Hello,
Thanks for your help !
In a nushell: I've a Touchshield Slide which cottects to a Duemilanove (got it from www.liquidware.com).
The native Hardware Serial port on the Duemilanove is used to communicate with the Touchshield Slide.
I've tried to install a Soft Serial port and I'm just getting compile errors ‘`digital_pin_to_port_PGM' and ’port_to_input_PGM’.
Can you help ?
Detailded description:
A) IDE is the Antipasto branch of the Arduino IDE, version: 0018-Antipasto-0043
B) The Soft Serial Library that I have is: NewSoftSerial (NewSoftSerial | Arduiniana)
Ther are 2 files: NewSoftSerial.h & NewSoftSerial.cpp
[I do not care what is used once it works]
C) Where do I include these files in the directory structure so that they are included?
(I had put them in: Antipasto/hardware/arduino/cores/touchscreen/src/components/libraries
and selected import library from the sketch menu)
Below is a very simple program, the code and compile errors:
#include <NewSoftSerial.h>
NewSoftSerial mySerial(8, 9);
// set the data rate for the NewSoftSerial port
mySerial.begin(4800);
mySerial.println("Hello, world?");
void loop() // run over and over again
if (mySerial.available()) {
Serial.print((char)mySerial.read());
if (Serial.available()) {
mySerial.print((char)Serial.read());
Handling the compile 4
Saving sketches...
Sketches saved.
compile(), new thread run about to sketch.compile()
[echo] Building TouchShield Slide libraries...
[echo] Building TouchShield Slide board target...
[echo] Building NewSoftSerialTest for the TouchShield Slide core...
[exec] C:\Users\GABRIE~1.LEE\AppData\Local\Temp\build5935907789769535347.tmp/targets/body/lib\libcontrib.a(NewSoftSerial.o): In function NewSoftSerial::setRX(unsigned char)': [exec] C:\__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:381: undefined reference to digital_pin_to_bit_mask_PGM'
[exec] C:__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:381: undefined reference to digital_pin_to_bit_mask_PGM' [exec] C:\__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:382: undefined reference to digital_pin_to_port_PGM'
[exec] C:__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:382: undefined reference to digital_pin_to_port_PGM' [exec] C:\__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:383: undefined reference to port_to_input_PGM'
[exec] C:__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:383: undefined reference to port_to_input_PGM' [exec] C:\Users\GABRIE~1.LEE\AppData\Local\Temp\build5935907789769535347.tmp/targets/body/lib\libcontrib.a(NewSoftSerial.o): In function NewSoftSerial::setTX(unsigned char)':
[exec] C:__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:370: undefined reference to digital_pin_to_bit_mask_PGM' [exec] C:\__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:370: undefined reference to digital_pin_to_bit_mask_PGM'
[exec] C:__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:371: undefined reference to digital_pin_to_port_PGM' [exec] C:\__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:371: undefined reference to digital_pin_to_port_PGM'
[exec] C:__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:372: undefined reference to port_to_output_PGM' [exec] C:\__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\components\libraries\NewSoftSerial/NewSoftSerial.cpp:372: undefined reference to port_to_output_PGM'
BUILD FAILED
C:__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\build.xml:136: The following error occurred while executing this line:
C:__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\src\template\build.xml:154: The following error occurred while executing this line:
C:__2011\David Byrne\Development documents\Arduino_Antipasto_win32\Antipasto\hardware\arduino\cores\touchshield\config\build.ccmacros.xml:45: exec returned: 1
Total time: 5 seconds
