Hello,
i have question i will transfer a button event value on html too a value for ESP8266. So when i push the html-button then the motor should spinning and when i release the html-button the motor should stop spinning(onmousedown event)
thank you i have another question about an scroll bar for the steering, the question is how to get an variable that is changing from the scroll bar. Do you also have an method that de requests doesnt crash through so much requests.
marc1200:
PS. in the attachment the updated project file
you want to control a RC car over web? that must be a very slow car
do not send every change. code it in js so that the next request is sent only when the previous returned
yes, i have an bluetooth module zo i can control it with bluetooth, is bluetooth faster then wifi, or set the esp8266 as an AP so that i can connect with my smartphone to the wifi network of the esp8266? what i want is when i push the button the car will drive when i release the button then the cars stops, but with wifi the xhr gaves errors how can that, i can only push once en then the car drive but when i push another button xhr gaves only errors.
