried the else if as an if function already.
(For fun, I atached the blue led's to pin D13 to see the board led blink [Uno prototype shield atached.])
Go to the C++ reference section to see if you are doing this correctly:
Look at the syntax of the function: Syntax
digitalWrite(pin, value).
Does that look like what you have?
Paul
larryd:
Arduino Reference - Arduino Reference
larryd:
Thanks larryd, i didn't catch that.
i tried that, but it did not work. here is my work:
int green = 9;
int yellow = 10;
int red =11;
int motor = 3;
pinMode(motor, OUTPUT);
pinMode(green) == LOW);
pinMode(yellow) == LOW);
pinMode(red) == LOW);
pinMode(motor) == LOW);
pinMode(green) == HIGH);
pinMode(yellow) == HIGH);
pinMode(red) == HIGH);
pinMode(motor) == HIGH);
