Hi, i have bought 5 of this TP4056, and they works fine charching 1 battery 18650.
I have 2 questions:
how can i put the tp4056 in such a way that the battery powers the circuit but when i insert the cable in the tp4056 it charges the battery? if so, would the circuit stop or continue to run meanwhile the battery is charging?
After the first question, i would like to know which would be the characteristic for a solar pannel to recharge the 18650. I mean the voltage, the Watt, the Ampere.
Because i want a solar pannel that recharge my battery 18650 meanwhile the circuit is connected to the battery (so i hope it last for really long time). The circuit connected uses 3.5 mah and every minute, for 3 second it uses 15mah. I think would be more the recharge than the discharge of the battery, isn't it?
The tp4046 can be used to charge the battery with a solar cell while running on the battery. I found 6 V's to the TP4056 to works better than 5V to the TP. The TP will wear out the batteries in about 4 to 6 months and Li does not work well when temps turn freezing.
Just connect the load to the TP output.
If you are interested in a better solution, I'd use 12V solar panels connected to a reverse flow prevention diode then a MPPT charge controller.
I did not 'say' that your idea would not work. One might be able to discern from post#2 that I have used a solar cell and a LiPo and a TP4056 to power a project.
The TP4560 can deliver 1amp output to charge the battery/load supply.
The video use this solar panel: solar panel 6V 0.6W
Could i use this one? that have 6V, 0.6W but here says 100mah (and the one from amazon doesn't says that mah): solar panel 6V 0.6W 100mah (the option 6V 0.6W etc...)
