Transferring String through HM-10 to Xcode Project
Hi, so I have looked through a lot of the Arduino forums and some of which have been helpful and others not so much. I am trying to transfer data from my arduino uno r4 wifi to my xcode project through my HM-10 XC4382 BLE Bluetooth Module. I am trying to essentially scan an RFID tag and transmit the name and UUID to the phone app to acknowledge the tag has been scanned.
Every time I connect to my HM-10 module successfully on my phone but when I try and print the message it shows up as empty. When trying to debug it does show the statement when I scan the RFID tag each time which tells me it is being received but perhaps the format is not compatible with Xcode? Would appreciate any assistance :slight_smile:
I have both arduino code and swift code. In my arduino code, I am working with RFID Scanner (from Jaycar) using the MFRC522 library and is connected the following ways:
Apologies if I may have missed some code / context to this question. Thank you!
RFID Module Setup
3.3V - 3.3V
RST - 9
GND - GND
MISO - 12
MOSI - 11
SCK - 13
SDA - 10
HM-10 Setup
5V - 5V
GND - GND
RX - TX (arduino)
TX - RX (arduino)
Current Arduino Code
#include <SoftwareSerial.h> // for the Bluetooth module
#include <MFRC522.h> // for the RFID module
#define SS_PIN 10
#define RST_PIN 9
String uidString;
MFRC522 rfid(SS_PIN, RST_PIN);
SoftwareSerial BLE_Serial(0, 1); // RX, TX
  BLE_Serial.begin(9600);
  SPI.begin();
  rfid.PCD_Init();
  Serial.println("Waiting for command...");
  BLE_Serial.println("Waiting for command...");
  if (rfid.PICC_IsNewCardPresent()) {
    readRFID();
  if (BLE_Serial.available()) {
    char data = BLE_Serial.read();
    // Serial.println("Hello I am debug");
      readRFID();
    else {
      // Serial.println("I am not connected to Bluetooth");
    delay(10);
void readRFID() {
  rfid.PICC_ReadCardSerial();
  Serial.print("Tag UID: ");
  uidString = String(rfid.uid.uidByte[0]) + " " + String(rfid.uid.uidByte[1]) + " " +
    String(rfid.uid.uidByte[2]) + " " + String(rfid.uid.uidByte[3]);
  Serial.println(uidString);
  boolean authorized = false;
  char *name = "";
  if (uidString == "220 223 30 204") {
    authorized = true;
    name = "KeyCard";
  if (uidString == "243 154 6 14") {
    authorized = true;
    name = "Bagtag";
  if (uidString == "118 211 198 33") {
    authorized = true;
    name = "George";
  if (authorized) {
    char message[50];
    sprintf(message, "You have successfully scanned %s", name);
    Serial.print("Message: ");
    Serial.println(message);
    BLE_Serial.print(message);
    BLE_Serial.write((char)0); // add null character at the end of the message
    delay(200);
My current Swift Code: Utilising Bluetooth Serial Delegate Method & CoreBluetooth
//  ScanCompleteViewController.swift
//  Clutch-IDS
//  Created by Joshua Dinkin on 16/4/2024.
import Foundation
import UIKit
import CoreBluetooth
import QuartzCore
enum ReceivedMessageOption: String {
    case none,
         newline
class ScanCompleteViewController: UIViewController, BluetoothSerialDelegate, CBPeripheralDelegate {
    @IBOutlet weak var mainTextView: UITextView!
    @IBOutlet weak var mainLabel: UILabel!
    @IBOutlet weak var barButton: UIButton!
    @IBOutlet weak var titleLabel: UILabel!
    override func viewDidLoad() {
        super.viewDidLoad()
        // init serial
        serial = BluetoothSerial(delegate: self)
        // UI
        mainLabel.text = ""
        mainLabel.numberOfLines = 0
        reloadView()
        NotificationCenter.default.addObserver(self, selector: #selector(ScanCompleteViewController.reloadView), name: NSNotification.Name(rawValue: "reloadStartViewController"), object: nil)
    @objc func reloadView() {
        // in case we're the visible view again
        serial.delegate = self
        if serial.isReady {
            titleLabel.text = serial.connectedPeripheral!.name
            barButton.setTitle("Disconnect", for: .normal)
            barButton.setTitleColor(.red, for: .normal)
            barButton.isEnabled = true
        } else if serial.centralManager.state == .poweredOn {
            titleLabel.text = "Bluetooth Serial"
            barButton.setTitle("Connect", for: .normal)
            barButton.setTitleColor(view.tintColor, for: .normal)
            barButton.isEnabled = false
    func textViewScrollToBottom() {
        let range = NSMakeRange(NSString(string: mainTextView.text).length - 1, 1)
        mainTextView.scrollRangeToVisible(range)
    //MARK: BluetoothSerialDelegate
    func serialDidReceiveString(_ message: String) {
        // add the received text to the textView, optionally with a line break at the end
        mainLabel.text! += message
        if let pref = UserDefaults.standard.string(forKey: ReceivedMessageOptionKey) {
            mainLabel.text! += "\n"
        print("Received message: \(message)")
        print(UserDefaults.standard.string(forKey: ReceivedMessageOptionKey))
        //print("This is the \(message)")
       // print(UserDefaults.standard.string(forKey: ReceivedMessageOptionKey))
       // print(mainLabel.text)
    func serialDidDisconnect(_ peripheral: CBPeripheral, error: NSError?) {
        reloadView()
        let hud = MBProgressHUD.showAdded(to: view, animated: true)
        hud?.mode = MBProgressHUDMode.text
        hud?.labelText = "Disconnected"
        hud?.hide(true, afterDelay: 1.0)
    func serialDidChangeState() {
        reloadView()
        if serial.centralManager.state != .poweredOn {
            hud?.labelText = "Bluetooth turned off"
    func peripheral(_ peripheral: CBPeripheral, didUpdateValueFor characteristic: CBCharacteristic, error: Error?) {
            if let error = error {
                    print("Error reading characteristics: \(error)")
                    return
                if let value = characteristic.value {
                    if let dataBLE = String(data: value, encoding: .utf8) {
                        print("Data from Arduino: \(dataBLE)")
                        DispatchQueue.main.async {
                            self.mainLabel.text = dataBLE
                        print("Failed to convert data to string")
    @IBAction func buttonPressed(_ sender: Any) {
        if serial.connectedPeripheral == nil {
            performSegue(withIdentifier: "ShowScanner", sender: self)
            serial.disconnect()
            reloadView()
Try using pins other than 0 and 1 as they are used by Serial.
