Tractor intermittent wiper motor control with added DFRobot Intelligent Rain Detection Module
Ok, so to have others to do the whole shebang is ok, as long as you present it? Pull someone elses leg pal. :upside_down_face:
Hi I got the sensor from DFRB and I connected it to UNO R4 and coded as above but not getting data frame from sensor to RX of UNO can someone help me
Are you certain that you have the Tx of the sensor connected to the Rx of the R4?
It looks like there is a white wire going to D0 which is indeed Rx, but this documentation says the the sensor Tx is yellow.
https://www.dfrobot.com/product-2611.html
Hi, thanks for helping me, I'm very confused about this problem because in this arrangement the white wire is TX and I also tried the yellow and white pins but no results, the RX light of the UNO is not on, meaning it is not receiving a signal.
Or am I making some mistake in this tutorial?
No screen shots please. Use codetags <CODE>to post your code.
Once your code is posted properly others will be able to copy, test and edit it.
  Serial.begin(115200);    // Kết nối với Serial Monitor
  Serial.println("Dang cho du lieu tu cam bien...");
  if (Serial.available()) {
    byte b = Serial.read();
    Serial.print("0x");
    if (b < 0x10) Serial.print("0");
    Serial.print(b, HEX);
    Serial.print(" ");
Here is the program I wrote, I also tried both yellow and white wires but no result is sent to UNO.
The code to read the sensor on pin0 should be using Serial1 like there was in the previous screen image.
Do you have an oscilloscope to see if indeed you are getting data from the sensor?
I don't have an oscilloscope to test, I tried with different command lines but it seems they don't work
I did some more research and they said that I should use any Serial Debugger to debug the sensor before actually connecting it to the MCU board. I don't know what that means, will the first time used sensor work when connected to the UNO R4
The user manual page 7 suggests this to check out the serial interface.
To detect whether the UART communication line
between the module and the host works normally, the host commands the module
to send rainfall status or system status, and if it receives a reply from the module, it
means that the communication works normally, otherwise there is something wrong
with communication line.
Page 8 then discusses the firmware version query.
See if this code gets you a response with the version.
  Serial1.begin(115200);    // Kết nối với Serial Monitor
  byte firmwareVersionQuery[] = {0x3A, 0x00, 0x00, 0x00, 0x4B};
  Serial1.write(firmwareVersionQuery, 5);
  if (Serial1.available()) {
    while (Serial1.available())
      byte b = Serial1.read();
      Serial.print("0x");
      Serial.print(" ");
  delay(5000);
Post #15 gives you a good example of how to do the calibration commands.
thanks a lot, there is actually communication between UNO R4 and the sensor, and this is what I get after using the code you provided​:kissing_face_with_closed_eyes::kissing_face_with_closed_eyes:
Papagino, can you give me the 3D box file of this project?
