I am attempting to use the code found here to upload a picture to my FTP server. The code on the page I linked is for Ethernet shields and I am using the original Arduino Wi-Fi shield.. I am using an Arduino MEGA 2560 and I made some changes to the main FTP code to make it compatible with the Wi-Fi shield I am using. I am not an expert on programming.
Regarding the connections, I mounted the shield and inserted the micro SD card and have done nothing else. Here is the edited code I uploaded on the Arduino:
If you compare the two codes you will see that I only made some minor changes such as replacing the Ethernet library functions with the Wi-Fi library functions. Here is the output of the serial monitor:
Ready. Press f or r SD opened Command connection failed FTP FAIL
It is my first time doing something like this and so I will have a few questions. The IP address I am supposed to enter is the IP address of my network, right? I assume that my FTP server shares the same address. Any help would be appreciated!
Leona_S:
Can you save us some time and comment on what changes you made?
can you check that your FTP server is accessable from other machines in the network, e.g. by running an FTP client on a different PC? this will check if the firewall is letting FTP requests thru
using Wireshark can you see the FTP requests from the Arduino?
Attempting to connect to the FTP server using a different PC does not work. I even disabled Firewall on both PC's. I am using "localhost" as the FTP server host and, on the FTP client, I enter the IP address of my laptop.
are the server and the client machines on the same router ? what does the router control panel tell you about connected devices?
does you arduino connect to the WiFi network OK? if not run the ScanNetworks example
if you are running virtual machines (using software such as virtualbox) you can get odd effects due to the their network connections. I disable all the virtual network devices if I am not running VMs.
I have modified a Ethernet FTP test to use a ESP-O1 WiFi device (I don't have a WiFi shield with SD card)
it connects to to the WiFi network and when f is pressed connects to the FTP server and sends a single line file
FTP passive client for IDE v1.0.1 and w5100/w5200
Posted October 2012 by SurferTim
Modified 6 June 2015 by SurferTim
// WiFiexample to send a single line file
#include <SPI.h>
#include "WiFiEsp.h"
//#define SPRINTF // comment out to use strcat()
// update for your WiFi
char ssid[] = "zzzzz"; // your network SSID (name)
char pass[] = "xxxxx"; // your network password
// change to your server
IPAddress server( 192, 168, 1, 96 );
WiFiEspClient client;
WiFiEspClient dclient;
int status = WL_IDLE_STATUS; // the Wifi radio's status
char outBuf[128];
char outCount;
// fileName to your file (8.3 format!) and file
char fileName[13] = "test.txt";
char clientBuf[64]="hello from ESP-01 1234567890"; // file to send
int clientCount = strlen(clientBuf);
// initialize serial for ESP module
Serial1.begin(9600);
// initialize ESP module
WiFi.init(&Serial1);
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// attempt to connect to WiFi network
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network
status = WiFi.begin(ssid, pass);
// you're connected now, so print out the data
Serial.println("You're connected to the network");
printWifiStatus(); delay(2000);
Serial.println(F("Ready. Press f"));
byte inChar;
inChar = Serial.read();
if(inChar == 'f')
if(doFTP()) Serial.println(F("FTP OK"));
else Serial.println(F("FTP FAIL"));
byte doFTP()
if (client.connect(server,21)) {
Serial.println(F("Command connected"));
else {
Serial.println(F("Command connection failed"));
return 0;
// send login name and password
if(!eRcv()) return 0;
client.println(F("USER horace"));
client.println(F("PASS horace"));
client.println(F("SYST"));
client.println(F("Type I"));
client.println(F("PASV"));
char *tStr = strtok(outBuf,"(,");
int array_pasv[6];
for ( int i = 0; i < 6; i++) {
tStr = strtok(NULL,"(,");
array_pasv[i] = atoi(tStr);
if(tStr == NULL)
Serial.println(F("Bad PASV Answer"));
unsigned int hiPort,loPort;
hiPort = array_pasv[4] << 8;
loPort = array_pasv[5] & 255;
Serial.print(F("Data port: "));
hiPort = hiPort | loPort;
Serial.println(hiPort);
if (dclient.connect(server,hiPort)) {
Serial.println(F("Data connected"));
else {
Serial.println(F("Data connection failed"));
client.stop();
return 0;
// setup to send file file fileName
client.print(F("STOR "));
client.println(fileName);
if(!eRcv())
dclient.stop();
return 0;
// send file contents
dclient.write(clientBuf,clientCount);
dclient.stop();
Serial.println(F("Data disconnected"));
client.println(F("QUIT"));
client.stop();
Serial.println(F("Command disconnected"));
return 1;
byte eRcv()
byte respCode;
byte thisByte;
while(!client.available()) delay(1);
respCode = client.peek();
outCount = 0;
while(client.available())
thisByte = client.read();
Serial.write(thisByte);
if(outCount < 127)
outBuf[outCount] = thisByte;
outCount++;
outBuf[outCount] = 0;
if(respCode >= '4')
efail();
return 0;
return 1;
void efail()
byte thisByte = 0;
client.stop();
Serial.println(F("SD closed"));
void printWifiStatus()
// print the SSID of the network you're attached to
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength
long rssi = WiFi.RSSI();
Serial.print("Signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
a run gives
[WiFiEsp] Initializing ESP module
[WiFiEsp] Initilization successful - 1.5.4
Attempting to connect to WPA SSID: zzzzz
[WiFiEsp] Connected to zzzzz
SSID: zzzzz
IP Address: 192.168.1.97
Signal strength (RSSI):-612 dBm
Ready. Press f
[WiFiEsp] Connecting to 192.168.1.96
Command connected
220-FileZilla Server 0.9.60 beta
220-written by Tim Kosse (tim.kosse@filezilla-project.org)
220 Please visit https://filezilla-project.org/
331 Password required for horace
230 Logged on
215 UNIX emulated by FileZilla
200 Type set to I
227 Entering Passive Mode (192,168,1,96,246,169)
Data port: 63145
Data connected
150 Opening data channel for file upload to server of "/test.txt"
[WiFiEsp] Disconnecting 2
Data disconnected
226 Successfully transferred "/test.txt"
221 Goodbye
FTP OK
the file test.txt on the server PC contains "hello from ESP-01 1234567890"
Both the client and the server are connected to the same router. I don't really know what the control panel is supposed to tell me, other than that the two PC's have different IP addresses. I am sure of the server's IP address (192.168.1.6 in my case).
Yes, it does. I tested the example codes and the Wi-Fi shield is working fine.
I get this error when I connect to the localhost server:
You appear to be behind a NAT router. Please configure the passive mode settings and forward a range of ports in your router.
Warning: FTP over TLS is not enabled, users cannot securely log in.
Retrieving account settings, please wait...
Could this be affecting my client PC? I can connect to the server if I am using the same PC as the client.
you should only need to configure the NAT settings if you wish to be able to connect to the FTP server from the external internet. You would setup port forwarding to forward FTP packets to the appropriate PC.
try the simple FTP in post #6
change #include "WiFiEsp.h" to include your WiFi header etc
I tried the code you posted and got an error due to this part:
I changed it like so:
Serial monitor output:
SSID: zzzz
IP Address: 192.168.1.32
Signal strength (RSSI):-69 dBm
Ready. Press f
FTP FAIL
what FTP server are you using?
I am using my laptop as the server. When I launch FileZilla Server, I enter "localhost" as my host and keep the port as default (14147) and I click "connect". Hope that answers the question.
the firewall (inbound rules) is blocking access or
I have the incorrect IP address for IPAddress server( 192, 168, 1, 96 );
Hi horace
i use heltec wifi kit8 send file to FTP, sometimes I do not complete it, I debug the error at line "array_pasv = atoi (tSt);" or "array_pasv = strtol (tStr, & ptr, 10);" Can you help me? Many thanks
horace:
does it fail on files over a certain size?
could you be overrunning an array?
what is the signal quality like?
Hello horace
Thank you for your interest, I answer the following:
I don't use SD file, I use SPIFFS file.
I checked, the program is not yet in the file transfer phase, and in the process of shaking hands with the FTP server
none of my arrays have been used yet
Good data quality, RSSI = -26dbm, ESP8266 distance to router = 0.5m
because I misunderstood, so I got the above question, I checked and the 2 atoi or strtoi functions are good.
After checking and using the serial debug, I found the following error:
"test befor whiletest after whiletest respCode2230
test befor whiletest after whiletest respCode2215 UNIX emulated by FileZilla
Fatal exception 28 (LoadProhibitedCause):
epc1 = 0x4020e3d2, epc2 = 0x00000000, epc3 = 0x00000000, excvaddr = 0x00000000, depc = 0x00000000 "
the line "test befor whiletest after while" added by me in function eRcv():
"Serial.write (" test befor while ");
while (! client.available ()) delay (1);
Serial.write ("test after while");
respCode = client.peek ();
7. However, sometimes the file is sent successfully
8. MY MAIN PROBLEM IS TO TRANSFER FILE FROM SPIFFS TO MYSERVER BY HTTP OR FTP AS WELL, I WOULD HELP YOU TO HELP ME
