Transistor question[SOLVED]
I am trying to turn on/off a few 5v relays with my Wemos D1 Mini. The Mini uses 3.3v so I am trying to use a transistor connected to the relays. I am using an MPS A92 (PNP) transistor.
My question is this:
When I use a multimeter to test the voltage of the Base, when nothing is connected to it, I get a reading of 4.48v. Is this voltage suppose to be there? Also, is the voltage dangerous to my 3.3v mini?
Here is a diagram and an image of my setup:
With a 3.3v mini, use a NPN, wire as Q1 is wired.
Do not forget the base resistor!
An Arduino 3.3v output cannot turn off the PNP transistor if the load power supply is 5v.
“Also, is the voltage dangerous to my 3.3v mini? ”
It could burn up your Arduino!
Always use a base resistor!
Wrong sort use a NPN. You will never be able to turn off a PNP transistor because your output from the Arduino does not go high enough.
That is a silly and totally fruitless thing to do.
Yes and yes
