Traffic Lights at an intersection
Hello!
I am trying to get traffic lights to work on my lego city build. I've written a code with millis instead of delays so I can use a button that gives a fast green light to a bus lane. But my code gets stuck on 2 green lights and 2 red lights constantly...
this here is my code:
int Red1_pin = 12;
int Yellow1_pin = 11;
int Green1_pin = 10;
int Red2_pin = 9;
int Yellow2_pin = 8;
int Green2_pin = 7;
int Bus_pin = 6;
unsigned long starttime;
unsigned long currenttime;
int state = 1;
	pinMode(Red1_pin, OUTPUT);
	pinMode(Yellow1_pin, OUTPUT);
	pinMode(Green1_pin, OUTPUT);
	pinMode(Red2_pin, OUTPUT);
	pinMode(Yellow2_pin, OUTPUT);
	pinMode(Green2_pin, OUTPUT);
	pinMode(Bus_pin, INPUT);
	starttime = millis();
  if (state == 1) {
    digitalWrite(Yellow1_pin, LOW);
    digitalWrite(Red1_pin, HIGH);
    digitalWrite(Red2_pin, HIGH);
    currenttime = millis();
    if(currenttime - starttime >= 2000) {
      state = 2;
  if(state == 2) {
    digitalWrite(Green1_pin, HIGH);
    digitalWrite(Red1_pin, LOW);
    if(currenttime - starttime >= 8000) {
      state = 3;
  if (state == 3) {
    digitalWrite(Yellow1_pin , HIGH);
    digitalWrite(Green1_pin , LOW);
    if(digitalRead(Bus_pin) == HIGH) {
      state = 4;
    if(currenttime - starttime >=2000) {
      state = 4;
  if (state == 4){
    digitalWrite(Yellow2_pin, LOW);
      state = 5;
      state = 5;
  if(state == 5){
    digitalWrite(Green2_pin, HIGH);
    if(currenttime - starttime >=10000) {
      state = 6;
  if (state == 6){
      state = 1;
      state = 1;
I have no clue what causes the problem there for my question to you guys, can you help me?
sorry for english, not my motherlanguage
I think you might have your LEDs wired "ON" always... because your code is turning RED and GREEN off (as it should).
Hello licolada
Insert a logic analyzer in the sketch calling Serial.println()´s at POI to check the logic of the sequencer.
Hi!
I'm not sure about the complete logic when the button is pressed so play with this code.
#define INTERVAL_2k 0
#define INTERVAL_8k 1
#define INTERVAL_10k 2
#include <Arduino.h>
#include <Bounce2.h> // https://github.com/thomasfredericks/Bounce2/archive/refs/heads/master.zip
const byte Red1_pin = 9;
const byte Yellow1_pin = 7;
const byte Green1_pin = 8;
const byte Red2_pin = 6;
const byte Yellow2_pin = 5;
const byte Green2_pin = 4;
const byte Bus_pin = 3;
const byte numIntervals = 3;
const unsigned int interval[numIntervals] = {2000, 8000, 10000};
byte intervalIndex = 0;
byte state = 1;
bool print = false;
bool pressedOneTime = false;
Bounce2::Button button = Bounce2::Button();
void printDebug(bool start = false)
  if (start == true)
    Serial.println("Starting...");
  Serial.print("\nState: ");
  Serial.print(state);
  Serial.print(", Interval: ");
  Serial.println(interval[intervalIndex]);
void controlLightsOfSectionOne(bool red1, bool yellow1, bool green1)
  digitalWrite(Red1_pin, red1);
  digitalWrite(Yellow1_pin, yellow1);
  digitalWrite(Green1_pin, green1);
void controlLightsOfSectionTwo(bool red2, bool yellow2, bool green2)
  digitalWrite(Red2_pin, red2);
  digitalWrite(Yellow2_pin, yellow2);
  digitalWrite(Green2_pin, green2);
  button.attach(Bus_pin, INPUT_PULLUP);
  button.interval(5);
  button.setPressedState(LOW);
  controlLightsOfSectionOne(LOW, LOW, LOW); // All lights OFF
  controlLightsOfSectionTwo(LOW, LOW, LOW); // All lights OFF
  printDebug(true);
  if ((millis() - starttime) >= interval[intervalIndex])
    state++;
    if (state > 5)
      state = 2;
    print = true;
  button.update();
  if (button.pressed())
    Serial.println("Button Pressed!");
    if ((pressedOneTime == false) && (state < 3))
      pressedOneTime = true;
      state = 3;
      print = true;
  switch (state)
    case 1:                                        // Idle state
        intervalIndex = INTERVAL_2k;
        controlLightsOfSectionOne(HIGH, LOW, LOW); // Red ON, yellow and green OFF
        controlLightsOfSectionTwo(HIGH, LOW, LOW); // Red ON, yellow and green OFF
    case 2: // Green for section 1 and red for section 2
        intervalIndex = INTERVAL_8k;
        controlLightsOfSectionOne(LOW, LOW, HIGH);
    case 3: // yellow for section 1 and red for section 2
        if(pressedOneTime == true)
          Serial.println("Fast green enabled");
        controlLightsOfSectionOne(LOW, HIGH, LOW);
    case 4: // Red for section 1 and green for section 2
          intervalIndex = INTERVAL_10k;
        controlLightsOfSectionTwo(LOW, LOW, HIGH);
    case 5: // Yellow for section 2 and red for section 1
        controlLightsOfSectionTwo(LOW, HIGH, LOW);
    default:
  if(print == true)
    print = false;
    printDebug();
Best regards.
