I am thinking of building a NeoPixel-based lamp, in which the vertical column supporting the bulb and shade is a transparent plastic cylinder, with vertical Neopixel strips inside. But as an added twist, I want to be able to rotate this cylinder at controlled RPM, to see what sort of interesting new lighting effects I could achieve.
So here's the problem. I need to transfer power (two wires) and signal (one wire) from a stationary source into the rotating structure. If I had a circular disc at the bottom of the cylinder with three concentric copper circles, made, say, from copper clad board, this could be done. But I suspect that the copper would quickly wear away with continued use.
Does anybody have any experience with such a device, or any good ideas as to how to make a good durable mechanism?
Thanks in advance for any help.
